Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan oiler don't work
My almost new Poulan"s oiler quit working. I washed out the oil res with gas, no help.
  • doc_d_58 May 22, 2009
    poulan pro 260 18"/45cm auto oiler stoped working
  • Dwain Pippen May 11, 2010
    What is the modle # of your saw? Should be on the side covers, like 2375, 2550..etc
    Problem Solver:
  • 17 Answers
Common problem with Poulan and Craftsman gas saws. Take off the chain and chain guide and clean out all the saw dust etc. Start saw without chain and look for port where there are signs of oil. If port is clear of sawdust, then it is likely the pump which is located behind the chain break assembly. you can get the diagram on Poulan website and the replacement pump will cost about $15 - $20 to replace yours.
Posted on May 26, 2009
Got a 2375 poulan with a tube that fell out of oiler now oil leaks all over
Posted on Aug 02, 2009
Poulan pro troubleshooting
CHAIN STRETCHS AS IT HEATS - KEEP CHAIN TIGHTENED CORRECTLY AND ALWAYS KEEP OIL IN OILER AND MAKE SURE IT OILS THE CHAIN. IF THIS DOESN'T FIX - REPLACE THE CHAIN. IF IT STILL HAPPENS THEN REPLACE BAR. WILL FAIL AGAIN WITHOUT OIL. POULAN WILL NOT HOLD UP WITHOUT CHAIN LUBRICATION. WORSE THAN OTHERS. IF CHAIN OR BAR OVERHEATED YOU'LL WORK ON IT MORE THAN YOU CUT. OIL IS THE KEY TO CUT WITH A POULAN!
Aug 10, 2014 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
Poulan Wild Thing bar oiler adjustment
there is no adjustment for the oil flow i find the screws that hold the pump on loosen up and then leak oil
Jun 09, 2012 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Brand new poulan pro 4620avx--bar oil is coming out of oiler but not getting onto chain
Hello. Thin your bar oil just a wee bit with some kerosene. If you have a gallon of bar oil add 1/4 cup of kerosene, stir it up and you will be fine. For starters also, directly apply some bar oil to the chain so that you are always using a well lubed chain. Joe
Oct 03, 2010 | Poulan Pro Chain Saw 46cc 20"
My poulan Wood Shark mod.1950- Dosen't seem to be oiling.I've cleaned everything you can clean and I can't find the oiler adjustment.Is there one?
A link to a Poulan "1950 Gas Saw Type 7" can be found below, (I did not see an oiler adjustment screw) follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/1950-Gas-Saw-Type-7/75.1950-Gas-Saw-Type-7.1.59.1.html
The IPL (exploded parts list) for your saw is the only detail for the Oil system and is sketchy at best. Oiler components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
Poulan.com (all models)
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 02, 2010 | Garden
I have a husqvarna 235, my oiler has quit working. I pulled the clutch assembly & cleaner the oiler gear but still no oil, resavoir is full
If you spin the oiler with the when it is desmantled does any oil come threw? (if so then the drum may not be linking to the oiler properly) also check the screw that determins how much oil is coming threw is turned up. And check the filter in the bottom of the oil tank is not blocked
  • Open in Google Docs Viewer
  • Open link in new tab
  • Open link in new window
  • Download file
  • Copy link address
hope this helps a bit
Apr 21, 2010 | Husqvarna Forest & Garden #952802239 235E...
Poulan 2300 Firewood chain doesn't oil
She is long of tooth. Some oiler parts are NLA. Item 17 on the "Power Unit" print is the actual oil pump. Do not mistreat it; do not blow it out with air; they are no longer available.
http://www.ordertree.com/modelinfo/PWE/2300AV-Gas-Saw/75.2300AV-Gas-Saw.1.59.1.html
Please see this thread, post 5
http://www.arboristsite.com/showthread.php?t=120981&highlight=poulan+xxv+oiler
The *.pdf is your oiler. I suggest you read the entire thread. and save the *.pdf to your hard drive. HTH
Lou
Feb 10, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
The automatic bar oiler isn't working. What
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear. Please see the IPL to aid in oiler component identification.
Example IPL Poulan 2375LE Gas Saw Type 2 (may not be your saw)
http://www.ordertree.com/modelinfo/PWE/2375LE-Gas-Saw-Type-2/75.2375LE-Gas-Saw-Type-2.1.59.1.html
Oiler components are on the "Handle, Chassis & Bar Assembly" print.
It has an outboarb clutch if necessary use this as a guide for removal. I think you need the special tool (Google Search):
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If the example is not your saw it can be found here:
Poulan.com
If You have more questions or need more help reply below and I will get back to you. HTH
Lou
Feb 07, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan 306A, chain keeps tighting up during use
Have you checked the oiler? If not oiling what you report is the outcome. You can post back below.
Oiler detail can be found on the "Handlebar & Oil Tank Assembly" page here:
http://www.ordertree.com/modelinfo/PWE/306A-Gas-Chain-Saw/75.306A-Gas-Chain-Saw.1.59.1.html
If I can be of more assistance please reply below. I hope you found this helpful.
Lou
Jan 19, 2010 | Poulan Garden
The auto oiler for the chain is not working, what should i look for
Hi
try this steps and proceed from one to the next :
1. make sure you filled oil
2. clean the chain oil container with gasoline
3. try thinner oil
Jul 16, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
1,460 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
