Question about FrancisFrancis! X1 for Ground Espresso - Black
Francis francis x1
How do i open up the x1
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 30 Answers
Take out the two screws on the front panel. There are other screws in the oval top section. When you find them and remove them you can slide off the sleeve and can then get at all the works.
Posted on Jan 23, 2015
  • 6 Answers
SOURCE: I am looking for user guide / user manual of the Francis Francis
Go to this site www.redmonkeycoffee.co.uk select expresso machines then FF X1 you will see a link to download manual
Posted on Jan 01, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: francis francis X1 the water supply seems to be lacking pressure
I would go ahead and run a solution of 50% distilled white vinegar and 50% water through the machine. If the machine still runs slow after that, pour another 50/50 vinegar/water solution into there - let it run just enough so that the vinegar water starts to drip out, then cut the machine off. Let the vinegar/water sit in the machine for about 20 minutes. Then cut the machine on and let the rest of the solution run through. Then run plain water through the machine to clear out the vinegar. Try brewing a batch and see if the machine behaves normally.
If the above fails to resolve the issue, the FrancisFrancis machines are now owned by illy, so would need to contact them for further TS.
-Tha Mp3 Doctor
Posted on Mar 09, 2009
jmgldsmth
  • 2005 Answers
SOURCE: Francis Francis X1 - Cleaning lime from tank
CLR rinse followed by a vinegar brew then a clear water brew cycle
Posted on May 21, 2009
  • 1089 Answers
SOURCE: Francis Francis fuse defective?
Hi
If you have power its not likely the fuse. It could be the heating element or the board.
Posted on Jun 16, 2009
  • 3 Answers
SOURCE: Francis Francis X1 Gasket broken
Hello Salmonp,
You can contact Empire Fulfillment at 877-855-4540 for all of your Francis Francis machine needs. The are the authorized service center for Illy cafe and the FF machines.
Posted on Aug 05, 2009
Francis francis espresso x1 not turning on
The most obvious thing is the fuse in the plug. There are no fuses inside the francis francis (at least in the model I have).
Aug 30, 2014 | FrancisFrancis! Francis Francis 207003 X7...
Francis francis X1---the steam nozzles won't work,
HI Unscrew the chrome tip from the wand. Then check the wand tube for a plug. Insert a paper clip into the wand tip to see if there is a restriction.
Feb 07, 2010 | FrancisFrancis! Coffee Makers & Espresso...
Í have a francis francis X1 for 3 years now.
Hi
There are 4 nuts that hold the chrome head on. They are either 7mm or 8mm nuts. Loosen then and the head should twist out.
Nov 23, 2009 | FrancisFrancis! X1 - Stainless Steel...
Hello Salmonp,
Aug 05, 2009 | FrancisFrancis! X1 Espresso Machine
Francis Francis X1 blowing thru ESE pod
Check the group head shower, make sure it does not have any defects(cracks, scratches or unusually large holes).
May 30, 2009 | FrancisFrancis! X1 - Stainless Steel...
May 21, 2009 | FrancisFrancis! X1 - Stainless Steel...
Low temperature
I had the francis francis examined.  It is indeed the boiler, a $200 fix if you could get the part.  Francis Francis X1 is now a brick!
Dec 19, 2007 | FrancisFrancis! X1 - Stainless Steel...
FrancisFrancis! X1 for Ground Espresso - Black Logo
56 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Joe Lalumia aka...
Joe Lalumia aka...
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
