Question about Jeep 1998 Grand Cherokee Laredo
Passenger window fell into door while rolling it down
    Sergeant:
  • 406 Answers
You will need to remove the inside door panel and see why it dropped..some glass hangs up and cranking pulls the bottom rail off the glass or it may be just off the track..if it is pulled from the bottom track you will need to get some good glass adhesive.got mine from a car window repair shop...you will have to push the glass up to its up position and wedge or tape it there and then apply the adhesive to the track and slowly roll the track up to the glass..and push tight..let it in that position for the prescribed drying time..I suggest at least 12 hours..or until completely dry...if it is a broken track etc..The complete crank assembly will need to be replaced..My bet is glass out of the track..good luck..
Posted on Nov 11, 2014
I have a 2004 Chevy venture passenger window won't go up or down what could it be
Have you tried the drivers door "passenger door window switch" and the passenger "door window switch" to try and roll the passenger window up?When you do try to roll it up make sure the vehicle is running as you want the most voltage to the window motor.If both door switches would not roll the window up,try the following.
With the engine running hit the up window switch on the passenger door just as you give the door a HARD FIRM RAP.The window should roll up.It may take a few tries.DO NOT roll the window back down until you have changed or dissembled the window motor for a good cleaning.Also,check for broken wires at the door hinge area on both the drivers and passenger sides,pull each wire firmly looking for a broken wire.
Mar 26, 2015 | 2004 Chevrolet Venture
Window will not roll down
replace the passenger door window switch
Dec 03, 2013 | 2006 Kia Sedona
Hi the passenger side window rolled down one day and wouldnt roll back up so we did some checking and discovered the motor was good so we figured,and was told it probably was the master switch on the...
Need to get a wiring diagram. Buy a book and follow the wiring schematic. It should help you out majorly. Can't really work on electrical issues without one.
Mar 17, 2013 | 2000 Oldsmobile Silhouette
Putting window back on track gmc jimmy passenger front window
some of them run with a wire this my have corroded and snaped take of door panel and check this
Aug 24, 2012 | Cars & Trucks
My window just fell into my door and know it won't
we had a KIA sportage that did that. we went inside for the night and came out to the passenger window down turned out it was a bad window regulator
Jun 17, 2010 | 2001 Kia Sephia
The passenger rear window won't roll up or down from the drivers controle it clicks in the passenger front door. it will roll down in the passenger rear door but not up. the window modulator rolls up and...
I have the exact same problem on a Jeep Grand Cherokee 2004. The rear passenger window rolls down only from the rear passenger window and won't go up or down from the front. It has to be in the wiring because the problem was intermittent initially and a new window motor does the exact same thing. If you figured it out or have the wiring diagram please let me know.
Apr 22, 2010 | 2004 Jeep Grand Cherokee
Passenger window rolls down window but does not roll up
replace the switch. They have parts made of plastic pressing on the contacts softing these babies up making them useless in a few years
Jan 20, 2010 | 2005 Ford Explorer
Subaru impreza/ manual side window stuck
You are having a problem with the "window regulator" remove the door panel, see if the window regulator bolts fell out. they are usually in between the plastic door covering and the door or inside the door on the bottom. they are four bolts that a 10 mm wrench fit, they are short about 1/4 of an inch long, if they fell out you can simply put them back in (I recommend using lock tite on them) These bolts are located in the middle of the door a little towards the front. If your bolts are still in place you probably need a window regulator.
Mar 22, 2009 | 1996 Subaru Impreza
Jeep 1998 Grand Cherokee Laredo Logo
227 people viewed this question
Top Jeep Toys Experts
Glenn Smart
Glenn Smart
 Brian Main
Brian Main
Are you a Jeep Toy Expert? Answer questions, earn points and help others
