Question about Samsung WA400PJHDWR
Error code 3e samsung wa400pjhdwr - Samsung WA400PJHDWR
I have a samsung front loader WF7700N6W1 WHICH KEEPS COMING UPWITH THE ERROR CODE 3E IVE checked the drainage plug and cleared that but mavhine still not working.
The 3E error code to indicate a drive motor tach fault.
Here's a good website that discusses how to troubleshoot and possibly repair. (Could be as simple as unplugging the machine for a few minutes).
How To Fix 3E Error Code On Samsung Washing Machine
Here's an EXCELLENT YouTube video on removing the motor and replacing the brushes (if equipped).
Samsung Washing Machine 3E Error Code not spinning or turning
Jun 15, 2017 | Samsung Washing Machines
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
I need a Samsung Vrt steam manual. What does the error message 3E stand for on the, VRT Samsung Front Loader washing machine?
This video will help you diagnose the fault on Samsung Vrt steam 3e error codes and the video will help you solve the problem
Oct 24, 2015 | Samsung 3.9 Cu. Ft. VRT Steam and Power...
Samsung front loader washer Model: WF306LAW
The "3E" error code indicates that a high current is detected.
A "3E" error in a Samsung washer indicates that there is an issue with the motor. Restarting the cycle may clear the error, but a service technician should be consulted if the error code appears again.
Oct 17, 2012 | Washing Machines
Samsung Model WF220 won't spin after it fills with water. It displays Error code 3E.
This video will help you diagnose the fault on Samsung Model WF220 3e error codes and the video will help you solve the problem
Sep 08, 2012 | Washing Machines
Samsung error code 3E?
3E - MOTOR RESTRICTION ERROR
Hall Senior is sensed every 5OOms. 1 second after motor starts to work.
If data of hall sensor is less than 2 (2RPM), the Washing motor will stop at once.
During Washing and Rinsing when a motor restriction is sensed, the motor stops and then proceeds to the next water -flow action. If the motor stops working and this happens in one direction ten times, "3E" Error is displayed.
During dehydrating. when a motor restriction is sensed. the motor stops working and then returns to the initial stage of the dehydration unbalance sensing cycle. After ten times, "3E" Error is displayed, When the motor Is told to stop because of an operating function. no error is shown.
Power 81W OFF can clear the motor restriction error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 12, 2010 | Samsung WF328AAW Front Load Washer
Samsung WA400PJHDWR Logo
224 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
