Question about Keurig B150P Small/Medium Office Brewer
Display: check water supply
We have water supply to the machine and have confirmed that the float is working properly and that it is filling the reservoir. We have reset the machine by powering off and back on. Disply comes up "Check water supply, Touch screen to continue."
cmccune04
  • 213 Answers
SOURCE: Broken O-ring floating in water reservoir. Where
As long as it's not leaking you should be fine. however if you have problems and need a replacement seal just go here,
http://iwantsweetdeals.com/ for your keurig part needs!
Posted on Jun 14, 2010
  • 3 Answers
SOURCE: Water doesn't come down when brewing
I had the same problem, and it turned out it was the top needle that was clogged. I used a safety pin to clean out the needle and it worked again . . . I descaled immediately, just in case it needed that too. I am back to coffee goodness!
Posted on Jul 11, 2010
espressonist
  • 1711 Answers
SOURCE: Display says "brewing" but no water gets pumped .
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig, you have something you can do at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
Posted on Aug 20, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: I have a Keurig B66, the reservoir water gets
Sorry to read about your issue.
Try this first....
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Posted on Dec 22, 2010
BarrettDenCo
  • 1772 Answers
Sorry to read about your problem, I hope this helps you out.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
ds
sdf
s
fs
f
Posted on Dec 23, 2010
I use this dishwasher in a florist to clean wax out of candle glass and recently it is not working. E4 codes appear, and it over flows sometimes.
this all I can find Machine will not fill or will not fill high enough. (Display shows E0, E2, E3 or E4. Machine will not run). 1. Low water pressure - check for clogged hose strainer; ensure the site water pressure meets minimum flow pressures. 2. Make sure probes are clean. (See Cleaning.) 3. No water pressure - main water supply valves may not be working. 4. Anti-siphon valve - located in the lower left area of the chamber just above the water line. Drain the machine and insert toothpick or similar object into hole to verify ball (3?16" OD) is free to float. 5. Delime machine perhaps the wax is plugging up the floating ball area
Apr 20, 2015 | Hobart 24 in. LXIH-3 Built-in Dishwasher
I have a hobart lx-g model which i purchased used a month ago. At the start everything worked great...then when ever i would push the "off" button it would shut down and restart by iteself......
Initially would suggest to check that the power supply requirements are satisfied. You might also need to check the breakers. Depending on the exact model number, the AC supply can be as shown below:
If the above checks out OK, then it could be as you have suspected, the controller is messed up, more specifically the firmware or related electronics. You could of course try a reset by unplugging from the mains or switching off the appropriate breakers for say half an hour.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 03, 2008 | Hobart Dishwashers
Display fill water only but water full help
check small float in tank is not stuck in the down position
Dec 29, 2013 | Jura Capresso Impressa S90 Espresso...
Miele Premier Dishwasher will not fill with water
click on this link directly to check out how fill valve looks http://www.applianceaid.com/images/fillvalve.JPG you will have to remove the access panels to reach the fill valve click on this link to get more instructions http://www.applianceaid.com/dishaccess.html --------- This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned. -------- also click on this link directly to get all types of troubleshooting instructions http://www.applianceaid.com/dish.html -------- This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 24, 2009 | Dishwashers
Dishwasher does not fill with water when started. Problem began slowly with dishes not rinsing completely. Overfill float appears to work properly. Water fills pipe leading to fill solenoid but does n
I am almost certain that your problem is the fill solenoid.
If it does not work, there will be no water entering your machine.
I would either remove it and test it or just replace it at this point.
Tim
Apr 16, 2009 | Dishwashers
Washer does not fill with water
I checked the inlet solenoid valve to make sure it was receiving power, it was. I removed the left hand side panel of the machine. The labyrinth was blocked with crud as was the float switch assy,
Cleaned them out,with boiling hot water, it now works.
Jan 14, 2009 | Bosch 24 in. SGS43C12 Classixx...
Firstly, check to see that your water temperature is selected properly. Next, check to confirm water supply to the washer is adequate, both HOT and COLD. If confirmed, try replacing the fill valve.
May 27, 2008 | Washing Machines
Fill Water Tank But Water Tank is Full
hello in the water tank they is a float it was probably out of water for a while and the float is stuck take the container in our hand and tap it gently by doing that the float gonna get loose move the container you gonna ear the float move put it back fill with water enjoy cheers
Jan 14, 2008 | Gaggia Titanium Espresso Machine
Fill Watertank Message
The black thing floating in the water tank is a plastic shell with a magnet inside. If you clean it...make sure you reinstall it with the tapered (smaller) side down. There is a slight size difference BUT it will make ALL the difference in the world.
I had no idea there was a magnet in that black/greyish case. The direction of the casing is important.
I had the same problem and that solved it!
Jul 29, 2007 | Miele CVA615 Espresso Machine
Keurig B150P Small/Medium Office Brewer Logo
52 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
