How to make screen smaller - Televison & Video
How do I make my screen smaller on my lap top
not sure by what u mean as "smaler" try to right click on the screen & change resolution or change display
Feb 26, 2015 | Acer Computers & Internet
How can I make the screen smaller when I want to.?
adjust your screen resolution. Higher numbers mean more dots per inch, and that means smaller images on screen.
Sep 19, 2014 | Computers & Internet
How do I change the desktop text, icons and bars back to 100% from 500% in Windows 8.1?
Hi Cindy
You have set a customer DPI scale for your display.
Right Click on desktop
Choose "Screen Resolution"
Click on link that says "Make Text and other items larger or smaller"
Click on link that says "Set custom text size (DPI)"
Adjust the scale back to 100%
Apply the changes and all should be well.
Regards
Andrew
Make the text on your screen larger or smaller Microsoft Windows Help
May 18, 2014 | Acer Aspire Computers & Internet
Make screen bigger
do you mean the screen resolution got smaller ? Right click your desktop and select properties, go to advanced and change your resolution to the required setting.
Oct 16, 2013 | HP Pavilion Computers & Internet
How do i make the screen smaller
Make the resolution higher under the Display. Right Click on any open area on your desktop and select Properties. When the Display Properties window opens select the Settings tab. Change the resolution. The higher the resolution, the smaller the icons and the more things will appear on the screen.
You can also get to the display by clicking Start/Control Panel and look for Display or Appearance and Personalization. When the Display Properties window opens select the Settings tab. Change the resolution. The higher the resolution, the smaller the icons and the more things will appear on the screen.
May 01, 2012 | Acer Computers & Internet
The normal screen is divided in two smaller screen,which are showing the same channel.I want to return the screen to its normal screen size of single screen channel
The smaller picture is PNP called picture and picture.It can be set in to the menu setting.Go to menu setting and search the PNP code.Try to off or diable the PNP menu setting to back the normal single picture.
Jul 09, 2011 | LG 42PC3D 42 in. Plasma Television
How to make your screen smaller
You can not physically make your screen "smaller", but you can zoom out your screen by going into menu and exploring display options. This prosess is diffrent on all TV's, o I can't really give you a specific answer.
Hope this helps!
May 26, 2011 | Televison & Video
How do I make my screen size on my computer smaller. Too big for the size of my comp.
Right click on the desktop and select Properties right at the bottom of the pop-up menu. Then a "Display Properties" window will open. Click on Settings. In this tab you should see a slider bar with the title "Screen resolution", (drag this to the right to make the screen more detailed/smaller and your icons smaller) or (drag it to the left to make the icons larger and the screen size less detailed/larger). Then hit Apply.
NB: If your screen goes blank it means that your display card cannot handle the given resolution. If this happens immediatelly hold down the"Enter" key on your keyboard until the display comes back. Then try a lower resolution.
Please rate me high.
Thanks.
Oct 31, 2010 | Computers & Internet
My computer screen got bigger
Press Control and + to make it bigger
Press Control and - to make it smaller
Nov 14, 2008 | E-Machines eMachines Desktop PC
Televison & Video Logo
371 people viewed this question
Top Televison & Video Experts
Electro Med Services...
