Home | Printers | Hp psc 2100
Printers
Problem for Printers
Generic problem for all Printers
Hp psc 2100
By greg69 on Oct 19, 2007
the black ink cartridge will not function properly once installed
Same Problem
Jan 12, 2009
-   When I install a new black cartridge, I get an orange "check print cartridge" error message that tells me the cartridge is incorrect for the printer. It's not incorrect. I've tried cleaning, stopping and starting, plugging and unplugging. The same thing happened with my last black cartridge but it ultimately righted itself. This time it won't. -   ldormen
Dec 10, 2008
-   I find it very difficult to get the ink cartridges into the printer. Must I use a crowbar? What am I dooing wrong?
JOHN-   printacc
Sep 17, 2008
-   I have changed both ink cartidges with brand new hp ink 3 times and keep getting the message that ink supply is out and to change cartidges. I have unplugged, cleaned ink heads, held down the 6 and # as one person suggested, and released the latch head several times. Same message--sometimes it says black cartridge, sometimes color cartridge needs replacing.-   Libearian
May 29, 2008
-   Same problem. Mine error message is with the yellow cartridge. The one I previously had did the same thing with the magenta cartridge. Are these duds or what?-   cottonpatch1
Apr 22, 2008
-   Black ink cartridge says empty. I replaced with a new one. But it still says empty. Cleaned it 10 times....not to avail. It prints but not in black. What can I do? Throw it or buy a new one......not brother for sure.-   Guest
Solution #1
posted on Oct 19, 2007
Somewhat Helpful)
diespy
Rank: Wiz
Rating: 81%, 111 votes
Go further into detail. Is it giving you a "check and remove" error, or just not printing? If it is simply not printing, try heating some water up, dampening a paper towel and wiping the print head(*the bottom of the cartridge where the ink comes out) and pressing on the paper towel to get a "foot print".
   If it is giving you an error, then you might have to update online. The check and remove error can sometimes be solved with online critical updates. If it is telling you cartridge has failed, then the circuits are bad, and you should contact HP. Their cartridges have warranties too
Was this helpful?
Yes
No
Solution #2
posted on Apr 05, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Which sid does color go in this thing.
Popular Solutions for Printers
Questions and Unsolved Problems for Printers
Answer
which all in one printer is cheeper to uses
Answer
konika minolta 1600 magicolor
Answer
HP Deskjet 1280 is not printing on A3 paper ? how can i solve this problem
6 Other Users Have The Same Problem - Continued
Comment by sandera, posted on Jan 13, 2008
I reinstalled the color and black ink cartridge. now the carriage won't move. It's bumping but can't move???
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Printers:
Top Printer Experts
Rank: Guru Guru
Solutions: 712
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
