Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
I think the bulb blew out on my tv,and i heard this could be from a dirty fan not cooling off the bulb. is this true?
I just wanted to know where the fan is so i can clean it
  • 110 Answers
Pull the back off you will see it.
Posted on May 22, 2009
My Sony KDF50E-2000, the projection light went out, i replaced it, it was working, then the replacement light went out too. Is this something with the TV or do I need to buy another light?
There are a few common causes for rapid bulb failure. If you touched the replacement bulb with your bare skin, oils on your skin will cause hot spots on the glass and can cause quick failure. Also, there are cooling fans that provide cooling for the bulb. If these are not working, bulb failure will occur.
Nov 19, 2015 | Sony KDF-E502000 50" HDTV
Just clicks want come on
there is a few things that can cause that 1 the bulb blew 2 the cooling fan quit or 3 the hitemp sensor for the bulb is bad sometimes its cheaper to replace a rear projector tv then to repair a bulb on some models can run $600.00
Aug 23, 2013 | Toshiba 50A62 50" Rear Projection...
Fan broken mitsubishi wd 60737 want to repair replace
Fan should be easy to replace try Encompass Parts Look on their website or try Mats Electronics for replacement fan.
Oct 08, 2012 | Mitsubishi WD-60737 TV
My picture will not come on. The display lights on the front are blinking in rotation. i pulled the lamp out and it appears to have burned out as there are glass pieces inside the casing. How can I...
Replace the bulb to clear the error state.
If the cooling fan isn't working at this point, power the unit down, and you will at that point know whether the cooling fan was the issue or not.
If the fan is working, then the bulb probably just blew due to age.
Feb 24, 2011 | Hitachi 50VS810 50" Rear Projection HDTV
Ok ok I am trying to find a cooling fan for the bulb but cant find one on line can someone help send me to a site that will have this bulb cooling fan? and how can i tell if the fan is the true issue
Howdy,
The part numbers for the (2) Lamp fans are: UX21521 (upper) and GS00506 (side). You can obtain these from 1-800-448-2244 at
Hitachi America, Ltd. Digital Media Division
900 Hitachi Way
Chula Vista, CA. 91914-3556
BUT, I do not think this is your concern. It is possible but I have not seen a fan on this Model go bad yet. So, give more information so the TV can be trouble shot better.
Godd Luck, Big Irish.
Dec 02, 2009 | Hitachi 60V500 60" Rear Projection...
I have a KDF 42WE655..while watching tv, I heard a popping sound.
If the lamp is blowing that soon, the cooling fan is not working, or is plugged with dust. I have heard some people have a filter that needs changing or cleaning. Check your manual. The cooling fan is on the optical block and not easy to get to.
Probably a job for a tech.
Aug 18, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Bulb went out
This maybe a McGuyver thing. Last thing you want to do is block the air flow to cool down your TV set. I would blow out all the dust, get a HEPA filter for house ventilation, get a computer cooling fan. Cut and put the filter in front of the fan, make the fan blow in to the TV vent in the back, that way it blows clean air in and keeps dirty air out. I hope that's one good idea.
Jan 24, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
42 inch LG Plasma TV - Lost picture
Hi , I recently had the same problem which I was determined to fix . So I did a few weeks of research to find that it was the Y SUS board which burns out. I'm sure you realized that the TV gets hot. Personally I think this is why. circuit boards don't like heat and I've learned that the cooling fans are a joke. I replaced the board and got my picture back. I proved the fan theory because after the screen started to act up. I placed a cooling fan near the vent holes on top and the problem cleared right up,It also helps if you lower the brightness which helps out on the heat situation.I will soon be adding a fan with a temp. sensor. This shoud help if your screen has lines when you initially turn the cool TV on.then I have Some other costless solutions. Hope this helped these are great TV's and like our cars we maintain them not throw them away..................................Mr Wiseman
Sep 16, 2008 | LG 50PX1D 50 in. Plasma Television
Sanyo Television PLV-55WHD1
i heard same popping sound and my power button flashed red and will not turn back on.?
Sep 15, 2008 | Sanyo PLV-55WM1 55" HDTV-Ready LCD TV
Recentley my tv just turned off. I heard a buzzing sound which happened the 1st time my bulb went out. So I ordered a new one. When the new one was put in it worked for 5 minutes then turned off and...
This could be a couple of things. Look at the cooling fan and be sure that it can spin freely. If it is stuck, the buzzing could be the motor trying to spin the fan. Other than that, the ballast could be failing as well. This is the part that "fires" the lamp. Examine the fan first and let mw know what happens.
Dan
Jul 22, 2008 | Televison & Video
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
143 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
