Question about KitchenAid KCMS1655BSS 1.6 Cu. Ft. 1200W Countertop Microwave Oven
Sparks from microwave
When turned on the microwave sparks with nothing in it. Sparks from right side under the cover
2 Suggested Answers
joeguest2
  • 2080 Answers
SOURCE: our kitchenaid microwave, sparks when
If the sparks are happening on the inside of the microwave's cooking area while you are cooking, then make sure you clean the inner surfaces really well. Be sure to remove any cooked on food particles that may have splashed up during cooking.
If the cleaning does not work, you may need to replace the waveguide cover. Click on the following Youtube video link for an instructional video on the process:
http://www.youtube.com/watch?v=M0xsXjhefy4
If the sparks are coming from somewhere other that the cooking area, then your unit may need more significant electrical repairs or service.
Thank you very much and good luck.
Posted on Mar 30, 2011
I need a microwave wave guild cover
Connie, look inside to see if something metallic is in the oven, like aluminum foil. Sparks should not be present. Also remove the grate/shelf if there is one and check under the turntable for metallic pieces. Actually take the turntable out. Test using a glass of water. 1/2 min on high, water should get warm
Apr 23, 2014 | Daewoo KOR-1B4H Microwave Oven
Microwave when turn on making a noise and sparks comin from fan area?
follow this steps and fix it. God bless you
Waveguide Cover
If the microwave is sparking or arcing the waveguide cover might be damaged and shorting out. Try removing the waveguide cover and see if the problem goes away. If there are any damaged spots in the microwave ceiling or sidewalls, repair them and paint them with microwave oven paint. Replace the waveguide cover if it is burnt or if it will not stay in place.
Microwave Oven Paint
If the microwave is sparking or arcing on the side walls the paint might have chipped causing pitting in the metal oven wall. Use microwave safe paint to touch up any bare metal spots.
Rack Support
If the microwave is sparking or arcing near one of the rack supports, remove the support, repaint any bare metal, install a new support.
Feb 06, 2013 | Turbo Air TMW-1100M Green World 1000 Watt...
SParks and smoke from microwave
it may be repairable but not by yourself
take it in for a quote and proper diagnosis
Aug 31, 2017 | Panasonic Microwave Ovens
When using the oven tonight, i saw sparks coming from the plasic clip on the right that holds the rack up. i tried again later and still hearing crackling/sparks. is it possible to replace that...
Yes it is possible to replace the plastic clips. However thats not the problem. The problem is exposed metal under the plastic clip. Remove the clip and you will see it. You need to sand it down so that it is smooth, then use ceramic paint to cover up the exposed metal. You should check under all 4 clips to be safe. Clips are a little tricky to get out, just insert a screwdriver on either side and pry gently.
Mar 01, 2011 | KitchenAid KHMS155L Microwave Oven
Fire sparks when in use off pad on right side of microwave
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jul 09, 2010 | Dacor DMT2420SS Microwave Oven
It sparks, lights up from the inside when turned on - it is 5 yrs old should I replace it?
this would indicate a failing magnetron,the magnetron should still be under warranty and should be replace by a service tech,to also determine if the cabinet has suffered any damage.
If nothing is covered under warranty the it is usually cheaper to go by a new microwave
Feb 23, 2010 | Microwave Ovens
Sparks in the interior while microwave is on. Sparks come from the right side where there is a "cardboard like" cover over an opening.
IF THIS COVER IS DIRTY IT WILL SPARK. IF CLEANING IT DOES NOT HELP IT MAYBE CRACKED OR THE STIRRER BLADE MAY BE OFF
Jan 13, 2010 | Sharp Microwave Ovens
Microwave sparks on the inside
It sounds like it needs professional servicing. There may be an issue with excessive radiation escaping from the oven -- this could be dangerous. Can't say for sure, but were it my oven, I would take it to a shop with the equipment to test for this condition.
Charlie
Aug 23, 2009 | Microwave Ovens
Sparks
usually sparks come from turning and cooking with nothing inside the microwave..if there is grease or something on the bottom the heat will generate a spark
Mar 22, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave ovens
The cover is probably the magenetron. That is where the microwaves come from. If the bread was moist, it might have left condensate in the unit which is causing the sparking. Unplug the unit, leave the door open over night. If you can remove that cover, do so. Be sure to carefully replace it before using the unit. Never turn on a microwave with nothing in it.
Dec 16, 2007 | Sharp R-1480 Microwave Oven
KitchenAid KCMS1655BSS 1.6 Cu. Ft. 1200W Countertop Microwave Oven Logo
76 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
