Question about Vacuums
Foodsaver 2200 The vacuum /seal doesn't work. I have to use the seal button to get anything to seal after it's vacuumed
SOURCE: reset button on riccar upright vacuum
I CANT SEEN TO GET THE TOP TANK TO SNAP BACK IN, IT KEEPS SPILLING THE WATER AND SOLUTION
Posted on Dec 21, 2008
  • 107 Answers
SOURCE: Vacuum hose has little suction.
There is most likely a clog in the hose. If the hose has poor suction the foot probably has poor suction as well seeing that the hose is what gives the foot assy suction.
Posted on Jan 05, 2009
redbeard00
  • 957 Answers
SOURCE: power button not engaging...vacuum will not stay
The power button is worn out and needs to be replaced. That vacuum is pretty simple. So even if you don't know how to take it apart it shouldn't cost much to have it repaired.
Posted on Nov 08, 2009
renevacdoc
  • 84 Answers
SOURCE: Does the kirby G5 have a reset button? If so,
No reset button. It sounds like you might have one of several possible problems. Some ideas I have that you could try yourself would be to check the lockout switches: there is one behind the head nozzle, maybe the nozzle is on crooked, if so, maybe not engaging the safety switch, the other lock-out is located where the bag screws on, unlock the bag and re lock it to ensure proper fit. Otherwise, take it to the shop because it could be the motor, the cord, the switch. Hope this helped ya. Let me know. Thanks, Rene (the Vacuum Doctor)
Posted on Nov 12, 2009
SOURCE: The 'on' button isn't working/sticking
it may be possible to fix the switch before you replace it.
http://www.fixya.com/support/t1396132-off_switch_faulty
it worked for me.
good luck.
Posted on Dec 12, 2009
Seals but won't draw all the air out. Seals fine
That could be a bad foam seal not completing suction, A piece of debris that got sucked into vacuum line and or in pump, or in some cases a crack in a elbow or pump housing.
Jan 22, 2016 | FoodSaver Vacuum Sealer Kit V3460
Foodsaver V3460 vacuum runs and sounds like it has reached the end of the cycle then seals bag.
then you do not have the bag in proper place in the sealer , mine has never failed .
Aug 05, 2015 | FoodSaver V3460 Vertical Vacuum Sealer,...
Foodsaver V3840 Won't vacuum air out and wont go to seal. A label states the seals are not removable. Do you know how to fix?
you are not using a "good" bag. Make sure there are no holes and that the bottom and sides of the bag are properly sealed. It will run all day and not pull the air out if the seal is broken anywhere.
Sep 11, 2014 | FoodSaver V3840 Vacuum Packaging System
FoodSaver V3240: Lights flash,,,won't operate...what's wrong?
Pull out the long rubber piece on the top, clean any debris, replace firmly.
Aug 10, 2014 | FoodSaver V3240 Vertical Vacuum Sealer
V3420 foodsaver will not suck out the air
Is the motor still running?
If so it sounds like a blocked pipe
Aug 09, 2014 | FoodSaver V3420 Smart Seal Vacuum Sealer...
Foodsaver vacuum sealer tray full light
Clean the two little contacts on the tray. Make absolutely sure there isn't anything across the two wires that run the length of the tray. It doesn't take much to trigger the light.
Jun 03, 2014 | FoodSaver V3880 Vacuum Sealer - The Master...
FOODSAVER V3880 DOESNT GET GOOD VACUUM IN BAG
Sounds like the foam seals are leaking. Go to their website to get replacement parts.
Mar 11, 2014 | FoodSaver V3880 Vacuum Sealer - The Master...
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
No suction to seal bag
is a hose unplugged? Unplug the devise and see if you can find anything that looks like it's not connected OR it has a hole in the hose.
Sep 07, 2012 | FoodSaver Vac 800 Vacuum-Sealing Kit,...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
