Question about Anona Labs Image Processing Toolbox for Matlab
Getting an error while trying to set IPT Path about line 16...
Error: File: C:\Program Files\Anona Labs\IPT2\MFiles\SetIPTPath.m Line: 16 Column: 24 Expected a variable, function, or constant, found ")".
Trying to set the IPT Path for Anona Labs and getting an error
I think this Anona Labs is gone. There isn't even a web site for them. Have you tried just setting to the default path?
Jan 04, 2014 | Computers & Internet
I keep getting an error code when trying to install my software on my computer Error 1305.Error reading from the file C:\Program Files(x86)Punch! Home and Land Premium 16\Tutorials\tool7513\tool7513.mp4....
you have a missing mp4 file! this is a video file. just do a search on your computer for all "*.mp4" files with this same name and when found copy/paste into the location in your missing file message.
Aug 22, 2011 | Computers & Internet
Sorry javac is not recognize as internal or external command , operation program or batch file-- how can i solve that?? pls help me and where can i install j2sdk_18 lezarasileger@yahoo.com--facebook...
If you are getting that error, it means that eitherJava is not installed, or is not in your path.
If Java is not installed, go to http://www.java.com to install the most recent version of the JRE.
If you're sure you have already installed Java ensure the Java executable is in your system's path. You can do this by first finding the directory it is installed in. For example, mine is installed in C:Program FilesJavajre6. The executables are located in the bin directory.
In order to set your path (Assuming Windows Vista), go to Start -> Control Panel -> System, then click on the 'Advanced System Settings' link on the left, then the 'Environment Variables' button. In the lower section (Labeled 'System Variables'), scroll through and find the item labeled 'Path' and double click it. In the field labeled 'Variable value' go to the end and add a semicolon (;), and then the path your installation of Java is located. Using the example I gave above, I would have added ;C:Program FilesJavajre6in to the end of the line.
The procedure for 64-bit Windows Vista or Windows 7 is the same, except the text you will add to the Path variable is ";C:Program Files (x86)Javajre6in". Notice there is still a semi-colon at the beginning of the line.
Once you have done this, you will need to close and reopen the command prompt if it is already open, and you should be able to run java without getting this error message.
Jun 30, 2011 | Computers & Internet
Sc542 error for gestetner 4502
error 4502
http://support.microsoft.com/kb/258442
Instead, this error occurs: The problem does not occur when you add a column to the ... Server: Msg 4502, Level 16, State 1, Procedure myview, Line 1 View 'myview' has more ...
http://support.microsoft.com/kb/958876
file is deleted from the replication partners, and event 4412 and event 4502 are ... it tries to update these files after the service receives an ERROR_DISK_FULL error.
hope this helps
Mar 17, 2011 | Computers & Internet
Logged on and my email icon was missing as well as other icons. tried to start outlook and the message is simply cannot start outlook. cannot make google my home page as dell4me contiues to override any...
This issue may occur if you deploy Outlook 2003 with the Microsoft Office 2003 Custom Installation Wizard and specify a personal folder (.pst) file in the Windows Installer transform (MST file) by using the Default location for PST files path option. The problem occurs because you specify a file name instead of a folder path.
To resolve this issue for future installations of Office, use the Custom Installation Wizard to edit the MST file. To do this, follow these steps:
  1. On the Change Office User Settings page (page 10 of 24), expand Microsoft Outlook 2003, expand Miscellaneous, and then click PST Settings.
  2. In the right pane, double-click Default location for PST files, and then type the path that you want in the Default location for PST files box. For example, type %USERPROFILE%\Local Settings\Application Data\Microsoft\Outlook\.
  3. Click OK, and then follow the steps to complete the wizard. When you have corrected the MST file, deploy Office by using the correct MST file.
To resolve this issue for an existing installation of Outlook that is experiencing this problem, specify the .pst file by using the Mail icon in Control Panel.
Or If you are receiving and Err like
Error message when you start Outlook: "Unable to open the Outlook window," "No profile has been created," or "The list of Profiles cannot be loaded"Follow the step's below:This issue may occur on a computer that is running Windows XP if the Outlook.exe file was configured to open with the Windows program compatibility mode setting. When you set compatibility for Outlook to Windows 95 or to Windows 98/Windows Millennium Edition, Outlook displays this error message. This is because the location of the Outlook Profile information in the registry differs on a Windows XP-based computer.
To resolve this issue, follow these steps:
  1. Locate Outlook.exe.
    Outlook.exe is typically located in one of the following folders, depending on the version of Outlook that you are running:
    • Microsoft Office Outlook 2010 C:\Program Files\Microsoft Office\Office14
    • Microsoft Office Outlook 2007 C:\Program Files\Microsoft Office\Office12
    • Microsoft Office Outlook 2003 C:\Program Files\Microsoft Office\Office 11
    • Microsoft Outlook 2002 C:\Program Files\Microsoft Office\Office 10
    • Microsoft Outlook 2000 C:\Program Files\Microsoft Office\Office 9
  2. Right-click Outlook.exe, and then click Properties.
  3. On the Compatibility tab, click to clear the Run this program in compatibility mode for check box.
  4. Click OK.
  5. Try to start Outlook. If you receive error message again, use Method 2.
Regard's
Pcs365.8
Jun 16, 2010 | Microsoft Windows XP Home Edition
MadDog MD-16XDVD9 could not perform end of disc-at-once
Have you tried checking your basics ?
Firmware ?
ASPI ?
Disk Defrag ?
IDE location ?
Jumper settings ?
What type of media are you using ?
What programs are you using ?
Exactly where are you and what are you doing when your error occurs.
What are your PC's specs ?
Do you have any Roxio products installed on your PC ?
Please answer ALL of the above - if you don't know, say so, don't make something
Oct 20, 2009 | Computers & Internet
When installing MC9 on my Vista machine I get the following "Error 1904.Module C:Program Files (x86)MasterCook 9ProgramMCWrap.dll failed to register. HRESULT -2147220473. Contact your support personnel."
Are you installing as administrator?
you could try:
Start->run
and type in the following line
regsvr32 "C:Program Files (x86)MasterCook 9ProgramMCWrap.dll"
or wherever the .dll path was
then try reinsalling.
When I installed it, I right clicked on the install file, and clicked RUN AS ADMINISTRATOR.
Try reading this:
mc6help.tripod.com/mastercook_and_vista.htm
Sep 17, 2009 | ValuSoft MasterCook Deluxe 9.0: Windows
Sharp Actius AL27 strange DVD burning problem - The drive will burn a DVD+RW at 4x. A cheap (Imation) DVD+R burns OK, but a good 16X DVD+R (Verbatim) tries to burn at 2x and fails a few minutes in. This...
man it's not a condition that if the DVD Bulck writeen on it 16X that ur DVD writer will burn on this speed.
always don't try to burn ur DVD on maximum, always use the previous speed or the last previous one
ok good luck
Jun 17, 2009 | Sharp Actius AL27 Notebook
Invalid Path error
I get this error when trying to run Financial reports in Sage line 50 financial controller verson 10: C:\PROGRAM FILES\SAGE\ACCOUNTS\REPORTS\\*TB.SRT contains an invalid path No matter what financial report I try to access I get the same error including audit trail. My computer is window Vista. Please help me and also let me know how much is it cost for on line chat?
Thank you
from selvi
Apr 14, 2009 | Sage Instant Accounts 8.0 (013604ug)
Computers & Internet Logo
Top Anona Labs Computers & Internet Experts
David Payne
David Payne
Are you an Anona Labs Computer and Internet Expert? Answer questions, earn points and help others
