Question about EliteGroup GeForce 6100SM-M Motherboard
No output to monitor
I can get no connection from the computer to the mother board.  I have reset the bios via jumper but no action.  The Monitor screen reads: No signal imput.
  • cbear342 Dec 01, 2007
    No output to monitor. Just get a “no signal input“ from the monitor from two different GeForce 6100SM-M Motherboards. No video from the board or a new video card. Power supply and monitor is good and Processor and Memory is new.
  • minderbinder Jan 09, 2008
    same issue here.
    here's the spec:
    ECS 6100sm-m
    NVIDIA GEForce 6100 single chip
    Integrated NVIDIA GEforce 6100s Graphics
    2000 MT/s FSB
    Dual Channel DDR2 800/667/533/400
    2x DIMMS, max 2gb
    1xPCIe x16, 1xPCIe x1, 2xPCI
    2X SATA (RAID 0/1) 1GB/s
    5.1 sound
    10.100 LAN
    Micro ATx
    AMD Athlon 64X2 4000+ AM2
    Clock speed 2.10GHz
    Cache memory L2 512kb
    computer makes all the right boot noises, but the screen remains blank or reads 'no vga input'... ?
Interesting, This computer was hit by lightning.  I was using the old modem.  When I pulled the modem the computer came to life and functions properly.
I would never have guessed.
De
Posted on Oct 23, 2007
  • 70 Answers
Try another video card and/or monitor
Posted on Oct 19, 2007
How to remove bios password
hi lata.
you can try this.
  1. Remove the computer cover.
  2. Locate the 2-pin password connector (PSWD) on the system board.
  3. Remove the 2-pin jumper plug and set the jumper plug aside.
  4. Replace the computer cover.
  5. Connect your keyboard and mouse, then connect your computer and monitor to electrical outlets and turn them on.
More items...
How to Perform a BIOS or CMOS Reset and/or Clear the NVRAM on ...
https://www.dell.com/.../how-to-perform-a-bios-or-cmos-reset-and-or-clear-the-nvram-o...
or go to this link.
How to remove bios password Google Search
Nov 06, 2017 | Computers & Internet
Bios password Dell XPS M170 how do you unlock it ???
How to use the jumper to reset the BIOS password on your Dell desktop computer
Summary: If you're prompted for the Basic Input/Output System (BIOS) password at startup (before the operating system loads) or the BIOS or CMOS setup is locked, and you don't know or have forgotten the password, you won't be able to use your computer or change BIOS settings. Use these instructions to reset the BIOS password manually using the jumper.
NOTE: This process will not clear a Windows Operating System password, nor will it clear passwords on a Dell portable computer. This is only to clear System BIOS passwords on Dell Desktop and Mini-Tower systems.
Desktop system BIOS password reset.
NOTE: The BIOS is the program that activates the hardware required to start your computer. The jumper is a small plastic covering found inside your computer.
Before you begin
Perform the safety steps in the order below.
WARNING: These steps are for your personal safety and the protection of the equipment.
  1. Turn off the computer and unplug the power cable.
  2. Wait 5 seconds.
  3. Disconnect all external devices.
  4. Disconnect any telephone or network cables from your computer.
  5. Press and hold thePowerbutton for 10 seconds while your computer is unplugged to release static electricity from the system.
  6. Before touching anything inside your computer, ground yourself with a wrist-grounding strap or by touching an unpainted metal surface, such as the metal at the back of your computer. While you work, periodically touch an unpainted metal surface to dissipate static electricity.
To use the jumper to reset the BIOS password
NOTE: On the DellManualsweb page, download the Setup Guide or Service Manual for your computer. Then refer to the System Board Components section for a labeled illustration of the jumpers on the system board.
  1. Ensure that your work surface is flat and clean to prevent scratching your computer's cover.
  2. With your computer still turned off and unplugged, remove your computer's cover.
  3. To locate the password jumper on the motherboard, look for the letters PWD, PSWD or PSWDCLR.
  4. Choose an option:
If there are 2 metals pins under the jumper
  1. Remove the jumper from the pins, replace the computer cover, reconnect the power cable and monitor and turn on the computer.
  2. After the Windows logon screen appears, turn off the computer.
  3. Again, disconnect the power cable and monitor. Press and hold the power button for 10 seconds to release static electricity from the system.
  4. Remove your computer cover.
  5. Replace the jumper in its original position covering the 2 pins. This will re-enable password feature.
  6. Replace the computer cover.
  7. Reconnect the power cable and other connections and turn on the computer.
If there are 3 pins under the jumper (See figure 1. below.)
Figure 1. Generic motherboard illustration showing a 3 pin password jumper, you motherboard may vary, see the owners manual for you system for specific instructions.
