Question about RIM BlackBerry Storm 9530 Smartphone
Blue tooth connection passkey
I have a blackberry storm. I threw out all of the paperwork for my vbt2050 I tried the 0000 default passkey and its not working...where would I find the passkey for the phone and blue tooth.
    President:
  • RIM Master
  • 2,923 Answers
Most Bluetooth devices uses '1234' or '0000' as the default passkey. Since you tried using '0000', you may wanna try using 1234.
Have a great day!
Posted on May 22, 2009
How to connect by bluethooth in Lexus 350 to blackberry 8520
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 30, 2010 | RIM BlackBerry Curve 8520 Smartphone
Blackberry storm won't accept 0000 as the passkey, in pairing mode
Not all headsets use 0000 as the passkey for pairing mode. Check you manual and make sure that the device your attaching to the blackberry does. If it does, make sure that it has not already been paired with something else.
Jan 28, 2010 | RIM BlackBerry Storm 9530 Smartphone
Visor bt, i need a passkey code. i have no idea what this is
Yes had same problem. all the usual 0000, 1234 etc access to the device was denied...on the point of binning it.....However found the answer... Get your phone to the point where its recognised another device ie the bt visor , select and its asking for password. ...now ...Turn on BT Visor BUT continue to hold main button for several seconds. There will then be another beep and light flashes alternately red and blue now insert 0000 into your phone and ok...this should then pair the devices.
Good luck
Jan 16, 2010 | RIM Blackberry 8310 8320 8330 Curve 8100...
After i enter my passkey it says connection failure for my h700 blue tooth
On the Blackberry, Go to Options, Bluetooth. Select the blackberry button, Add Device, and search. If search doesn work, try listen. While these are going conduct the following on the Headset:
Close theheadset. Go to the phone and choose discover, or search. Open the headset and pressand hold the big button. It should then turn purple and should be recognized.
Also make sure the battery on theheadset is charged before doing this.
If this doesnt work: Start the search onthe phone, Keep the boom of the mic closed when you press and hold the buttonon the h700. the light should turn purple. After this, open the boom
The passkey is 0000, four zeros.
May 23, 2009 | Motorola Mobility H700 Wireless Headset
Jabra vbt2050 won't connect
Jabra VBT2050 - You have to hold the round button in until the light stays lit (about 20 seconds) this will put it in discoverable mode, the pin is 0000, I have AT@T service and it works just fine. Hope this helps out!
Dec 21, 2008 | Radio Communications
How to connect motorola skywing
The default passkey is usually 0000 (4 zeros)
Jul 23, 2008 | Motorola Mobility H700 Wireless Headset
Password
The default passkey is "0000". Try that & see! Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 28, 2007 | Motorola Mobility H500 Wireless Headset
RIM BlackBerry Storm 9530 Smartphone Logo
457 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
