Question about Air-O-Swiss Humidifiers
Engine making loud noise - Air-O-Swiss Humidifiers
I have a 1099 general powered humidifier making a loud humming noise.
there are no moving parts in that humidifier other than the solenoid and it only moves open or closed are you sure the noise isn't caused by something else, maybe something close or even the furnace
Feb 23, 2014 | General Filters 1099-LH Humidifier
Hm2612-u is making really loud noise when running
Best solution is to take it back to the retailer for warranty repair or exchange.
Mar 03, 2013 | Holmes Homes HM2612-U Ultrasonic Comfort...
Loud vibrating noise when the furnace blower starts up.
Try closing damper slightly between humidifier and furnace????
Feb 03, 2010 | Aprilaire 550 Humidifier
My aprilair's humidifier motor began to make loud squealing noise
Put some lubricant, oil, WD40, etc. on shaft of fan. Spin the fan with your finger and work the oil into the shaft until the fan spins freely again. Reassemble and problem will be gone for 2-3 weeks. Repeat again until you want to replace the fan motor.
Dec 31, 2009 | Aprilaire 700 Humidifier
Aprilaire 550 makes extremely loud grinding noise when turned on
yes it should be bypass but solenoid could be trying to open but the voltage to it may be to low if you have 24v ac power at the 2 small wires. but to change shut down power to furnace and water to humidifier.you loosen the 2 compression nuts unwire they cant be reversed so dont worry then 2 mounting screws then reverse to install
Dec 17, 2009 | Aprilaire 550 Humidifier
Loud noise
Try checking the pick up tube that spins from the motor to the resivoir. If this is not seated properly or off balance even just a bit, it can cause your humidifier to sound like a small waterfall. Hope this helps
Aug 01, 2009 | Vicks Cool Mist V400 Humidifier
Aprilaire 760 furnace humidifier makes a loud screeching sound.
A bad circuit board should not make any noises. A bad solenoid valve could make a loud buzzing noise. If the noise is a squealing noise then you have defective bearings in the blower motor.
If you disconnect the low voltage wiring from the solenoid valve and you still hear the noise, then its not the solenoid valve.
Apr 06, 2009 | Aprilaire 700 Humidifier
Loud noise
Replace the water valve... It"s vibrating when closing. Do you have hot water feeding the unit?
Oct 22, 2008 | Aprilaire 550 Humidifier
Loud "Glonk" when humidifier turns off
Try turning the water valve going to the soleniod down. There may be too much pressure. You may have to replace solenoid one more time after making the adjustment.
Mar 12, 2008 | Aprilaire 700 Humidifier
Noisey humidifier
Not sure what type of humidifier you have but if is a power humidifier like the April 700 or 760 they do have a blower motor and it may be the fan blade is broken.But if you have a bypass humidifier is posible that your water solenoid may be making noise because of to much water pressure there is not much to a bypass humidifier, you may want to close the water supply valve a little at a time se if the noise goes away.
Nov 28, 2007 | Aprilaire 550 Humidifier
Humidifiers Logo
37 people viewed this question
Top Air-O-Swiss Humidifiers Experts
Mack Baxter
Dennis
Are you an Air-O-Swiss Humidifier Expert? Answer questions, earn points and help others
