Question about Refrigerators
Frezer temp fluctuates from 5-degrees and 30 degrees. I replaced the timer that regulates the defrost cycles but it still same fluctualtion? what can the peoblem be# Amana mod# SZD20KL S/N 8910111816
  • Dennis Boxerman May 11, 2010
    If it fluxuates regularly, the problem is most likely the t'stat, or temp control. I would look there first.
  • tonyw514
    tonyw514 May 11, 2010
    when did the problem start and is it inside or in a garage/outside ?
  • Refrigerators Master
  • 4,655 Answers
There can be several reasons for that problem. Condenser fan not working properly, dust and obstruction in ventilation below the refrigerator, defrost element is bad, defrost thermostat defective or low on freon. Check the area under fridge for good air movement and look at the evaporator coils during the time of day the freezer is not cooling its best. If frosted over I think its inside where the element and defrost thermostat. If evaporator coils have some rows on botton frozen over with ice and top is sweaty then its a freon leak. Let me know and make sure you have it unplugged while working on the refrigerator, Thanks, Sea Breeze
Posted on May 23, 2009
Frigidaire freezer runs a lot. Located in garage. In summer runs almost non-stop. Currently outside temps are below 0 deg F and freezer still cyles frequently. Have replace the freezer tstat. Defrost...
Yup, these timers have a tiny clock motor that can get lint on them, causing motor failure, should be simple replacement. Refrigerators in cold garages run more to regulate their temperature below 45 degrees.
Jan 29, 2014 | Freezers
Tip
Freezer working but no cool in Fridge/No Ice making
This is one of the common problem throughout the world. It's because of not going through User Manual before using the fridge. <br /><br />To get better cooling, dispensing water, ice cubes from your refrigerator, please follow the steps. <br />1. Keep temp setting between 3 degree and 5 degree Centigrade.<br />2. Ensure, freezer door and mail door of Refrigerator are closed properly.<br />3. Check freezer fan is working. If struck by frosting behind the freezer, you have to defrost it.<br />4. Defrost cycling is not functioning properly. Because your set temp is less than 3 degree or in minus.<br />5. Auto defrost cycle not activated due to thermostat, timer, heater malfunction. <br />First, locate the defrost timer which may hiddenbehind corners of the fridge at the back bottom, in some models located in theceiling of the fresh food section or behind the cold control cover. Once youlocate the defrost timer, slowly turn the screw in the middle of the defrosttimer with straight screwdriver until the fridge shuts off. Now it's indefrost. If the defrost heater(s) starts, replace the defrost timer and defrostthermostat. If the heater(s) does not start, unplug wire cord to check ohm testfor continuity of heater. If continuity is there, plug cord wire which givespower 120volts (check specification) to heater. If heater no starts, bypassdefrost thermostat by join the 2 wires in the defrost thermostat. If the heaternow comes on, replace the defrost timer and defrost thermostat. If the heateritself is bad, replace it<br />6. Check water line to make ice are not tint or remove kinks in water source line in the back of refrigerator to increase water pressure.<br />7. Check solenoid valve in the rear side of refrigerator back is activated. <br />8. If solenoid activated,no water flow means, have to clean solenoid valve. <br />9. Check shut off arm is not struck due to over ice stores in the ice bucket. Remove it.
on Feb 07, 2011 | Refrigerators
Defrost cycles
Defrost cycle usually comes on after about 7 hours. If it is happening every 30 minutes or so, the defrost timer is not working properly and your internal temperature will never have a chance to go down to zero as SOP.
When defrost cycle comes on, the compressor is automatically shut off and internal freezer temps can go up by close to 25 degrees or more. It is for this reason that commercial freezers do not have auto defrost - the latter extols a price, convenience at the price of higher average temps and less time to properly store foodstuffs in freezer.
Nov 20, 2013 | Freezers
Frezer works but fridge does not get cold
If refrigerator is not cooling properly, it can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer goes bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
I hope the above helps.......
Good luck.
Mar 22, 2011 | Frigidaire Refrigerators
Freezer defrost cycle
If the defrost timer sticks in the defrost mode,yes. Normal defrost time is 30 minutes or less depending upon which timer is installed.
If it happens again,locate the defrost timer and turn the dial manually to see if the compressor comes back on. If so,replace the timer.
It is probably on the rear near the compressor. Some are under the front behind the dust guard.
Feb 24, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
Do the kenmore refridgerators have a daily defrost cycle? If so, how long does it last and what is the temperature fluctuation? The freezer is empty right now, and the temperature fluctuation seem to go...
All refrigeration products have a defrost set point. Most residential units defrost about every six to eighteen hours. This process should take about 30 minutes to 1 hour. The temp goes up so high inside because there is a heating element in the coils to thaw any residual ice. The temp should not exceed about 45 degrees though. If it does the the compressor is signaled to come back on and start cooling again. This is perfectly alright. The time at higher temp is not enough to spoil the food. Hope this helps. Good luck.
Nov 18, 2009 | Kenmore Refrigerators
Freezer temperature went from 0 to 20 degrees farenheit and holding.I had the digital readout, alarm, and temp. setting go out 1 year ago and replaced with inside temp. guage. I have a warrnty on the...
If this is a self defrosting freeze,then it is normal to periodically see an elevated reading during a defrost cycle. At 20 degrees, it was probably ready to complete its defrost cycle and come back on to return it to your cold setting.
Dec 25, 2017 | Kenmore Freezers
Temp changes in freezer
If the temperature fluctuations occur (at least the ones to 20-30 degrees) at intervals of 6 hours or so then you are catching it in it's defrost mode which occurs on a timer. The timer shuts off everything except lights every 6 hours for an average of 20 minutes. This usually isn't enough to thaw things but I have seen it cause some crystale. Look closely at the back inside wall of the freezer for an accumulation of frost. If you see it there then you may have a defrost problem. Usually this is accompanied by steadily rising temperature in the freezer and fresh food secions both. The temps you listed (0to10) are fine. Good luck, AJ
May 22, 2009 | Freezers
Frezer fluctuating fron 05 to 35 degrees
HI, this is a failing thermostat(cold control). simply replacing the thermostat will fix this issue dealing with the temp fluctuations.
May 22, 2009 | Refrigerators
Our model is MCBR 415S. The top freezer acts as
You most likely have a bad thermostat control or a bad defrost timer.
Locate the defrost timer, probably inside the temp control panel.Defrost cycles should last 30 minutes then resume freezing.
Manually turn the timer control a 1/4 turn and see if it starts.
If so, replace the defrost control.
It could also be a bad temp control.
If the timer adjustment does not start the fridge. Tap the temp control. It may have stuck contacts.
Mar 10, 2009 | Magic Chef Refrigerators
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
