Question about Euro-Pro EP901 Vacuum
How much water to add to ep-150 steam cleaner
I have a scunci ss 1000 hand held steamer cleaner. Its been used and given to me from a friend. The steam comes out the trouble is the steam is not hot, just luke warm. how can I fix it myself.
Try descaling it with CLR. Add CLR and water, turn it on but not fully to produce steam, just get it hot. Leave it for an hour. Empty that out and out some more in. Get this up to steam for 10 minutes, switch off, leave it for an hour and empty it. Fill and rinse out twice. Fill with water and see if it is fixed.
Nov 09, 2015 | Scunci SS1000 Handheld Steam Cleaner
Tip
Preventive maintenance for steam cleaners.
Always flush out your machines with clean water after each use. Including the soap container! Never leave chemicals (soap, cleaner,or shampoo) in your unit when your finished, regardless if the manufacture says its ok. If your unit has a heater its good to add a little white vinegar to your rinse.
If you have hard water this is double important (white vinegar).
on Dec 18, 2009 | Vacuums
Can I add vinegar to the water and steam clean laminate flooring?
Unless Shark says water only I don't think that would be a problem. All the vinegar will do is remove any grease on the floor and perhaps remove some bad odor. I rinse my hair with vinegar water every day after shampoo and conditioner. Only then do I consider my baby fine hair clean!
Jun 07, 2015 | Shark Steam Mop S3202 Floor Cleaner
Steam cleaner sc20
It works like a squirt gun, submerge complete unit into water to add water. After it fills pull out and ready to use.
Jul 28, 2014 | Conair SC20 Handheld Steam Cleaner
I have a Euro Pro model #EP-901 steam cleaner I need the manual for
Could not find it listed under Euro Pro, it may be the same as a Shark model as they are the same company.
Does this look like the same model, but different color?
http://preview.tinyurl.com/SHARK-3901-steam-mop
If so the customer support number is near the top of the page on the right side.
Nov 13, 2013 | Euro-Pro EP901 Vacuum
Have shark steam cleaner. Brown sticky smelly water started coming out after using 5 or 6 times. Nothing has been added to water.
add some white vinegar in the water let it boil them empty and repeat about 3 times , when you finished using it always make sure you empty it..
Aug 17, 2013 | Euro-Pro Ultra Steam SharkTM II Hard...
SteamVac Carpet/Upholstery Deep Cleaner Vacuum: how do i add the solution to the steam vac? how mu...
You didn't give a model number so I'll tell you both methods. The F5xxx and F6xxx models have a cap at the top of the clean water tank that doubles as a measuring cup. The cap is about 3 inches in diameter. Fill the cap to the fill line with shampoo and dump it in the tank. Then fill the tank with hot (Not Boiling) water.
The F7xxx series has a 2 section tank. The large section is for hot (Not Boiling) water. The smaller section is for shampoo. Fill the smaller section with shampoo and the Steam Vac will mix the water and shampoo for you in the proper proportion.
May 16, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Euro-Pro EP901 Vacuum Logo
12 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
