Question about Philips Shb9100/28 Bluetooth Stereo Headset With Noise Reduction
PHILIPS SHB9100 change battery
How do i replace my philips beard trimmer battery?
It depends on what model you have. For Example, this is how you replace the battery on a Philips QG3020 beard trimmer:
Philips QG3020 Disassembly Change Battery
You can write here your trimmer model, in order to get instructions for that.
Jan 29, 2015 | Philips Health & Beauty
Phillips headphones
I would say a problem with the headphones, maybe they've been thrown around a bit?
Nov 17, 2013 | Philips SHB9100/00 Bluetooth Stereo...
Change battery
The batteries need replaced. You will find the correct batteries at shaveroutlet.com at the link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/philips-norelco/shaver-battery-pack-for-most-norelco-more-p-278.html
To open the shaver you will need to remove the back cover by removing the two screws. You may need to slide the trimmer up to reveal second screw. Inside, you will need to remove the metal clip that is in the way.
Use the tutorial video at the link below for information on changing the batteries
http://www.youtube.com/watch?v=2oAnLpvdYqQ
Oct 06, 2013 | Philips Philishave HQ7850 Electric Shaver
Right side of headphone stoped working
you need to open the broken side up and re solder the cable back also check the other cable to see if it hasn't sheered off inside the insulation like mine did. Hope this helps. J
Feb 17, 2013 | Philips SHB9100/00 Bluetooth Stereo...
Can I change a battery in my philips hq7300 shaver
Philips STRONGLY recommends you do not insert any other battery into the razor, whether it be a normal battery, or a rechargeable battery. If your product is still under warranty you may be able to get a replacement.
Mar 01, 2011 | Philips HQ7300 7300 Series Shaver Electric...
My philips gogear vibe is charging fully and will not work for morethan 2 minutes
I think the built-in battery of the player has been dead. If the warranty time takes long up to now you can carry it to a corresponding service centre to change the item or its battery free of charge.
If not, in this case you may decide to be repaired by changing battery or here is the end of its life.
Good luck, bye
gylacz
Jan 28, 2011 | Philips GoGear ViBE Digital Media Player
MY REMOTE DOESN'T WORK AFTER I CHANGED THE BATTERIES. WILL I HAVE TO GET A NEW REMOTE? AND IF SO, WHICH ONE TO WORK WITH MY TV?
Just changing the batteries would not cause the remote to go bad. check the way you have put the batteries in, put a neww pair of batteries, see the terminals inside the remote are clean? If it does not help then you can choose a dedicated remote for philips tvs that does not need programming. These cost $5 to 15.
Apr 26, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Can i replace the battery for my philips SA9122 player? it doesnt hold power anymore
its possible for you to change the battery. If the battery is an in-built, you will have the loose/open the player's cover to be able to access the battery.
Also take the battery along as a sample to get another one.
Take care.
Feb 03, 2010 | Philips GoGear HDD075/17 MP3 Player
MENU KEEPS POPPING UP
It's a software problem with the TV. Go to the PHILIPS web site for downloading the latest software upgrade for your TV to fix the problem.
Lots of Philips TV are having the same problem. Philips support should provide the software for free.
Sep 09, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Philips HDD1630 MP3 Player about 2 years old, no excessive use, won't charge any more or be seen by computer. Only shows low battery on screen then dies. I am a little technically incline, can anyone tell...
You may have to change the battery, but try Reset, Repair, and Update (firmware upgrade) first. Also, there is an FAQ on the Philips website for the computer does not recognize device issue (but only follow it AFTER you have tried reset, repair, and update).
Open Philips Device Manager and try repairing the device. [connect your GoGear to the computer, open Philips Device Manager (Start-->All Programs-->Philips), and click on the repair tab. Now, disconnect your GoGear from computer. Turn the GoGear off if it is not already. Press and hold the volume + key and connect the GoGear to the computer (while still pressing the volume +). A window will pop up saying a repair is being performed. now you can let go of the Volume + button. The repair will get your device working normally again. WARNING: the repair process will delete any music/other media file from your GoGear.]
After repair, perform a firmware upgrade ("Update" tab in Philips Device Mgr while GoGear is connected to computer - see Philips website for more details)
Worst case scenario - Even rechargeable batteries have a limited number of charging cycles. The battery for the SA178 is an LI-Polymer 300mAh 12-hr battery. Philips won't fix it for you, but you might want to find a local repair service.
Feb 05, 2008 | Philips HDD1630 MP3 Player
Philips Shb9100/28 Bluetooth Stereo Headset With Noise Reduction Logo
93 people viewed this question
Top Philips Radio Communications Experts
Computer Repairing
Computer Repairing
wwlvictoria
wwlvictoria
Tom Chichester
Are you a Philips Radio Communication Expert? Answer questions, earn points and help others
