Question about Dishwashers
Reset zanussi dishwasher
Doesn't use hot water
4 Suggested Answers
SOURCE: Zanussi dishwasher water input
it is possible but if you use a hot fill you will find that the rinse aid will produce a large amount of foam and the dishes wont dry properly
Posted on Jan 15, 2008
  • 10 Answers
SOURCE: zanussi ls9
write to me if you need the manual.as for the soap the dishwasher uses only liquid professional soap and you must connect it inside the tank . there is also a blue pipe for the rinse aid detergent
let me know if you need anything else
Posted on Dec 15, 2008
MNfisherman
  • 11896 Answers
SOURCE: dishwasher-zanussi/electrolux goes through full cycle
Check to see if the water valve is opening. The valve connects the external hoses to internal ones. The hot water valve may eitherbe bad or not getting any power to it which you could test with a voltmeter if you wanted to. Make sure both valves on your house water lines are fully open. You can remove the rear panel of the machine to access the valves.
Posted on Oct 15, 2010
Washes but water does not heat up and dishes cold
The dishwasher does not heat up the water. The water should be hot coming into the dishwasher, check your hot water supply source, whether it be the hot water tank or be sure the water inlet for the dishwasher is not connected to the cold water line
Jan 09, 2011 | Zanussi Dishwashers
DA6141....DOES IT HEAT THE WATER? CAN ONLY SEE A HOT WATER INLET PIPE TO THE REAR....
Your dishwasher uses your hot water to wash the dishes.
Attach your hot water to both the sink and dishwasher at that (hot water) inlet.
Run the hot water in your sink until it is very hot, then turn on your dishwasher.
MY DISHWASHER IS NOT GETTING HOT
If it used to get hot then I would check your water heater then the hot water supply connection to the dishwasher
Jun 21, 2010 | Zanussi 24 in. ZSF6160 Free-standing...
Water not getting hot
Start checking the element. (assuming you have a tester).If reading is good,(approx. 20-40 ohms).then check for a reset switch. Normall a red push to resed button or if there is continuity.. From there it can only be the board which outputs the heater voltage.
Sep 19, 2009 | Zanussi 24 in. DE6850 Free-standing...
Hi there I have a Zanussi zdf121 dishwasher which is only doing a cold wash, not heating at all. Not sure if its hot fill but the hot water is fine elsewhere. Any ideas please Pete
Do you have it hooked up to hot or cold water supply? Most residential dishwashers don't come equipped with a booster heater. If it's connected to the cold side, you'll have to replace the angle stop with a single outlet stop and replace the hot angle stop with a double outlet stop. This should help out, if not, make sure you have hot water in the faucet before starting the dishwasher. Most dishwashers need at least 120 degree hot water supply.
Mar 02, 2009 | Zanussi 18 in. DA4342 Free-standing...
Is my zanussi aquapulse de 4744 dw hot or cold water fed ?
It is more than likely hot water fed. You can trace the line probably to under your kitchen sink and see where the line follows up to your hot/cold on your sink. There would be then another line coming off the hot which would lead to your dishwasher.
Jan 17, 2009 | Zanussi 18 in. DE4744 Free-standing...
My dishwasher works but is taking a long time to finish the cycle it is a zanussi DA 6373
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Nov 12, 2008 | Zanussi Dishwashers
Dec 22, 2007 | Zanussi 24 in. ZSF6120 Free-standing...
Zanussi LS9 Dishwash error message
c3 means that the temperature of the water inside the tank is higher than 60 degrees celcious.may be you have already connect the dishwasher with to much hot water or the rele inside the pcb is stuck.
waiting for answer
Nov 16, 2007 | Zanussi 29 in. LS14 Free-standing...
Dishwashers Logo
47 people viewed this question
Top Dishwashers Experts
Owen Barnes
