Question about Maytag Neptune MAH5500B Front Load Washer
Machine quit while filling up with water. all lights are blinkin
All the light s are glinking but nothing will happen,. we have tryed unplugging it, changin the setting, it allways reverte back to the original which I have never unsed. Nothing will happen. I have had this machine between 3 and 4 years WAAY to soon to have to replace.
thank you.
Patricia
Richards
864-895-4694 Home
346-5833 Cell
    President:
  • 2,923 Answers
There's a possibility that the motor control board is not functioning correctly. The motor control board receives 120 VAC voltage from the line cord and distributes DC voltage to the drive motor. The motor control converts the voltage from single phase to 3 phase for the drive motor.
You may need to check also the drive motor to see if there's a wax that you need to remove.
Here, I provided you the link where you can watch how to remove the wax motor:
http://images.google.com.ph/imgres?imgurl=http://shopimages.wikio.com/shop/img/l/YouTube/2007/09/04/D126/58b50f013a215ba894829d02b9233fb93b2b8dc91ddf225a8f5aa38d53171f28.jpg&imgrefurl=http://www.wikio.com/product/maytag-neptune-65034.html&usg=__bjJ1BMv2kxJr-o0s-86myVNa-6c=&h=95&w=130&sz=3&hl=tl&start=8&um=1&tbnid=Tyv634RoZOBUfM:&tbnh=67&tbnw=91&prev=/images%3Fq%3DNeptune%2BMAH5500B%2Bwon%2527t%2Bwork%26hl%3Dtl%26client%3Dfirefox-a%26channel%3Ds%26rls%3Dorg.mozilla:en-US:official%26sa%3DG%26um%3D1
NOTE: Check this link and you will see the media player. Click it and watch how to remove the wax motor.
I also provided you this link that will redirect you to the user guide of this machine:
http://www.scribd.com/doc/11205556/Maytag-Neptune-MAH3000AWW-Service-Manual
Have a great day!
Posted on May 22, 2009
Machine does not seem to be filling properly, then does nothing else.
Sounds like you're fill valves are junk which sadly happens allot. This video is very generic but should give you an idea
Jul 06, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
Hi, recently bought a bush a126q washing machine, worked perfectly fine after 2 washes. However, firstly the programme starter light doesn't stay on throughout the wash, is this a problem? Then the washing...
Sometimes things can get out of sync. Try unplugging the machine for a few hours to rest the code on the board. It's like rebooting your computer. I did this to mine and it cleared up the problem.
Oct 16, 2013 | Washing Machines
I started my machine, an hour later I went back and the machine still had water in it, and the cycle had not advanced. I tried to manually advance it but nothing happened. The power light is not on and...
Replacing the control panel should be the LAST thing you attempt!
Go back to basics first - does the machine empty when you turn it on? have you removed the water in the machine by lowering the waste hose onto the floor or removing the drain filter? do the program indicators light up?is water flowing through the fill hose / hoses? Are any fault codes showing? If you replaced the fuse, did it blow again? Have you any means of testing electrical Insulation / Earth continuity? Have you tried plugging something else into the washing machine socket - say a kettle or heater etc?
It well may be the Electrical Control Board in the end, BUT if you fit a new board onto a faulty part - say a blown heater - you will probably blow the new board as well, and the shop won't take it back for this reason.
Dec 04, 2017 | Asko WL6532XXL Washer
Plug in but does not heat up, no light on but
The thing just plain broke...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Mar 14, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My hotpoint wf540 will not start a cycle it very quicly steps to wash light showing but nothing happens door locked light is not illuminated.Just prior to this fault the fuse in the mains plug had blown.I...
1st you need to know if power is getting to machine, Next could be door interlock switch faulty the fact the fuse blew indicates possible short circuit/ excess current draw occured also check motor brushes assuming machine fills with water 1st
Nov 05, 2009 | Washing Machines
Me Estate washing machine, when started fills to specified water level then, it makes a buzzing noise then the buzz quits and nothing happens. Machine won't agitate or drain, just buzz then buzz quits.
sounds like you have a problem with your water supply to washer. the buzzing noise sounds like it's the valve opening to receive water but nothing going in. check supply hoses and water taps
Jul 14, 2009 | Washing Machines
Machine will not work and flashes 12 minutes
remove bottom cover look for tech sheet usually on right side of cabinet at bottom fh is usually a water fill issue drain may be siphoning water may be slow filling or bad flow meter flow meter may be harder to diagnois but try tapping lightly with screwdriver (it's the round object left side with 2 small hoses attached ) slim chance may be pressure switch left side rear corner
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer filled with water then stopped
Same problem- quick fix- to release door anyway. Found the service manual online...First unplug power cord and remove bottom front panel. Reach underneath on the right side of the machine- there will be a white round plastic disk that you can pull downward to release the door lock and remove your wet clothes. I found a pen lodged inside which may have caused the 'glitch'. When I ran it again it did the same thing and locked at the same place. The service guy had to replace the door lock mechanism to permanently fix the problem.
Apr 16, 2008 | Frigidaire GLTF2940ES Front Load Washer
Solis Palazzo - stuck in descale mode?
Are you refilling the tank during this process? You need to let in run dry, and then the buttons flash. Then, refill the tank with clean water, and let the tank run dry again.
Dec 11, 2007 | Bosch Benvenuto B30 Espresso/Coffee Maker
Maytag Neptune MAH5500B Front Load Washer Logo
21 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
