Question about Freezers
R404a operating pressures - Freezers
3 Suggested Answers
  • 1250 Answers
SOURCE: Normal Operating pressure for true 2 door Freezer
The pressures depend, somewhat, on the expansion device,i.e. a TXV or Cap Tube. Take a pressure reading, then convert it to a temperature. The evap temp should be right at 10 colder than the box temp. Remember, heat flows to cold so the evap has to "Lead the Load" in order to cool. In many cases, the condensing pressure is usually ambient temp, plus 30, then convert to a pressure. These are general accepted practices that have been used for many years.
Hope this helps
Posted on Jul 12, 2009
the proper operational pressure on the high side is 450 psig and on low is 200 psig for R-404A
Posted on Feb 14, 2010
I would like to recharge euroman walk in freezer room how do I go about it using r404a.
First you will need the Freon,
then a charging valve to attache to your low side of compressor line
a set of gauges to monitor pressure and a amp meter to see what amps its pulling when charging if charge is low then it has to be a leak can be a micro leak and may work for a while but not fix may need a Freon leak detector to find 90% of units end up with evaporator leaks or in condenser cooling drain pan line rusted out
Jan 23, 2017 | Freezers
What should the iowside pressure be on freezer went the inside temp. is 0 degree?
Depends what freon you are using.......... For R12 6 to10 PSI
For R502 25 to 30 About the same for R404A
Feb 01, 2011 | Frigidaire Freezers
Normal Operating pressure for true 2 door Freezer R404A Room Under 80 degrees F Box at -10 degrees F
Hope this helps
Jul 11, 2009 | True 49 cu. ft. / 1388 liter Commercial...
Taylor 1999, series 754, 3phase ice cream dispenser freeze up
I have had this with other Taylor machines. The rear drive bearing has a pin driven into the coupling that turns the beater bar. This pin will shear off. The pulley will turn and give the illution that the beater bar is turning but it really isn't. With the unit unplugged, try holding the beater bar still and try turning the large drive pulley.
I have also had situations where the hex piece that the drive shaft goes into, was rounded out. As soon as the mix go a little firm, the beater bar would stop turning but the rear drive assy didn't.
Check this out and let me know.
Jul 07, 2009 | Freezers
Can not get temp. below +10 f
what is your superheat and is defrost cycle working
Jun 19, 2008 | McCall Freezer 7-7045FT
I wolud like to modify my Kenmore chest freezer to -40F.
the amount of coolant is not the issue, its strictly a thermostat issue,WOW -40 though i dont know where youd geta thermo to go that low. def not in ANY residential/local appliance outlet
Mar 23, 2008 | Freezers
Freezers Logo
35 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
