Question about v70 grommet. connector index cable terminals. insulators
I want to order an insulator - v70 grommet. connector index cable terminals. insulators
    Sergeant:
    Champion:
  • Volvo Expert
  • 496 Answers
Look up IPD USA online. They are based a short drive from where I live and they have good prices and great service.
Posted on Oct 23, 2015
I have a 2010 GMC Acadia that is having Ac problems. The Ac blows cold on the passenger side and the rear, but hot on the driver's side. Any ideas?
Temperature blend door actuator . There are electric motors behind the instrument panel that control air flow direction. GM calls it a Temperature Valve Actuator Replacement - Left Side
Instrument Panel Insulator Panel Replacement - Left Side (Acadia)
showgif.do?image=1853511
Callout
Component Name
Push-pin Fasteners (Qty: 3)
Insulator/Closeout Panel - Left
Procedure Disconnect the electrical connectors.
Caution: In order to avoid actuator damage, DO NOT apply power to the actuator when it is not installed in the HVAC module.
Preliminary Procedure Remove the instrument panel insulator - left side. Refer to Instrument Panel Insulator Panel Replacement - Left Side.
Left Temperature Actuator Screw (Qty: 3)
Caution: Refer to Fastener Caution in the Preface section.
Tighten
2 N?·m (18 lb in)
Procedure
  1. Disconnect the electrical connectors.
  2. Re-calibrate the right temperature actuator. Refer to Actuator Recalibration.
Sep 23, 2016 | 2010 GMC Acadia
Do you access the blower motor on an 04 bonneville from under the hood or passenger side behind the glove box?
passenger side under the glove box ,
Remove the right side sound insulator. Refer to Instrument Panel Insulator Panel Replacement - Right Side in Instrument Panel, Gages and Console.
Disconnect the electrical connector (1) from the blower motor.
Disconnect the blower ventilation tube (2) from the module.
Remove the blower motor screws (3).
Remove the blower motor from the housing.
Removal Procedure
Remove the fasteners at the rear edge of the insulators in order to disengage from the lower instrument panel.
Pry out the retainers in order to release.
Turn the heater temperature sensor 1/4 turn in order to release and allow to remain connected to its wire (CJ2 vehicles only).
Slide the insulator rearward in order to remove.
Sep 11, 2016 | 2004 Pontiac Bonneville
How to change ac blower on a 2001 chevy silverado with the 5.3 liter v8
With Delphi Blower Motor
  1. If equipped, remove the sound insulator panel.
  2. Remove the blower motor insulating cover screws.
  3. Disconnect the electrical connector from the blower motor.
  4. Remove the blower motor insulating cover.
  5. Pull the retaining tab down while turning the blower motor counterclockwise in order to disengage the blower motor from the heater/ventilation module.
  6. Remove the blower motor.
With Visteon Blower Motor
  1. Remove the sound insulator panel.
  2. Disconnect the electrical connector from the blower motor.
  3. Remove the screws from the blower motor.
  4. Remove the blower motor from the HVAC module.
  5. Remove the retainer from the blower motor wheel. Discard the retainer.
  6. Remove the blower motor wheel from the blower motor.
Jul 27, 2014 | 2001 Chevrolet Silverado
LIGHT BULB TOUCHING INSULATION IN OVEN
it won't hurt anything. The bulb is encased in insulation in order to prevent it from braking during a clean cycle.
May 20, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
How to replace temperature sensor in Whirlpool water heater
Whrilpool will send information.
Copy following link for resources, including images showing temperature sensor (thermister):
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
http://waterheatertimer.org/images/Whirlpool-energy-smart-part.jpg
Remove cover on outside of tank.
The foam insulation is very stout, and must be cut back to access sensor located above each element.
Insulation must be put back when finished.
After insulation is cut back, it appears you can remove the sensor... I am assuming the wiring can be unplugged, or spliced. It is not possible to replace wires that run between sensor and top of tank because the foam insulation is too tight and wiring is not inside a conduit.
Add a comment and say what you discover.
Apr 11, 2013 | Whirlpool Water Heaters
Unit will not heat plus there have been sparks at the supports for the trays
Trays are most likely insulated and have areas where the insulation has worn through exposing metal. Order correct microwave touch up paint and coat trays. As to it not heating that is most likely a magnetron tube and diode problem.
Nov 04, 2009 | GE XL1800 1100 Watts Microwave Oven
Looking for instructions or a diagram of how to install a new blower motor on 1999 chevy silverado
1 Disconnect the electrical connector from the blower resistor
2 Remove the blower motor insulating cover screws.
3 Disconnect the electrical connector from the blower motor
4 Remove the blower motor insulating cover.
5 Pull the retaining tab down while turning the blower motor counter-clockwise in order to disengage the blower motor from the heater/ventilation module (case)
6 Remove the blower motor. Install in reverse order.
Feb 18, 2009 | 1999 Chevrolet Silverado 1500
Need to replace the blower motor on my 2002 silverado
2002 silverado as follows :
1. if equipped , remove the sound insulator panel , remove the blower motor insulating cover screws , disconnect the electrical connector from the blower motor , remover the blower motor insulating cover , pull the retaining tab down while turning the blower motor counter clockwise in order to disengage the blower motor from the HVAC module , remove the blower motor .
2. to install blower motor , reverse the steps .
thanks for voting.
Dec 28, 2008 | 2001 Chevrolet Suburban
Blower motor
PART 1
If all blower speeds are not working I would check the blower, but if only one speed is not working I would check the resistor block for the blower it controls the speeds. they use 2 different blowers in this truck I have to sent a second message with the rest it will not hold it all inthis message.
2001–05 Models With Delphi Blower Motor
c93043c.jpgPull the retaining tab down while turning the blower motor counterclockwise in order to disengage the blower motor
To install:
  1. Install the blower motor.
  2. Install the blower motor to the heater/ventilation module. Turn the blower assembly clockwise until the retaining tab locks into place.
  3. Install the blower motor insulating cover.
  4. Connect the electrical connector to the blower motor.
  5. Install the blower motor insulating cover screws.
    1. Tighten the screws to 14 inch lbs. (1.6 Nm).
  6. If equipped, install the sound insulator panel
Nov 27, 2008 | 2004 Chevrolet Silverado
v70 grommet. connector index cable terminals. insulators Logo
23 people viewed this question
Top Volvo Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
bosy1
Are you a Volvo Vehicle Part and Accessory Expert? Answer questions, earn points and help others