  1. Remembering which two pins are covered, remove the jumper from those pins.
  2. Reinstall the jumper in a different position. For example, if you removed the jumper from pins 2 and 3, reinstall the jumper over pins 1 and 2.
  3. Replace the computer cover and reconnect the power cable and monitor.
  4. Turn on the computer and wait 5 seconds. Then press and hold thePowerbutton until the computer turns off again.
  5. Disconnect the power cable and monitor again. Press and hold thePowerbutton for 10 seconds to release static electricity from the system.
  6. Replace the jumper over the original 2 pins.
  7. Replace the computer cover.
  8. Reconnect the power cable and other connections and turn on the computer.
May 06, 2017 | Dell Computers & Internet
Problem with Intel D101GGC Motherboard e210882
you can't directly blame to mother board. so first thing you can try is to reset your BIOS. to rewet the Bios you can locate the CMOS battery on your board and remove it for 10-20seconds . or you can see any jumper near the CMOS bateery and reset it. in most of the case mother board works when you reset the BIOS by doing the above process.
And if you can arreage another RAM then you can try with other RAM. I hope it'll work for you.
Jul 16, 2012 | Intel D101GGC Motherboard
I want to break my bios password.
if you are using a desktop computer you can reset *********** board settings by removing the battery or by connecting the jumper setting but to do this you need the manual of the mother board. you need to find the exact place where to connect the jumper. if you are using the laptop there is no way you can reset the motherboard of the laptop. some people use a program just to reset the bios settings but for it is quite dangerous. because it might damage the bios program in the mother board.
May 02, 2011 | Computers & Internet
No display on monitor & if ram open and restart on then no sound on buzzer.
*Please Read full post before trying Also download the Online manual for this motherboard it takes only a minute and probably will answer a lot of questions you might have regarding *********** Board.*
Um... i am assuming your able to still see the display on the monitor if you plug your monitor into the on board video card. I am also assuming that the problem your talking about accursed when you plug in a video card into *********** board and then plug your monitor into that video card. I am also assuming your graphics card that you want to plug into *********** board is a AGP slot card.
If both of these conditions apply to you then try this.
Start your computer with your on board graphics card and unplug any other graphics card form *********** board.
Next go into your bios, and follow these instructions:
Go to "Advanced", "Chipset", And then "AGP configuration".
Next change your "Select AGP 3.0 Data Ratio" to "4X".
Next change your "Graphics Adapter Priority" to "AGP/Int-VGA"
*make sure its set to" AGP/Int-VGA" or your display will not work and you will need to reset your bios via the mother boards jumper cables.*
After that hit esc and go to "Exit" select "Exit
Sep 24, 2010 | ASUS K8S-MX Motherboard
I have a 6 year old dell 2400 pc. The monitor
find out the price and then compare... but in my experience... its cheaper to get a new mother board with the chip and then just install it... in the end... all you are really concerned about is the hard drive... becuase thats where your data is...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 23, 2009 | Dell Dimension 2400 PC Desktop
No video output
Depending on your computer/motherboard there is either a bios setting or jumper you must disable to router video to your graphics card. It is probably still trying to output video on your integrated video card.
Hope this helps,
Bill
Oct 04, 2009 | Evga NVIDIA GeForce 9500GT,, PCI Express...
Can't see the bios or dual boot option on my brandnew monitor!!
Have you replaced the VGA video cable (thick cable with many pins). Do you have TWO video outputs ? One on the main board and one video card. If the BIOS is set to run off main motherboard video, the video card output won't work. If you have a video connector on the motherboard (by the printer connection and USB plugs) plug it in there. You must set BIOS to use separate video card.
Jun 05, 2009 | Computers & Internet
Turn on power nothing on my monitor, black ...
you semm have replaced any component in your motherboard eccept two, monitor and motherboard itself. try to put your new component in similar mother board begining with cpu ram vga, and put in output in same monitor (you must be hure that second motherboard is working) if nothing is coming try second monitor for output, if nothing is coming and have maybe beeps, one of your component that you have puted is defektive so try to replace them one by one. is not necesary to buy new component just try in other friend eith his parts afterthat if you finded defekyive component replace it in *********** board, (or if *********** board is defektive you must replace him, or monitor too if the problem is in monitor)
Apr 06, 2009 | Computers & Internet
K9mm-v via k8m800 + vt8237r / amd athlon / running ubuntu 7.10 video problems
MY GUESS IS THE NORTH BRIDGE ON MOTHER BOARD IS BAD, REPLACE MOTHER BOARD.
Dec 16, 2008 | Computers & Internet
EliteGroup GeForce 6100SM-M Motherboard Logo
59 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Computer Links
Matson Kurian
Matson Kurian
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
