Question about Electrolux EW1000i Front Load Washer
Front load washer will not spin fast
It spins slowly alternating between directions
4 Suggested Answers
  • 117 Answers
SOURCE: Stops at spin cycle
Open the lid to the washer and let it down gently. You should hear a click when the lid closes. If you don't hear it, the lid switch might be faulty and this will prevent the washer from going into spin. Not an expensive repair.
http://tclaundryrepair.com/
Posted on Feb 20, 2009
ZJLimited
  • 17970 Answers
SOURCE: Electrolux front load washer door won't
First try to reset the lock unplugged the power machine for a few (10) minutes (maybe release the interlock door switch). If this work, them its possible that you need door latch replacement.
To do it, turn off power, unplug at the mains. Drag the machine out so you can see the back. Remove the 2 screws that hold the top on, pull back or tap the top forward (depending on the model) to unclip it. Peer inside. You will see the door switch inside the chassis exactly in line with the door handle on the outside. See if you manually make the mechanism release, or if you have a stubby philips screwdriver, you can probably unscrew the switch complely.
Keep us updated.
Posted on Aug 18, 2011
richroth
  • 9472 Answers
SOURCE: electrolux front load washer model GLTF2940FS1 doesnt spin good & makes a rubbing sound
open the cabinet and check for a broken shock. Here is the part in case you find it bad.
Posted on Nov 06, 2012
My electrolux front load washer model number, EWFLW65HIWO, gets to the spin cycle and spins slowly. At minute 4, it stops, never entering the super fast spinning. However, if I put the washer on the Spin...
Sounds like the timer and control board are not communicating correctly and efficiently when in a normal cycle. You would need a professional to diagnose the control board and see if that is the only part needing replacement.
Dec 26, 2012 | Washing Machines
Washer is not spinning fast - so the clothes are more wet when done
sounds like washer is load sensing either overloaded or unbalanced when it decides to low spin insteasd of high spin dose it stop for second rotate 3 times and change direction 3 times the just spin slow.... if so either u have misloaded the machine by overloading orthe clothes are unbalanced in load may need add a towel or something to balance the weight evenly in the tub
Jan 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Will not spin during spin portion of cycles. it rotates slowly cw and ccw but no fast spin
It's either a bad door switch, or motor control board. Definitely easier and cheaper to try changint he door switch first, as it fails much more often. Part number is 131763202
Apr 06, 2010 | Frigidaire Affinity ATF7000E Front Load...
Epic washer doesn't spin fast. spins, but slowly. clothes coming out wet, very wet. it started after i washed a heavy wool sweater.
Check the filter, make sure rinse hold is not on, check the drain hose is not blocked, lastly check the brushes, remmember unplug first.
Sep 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
Kenmore washer weak agitate even at fast load and no spin
It could need a new belt. If there is damage on the belt it may also be dirty or stretched and thereby slipping and not giving you it's best performance.
Aug 01, 2017 | Kenmore 43142 Front Load Washer
Front load drive motor on Kenmore washer will only turn the drum in a counter clockwise direction an there is no fast spin
you could have choosen the gentle care mode or delicate mode where in it would only run in one direction and would spin slowly.
tnx 4 using fixya,
drcool
Jul 28, 2008 | Whirlpool Washing Machines
Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Jan 26, 2008 | Kenmore 44102 Front Load Washer
Electrolux EW1000i Front Load Washer Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
