Question about LG LTM9000 Microwave Oven
Hang E - 10 - LG LTM9000 Microwave Oven
The door on my GE advantium 120 fell off and I need to reattach it
take off the top vent cover , should be three screws ...hang the door provided nothing is broken off the door or the microwave.. after hanging put the vent cover back on. If your model has a little clip/postage size at the top hinge or if you think there is something missing at that location you may need that to keep the door from coming back off... It can be bought on line if your model needs it. some do and some don't if you found something near that area before the door fell off... then your model had one..
Nov 06, 2011 | GE Advantium 120 Convection/Microwave Oven
I have a GE Profile JVM1790 microwave that needs to be installed. However, it will sit in front of a 3/4" thick granite backsplash that I would rather not drill holes through. Would it be safe to mount...
The front weight hangs from the cabinet above the microwave, the rear weight needs support also. It is intended to be fastened to two studs. If the granite does not go all the way up to the cabinet above, install a wood spacer, the same thickness as the granite, then extend the wall plate, at the corners, with some flat stock aluminum strips, available at most hardware stores. Fasten the aluminum strips to to wall plate with short machine screws. - If the granite goes up to the cabinet bottom, shim out the bottom frame of the cabinet to the face of the granite and use the same aluminum flat stock to extend the wall plate up to the necessary location.
Jul 06, 2009 | Microwave Ovens
My handy man hung my micro wave by putting a screw through the cuboard throught the side of my micro wave is that safe
Yes, as long as it did not come into contact with any internal parts or wires.
Jun 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a 1.5 over the range fridgidaire microwave...it seems the door hangs a little low because in order for it to work you have to put your thumb on the bottom of the door to raise it up a little and...
Does it seem to hang low or does it actually hang low? Readjust it. There is a switch that may hang high when the door closes. You just have look at what does what and what ain' doing what it is supposed to. first.
May 04, 2009 | Frigidaire Over-the-Range Microwave
I need the little cardboard piece that hangs on the top of the microwave for my Emerson. Where can I get this that fits there?
Take a piece of cardboard and cut one out. You probably won't be able to find what you're looking for.
Jan 19, 2009 | Microwave Ovens
Samsung otr microwave vent problem
Please call Samsung's Service Division at 800-932-3837.
If they cannot help you, they should be able to give you another number to call.
Oct 23, 2008 | Samsung 1.8 Cu. Ft. Over-the-Range...
No power
Simply use Safety. Unplug. Use Continuity Buzzer, Meter ( With Continuity Tone ). Can Use Meter if You Have & Watch, Check By AC Power Cord Fuse. Use a 500 Ohm to 5000 ohm Resistor on two Insulated clip leads with screwdrivers and Find the Hi-Voltage Capacitor ( Large Metal with Leads and a Diode on it. Short the Condenser from one side to another to BLEED any Voltage left Charged in the Condenser. Newer Microwaves have a Bleeder Resistor 10 MegOhms Built in. But Just do this for Backup/Sure Safety. Will Probally Just find a Blown 15-20 amp fuse ( Electrical Surge ). Any one of the 3 Door switches that DONT open-Close Smoothly Will Blow Fuse. ( Intermittent, Burnt, Skipping, Hanging up ). A Shorted Hi-Voltage Capacitor or Diode Will Blow Fuse. Open in Series Protection device may have opened because of Overload or Surge. These are Metal and loop in-Out AC Line and are Mounted ( Heat Sinked to Metal case ).
Aug 15, 2008 | Microwave Ovens
Microwave installation under cabinet, no rear wall
Your model weighs 41 pounds empty.
That - plus maybe adding another 8-10 pounds for safety - us what your installation needs to be able to handle.
I would think the average cabinet could handle that, but it may be better to add a small steel plate or large washer surrounding the mounting screws to help disperse the weight load.
The owner's manual describes the installation kit you can use to mount it in a cabinet or in the wall, etc. That may be helpful.
If you don't still have your manual you can download it here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 17, 2008 | Sharp R-408HS Microwave Oven
Hi , I would like to suggest to visit near appliance center to purchase hanging for oven . ace hardwares.
Jan 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Amana Radarange Microwave/Convection over the stove
what is the model number of your radarange? it should be found inside the microwave on the rim.
Nov 21, 2007 | Microwave Ovens
LG LTM9000 Microwave Oven Logo
23 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Devabhakthuni...
Devabhakthuni...
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
