Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
Won't come on, tried taking out battery and that
Hp pavillion dv2000 won't start properly. when i press power button. i kinda boots up and blue quickplay lights come but thats it. no screen. is it in some sort of sleep mode?
  • chrisohallor May 22, 2009
    no nothing ekse
    i did all this and it beeps alright, but doesn't come on
  • 84 Answers
Take the cd drive out and look to see if it has grounding out marks on the back and look inside the bay
Posted on Mar 05, 2013
  • 490 Answers
The other tech is right he is trying to diagnose your problem, another thing turn the laptop over and if necessary remove any panels so you have a clear view of the fan then press the power button, if the fan does not move it will cause your cpu to overheat and shutdown, you will need to replace the fan. i had this exact problem yesterday and the fan was the problem
Posted on May 27, 2009
  • HP Master
  • 13,433 Answers
Try taking the battery and the charger off from the laptop, press the power button, now let it sit for a moment.
Plug in the power adapter and try turning it on, what happens? any beeps? does it turn on?
Posted on May 22, 2009
  • Ekse May 22, 2009
    so you decided to rate this negatively already, are we done already?
    Turn the laptop over, take the charger and battery out, find the memory cover, most cases it has 2 screws on it, open it up, you should see 1-2 ram sticks inside depends on model.
    Take both out, close the cover, don't screw it in yet. turn the laptop over, plug in the ac power and turn it on, what happens do you get beeps now? you shouldn't get picture, because you don't have any ram in there.
    wait for a minute and unplug / turn it off.
    Turn it over and place the other ram module back into its slot, don't put the other in yet. close the cover again and try turning it on now, what happens?
    do you get picture now?
2 Suggested Answers
Rajan Solank
  • 62 Answers
SOURCE: won't come on, tried taking out battery and that
The problem could be with your screen. It looks like the led light of your screen is dead you could follow up this solution.
I have had this same problem with a HP DV2000 and the problem is not the contrast light. What it is, is that the laptop thinks that the screen is been shut down that is why the light does not come on. The best way to solve this is to remove your keyboard first.
You can remove the keyboard by removing exactly 7 screws from your laptop back, there are 5 screws located under your battery and other two that are in the location of your RAM'S.
Just open them up and then you will notice that the key board pops out abit then just simply take it up and then just below the keyboard, on the same line where HP brand logo is on your machine there are two small clip types of pind, that you can remove and put back.
There is a clip that is hidden abit under the metal plate, so just try and remove that clip from its place using a needle or any long and thin object.
That will make the laptop not have the problem. But once you remove that the laptop constantly will think that the screen is open even if you close it. then after like a week or two you can put it back and all shall be fine if not then just remove it and keep it out.
You can then set your power options to shut down the screen light every 2 minutes or something like that so as to avoid the backlight being switched on all the time.
Hope this solves your problem.
Posted on Jun 02, 2009
HP Pavillion dv2000, lights come on but screen is blank
unplug the power and take out the battery then use a metal object to place accross the computers battery terminals all at once then try to start it up again this will reset the bios
May 08, 2010 | HP Pavilion dv2000t Notebook
When I turn on my HP Pavillion DV2000, the lights are displayed, however the screen is blank, is there something that can be done??
Remove the AC power jack and then the battery. Hold down the on/off button for 30 seconds, that will drain any residual power from the laptop.
Then just plug in AC power only and try to boot the laptop up. If it boots let it load Windows and then shut it down. Remove the AC power jack and then re-insert the battery. Then try to boot the laptop up.
If it boots up you all good.
If this does not work please post back.
Good luck.
Nov 16, 2009 | Dell Latitude D600 Notebook
I have a pavillion dv2000.when i swich on it says only someone with a certain number or an administrator can unlock computer
Looks like this is locked and in hibernation / suspend rather than properly off. If you hold in the power button until it powers off, next time it should boot into windows or a normal logon screen. good luck!!
Nov 14, 2009 | HP Pavilion DV5234US Notebook Laptop
I m using ur model HP PAVILLION DV2000
Sounds like you have a driver issue.
Start up in safe mode (press the F8 button about once per second after you power on), and select safe mode with networking.
When you get into windows, use windows update to download all updates for both software and hardware (update will till you that there are optional updates available, download these as well),
Hopefully when all that has completed you should be able to run your computer as normal. If not there may be a problem with the memory installed on the laptop.
Regards
Jul 16, 2009 | HP Pavilion dv2000t Notebook
I think the problem is with your LCD screen.
Try connecting it to external monitor and see whether a display will come up on the external monitor. If this the case, update your video driver. If you had updated video driver but still no display I suspected your LCD screen is faulty and needs to be replace.
(if machine is under warrantly, no need to pay any fee for replacement).
Jun 02, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hp pavillion dv2000 laptop display problems
There is a known problem with the video card in this machine, certain models are covered by an extended HP warranty.  Symptoms are overheating and finally not starting at all.
See this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
May 03, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
HP Pavillion dv2000
well, try hooking it up to an other screen and see if it boots up,if it does your screen has taken a flop if it doesn't your viedo card is gone. lala linda
Jun 03, 2008 | Computers & Internet
Hp pavilion dv2000 notebook will not boot up
I have the HP pavilioin dv2000 too. I encountered the same problem. I did everything i though possible (reseated the battery, reseated the ram) and everytime i hit the power button, i would get all the blue lights on but no screen. And it is non responsive. Fed up i held the power key down for no less than 2 minutes and ta-da the computer responds by turning off. After i pressed the power button again, it started normally.
Hope it helps. Take care.
Nov 26, 2007 | Dell Latitude D600 Notebook
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
228 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
