Question about Konica Minolta Minolta DI1610FP Multifunction 200 x 400 dpi resolution, 33.6 Kbps modem speed, scan and fax functio... Printer
Getting dark lines on copies, how can I clean it?
  • Konica Minolta Master
  • 6,696 Answers
Replace the fuser unit and or the image unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 04, 2016
2 Suggested Answers
Nitrotrike
  • 589 Answers
SOURCE: Konica Minolta 7022- How to clean- Getting Dark Lines on Copies
Beings as it is close to 100k, it is due for a PM (preventative maintenance) kit to be installed (this model has a 100k PM cycle), and also a web, corona wires, charge grid, and feed rollers (if worn) should be replaced at this point, and of course cleaned.
The drum and developer "should" last 200k (this can vary greatly).
$200 for a general cleaning on that series machine... that's entirely too much, and he will most likely tell you it's due for a PM. A competent technician would be able to install the kit, replace the above parts in under 2 hours easily.
I wish I could be of more help, but given that is almost at the end of its PM cycle, it could be anything.
Posted on Feb 12, 2008
We were getting streaky lines, it also ask us to replace the durm which we did. Streaks have not gone away
Are you getting these lines when copying? Or Printing?
Or both. Are these dark lines or blank lines?
If it is just when copying, try making a copy by laying an original on the glass rather than using the feeder. If this copy comes out clean then you need to clean the ADF (Automatic Document Feeder) scanner glass. Just open the section where the documents are fed into and you will see a strip of glass that runs from front to back, about an inch wide. Clean this with a soft cloth and a bit of glass cleaner.
If this works then great. If not then reply back with more details and I will help you further.
Jun 09, 2010 | Ricoh Aficio 1515 Black and White Copier
Initially getting a few horizontal dark lines on copied page, now beginning to get longitudinal lines as well. Not sure where to start..
Lines that are thin are usually caused by white out or ink or just dust on the exposure thin **** glass, clean it with alcohol or windex. Other lines could be caused by dirty charge units, there should be a rod you can slide out and in when you open the front door to clean that. If the hot fuser rollers are damaged that also can cause dark lines
Mar 23, 2010 | Sharp AL 1631 Copier
Fault code J50 & dark strip.
This is for a Mita 1560 Photocopier (analog)
J50 was caused by exit sensor not sitting correctly in its bracket,I fixed this by pushing it until it
clicked back in.
The dark lines & double imaging can be caused light getting onto the drum ,or if the drum gets
cold (so I have been advised) which one it was for sure I will never know because when I
returned the next day & fixed the exit sensor the copy was OK.
May 18, 2009 | Office Equipment & Supplies
Dark lines on edges of copies
make a copy when you here the paper getting picked up count 2 seconds and open front cover or side stopping the process open the copier and see if the dark line is on your drum or transfer is the problem
Nov 23, 2008 | Sharp AL-1642CS Copier
I have a dark line across copies
Whats the make and model of the copier?
One culprit might be the drum.  If you can take a look at the drum from your copier and you see black lines on it.  It could be scratches on the drum or it may need a new cleaning blade to clean the toner off the drum.
Nov 11, 2008 | Office Equipment & Supplies
Dark line
If the line is not on your recived faxes then you need to clean the area the paper passes over when sending. any marks could cause this.
Mar 19, 2008 | Brother IntelliFAX 2600 Fax
Copies here and recipients faxes: dark, lined
How long has the drum been in there?
try this:
1-take out toner, look and see if it is ok. do you see stripes on it?
2- look at the drum are there any black rings on it? ( you did not specify white or black lines)
3- where the glass is on the opposite side ( the part you lifted to clean the glass, look at it standing from the back. you will see a white metal plate with some springs in it if you touch it. this is the reference that the fax has if there is/are a black dot on it it will give you a black line clean carefully. if it is scratched use white out to cover and make white again.
For the darkness try making a copy in photo mode if it is still too dark change drum.
Dec 07, 2007 | Canon FAXPHONE B640 Plain Paper Bubblejet
Installed new drum
dark lines is probably caused by the thin glass of the copier. test by making copy on glass, does it have lines? if no look carefully at the small 1" glass there is probably some ink dots or white out or something on it, clean with alcohol and try.
fish scales uniformly are coming from the fuser, ( where it gets hot as its coming out) check.You already changed drum which was a posssibility.
Also check the toner and see if it is solid black.
Dec 03, 2007 | Sharp AL-1655CS Copier
Dark Copies
Jim, A couple of things: 1. OEM (Canon original) toner cartridge or remanufactured/compatible? The first place to start is always with the toner cartridge when image problems occur. Pull the cartridge out and draw back the drum cover. Check to see if the drum is a nice "clean" blue color or if the lines and spots are on it like you described. (These two areas should be handled by someone with experience in copy service) 2. The next thing would involved cleaning under the copy glass. Build up from dust, etc causes a "fogginess" that makes the machine try to adjust the intensity of the exposure lamp to conpensate for this. 3. Also could be a bad upper fuser roller if you started having any paper jams when to paper exits.
Jul 18, 2007 | Canon imageCLASS D320 Digital Copier
Konica Minolta Minolta DI1610FP Multifunction 200 x 400 dpi resolution, 33.6 Kbps modem speed, scan and fax functio... Printer Logo
16 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
