Question about Bosch Dishwashers
Bosch dishwasher is taking 199 minutes on normal wash cycle
this is me
  • 48 Answers
SOURCE: Long cycle times
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. About the led: If your dishwasher has a digital readout and you see an error code, it may indicate a problem with the unit. If this happens, look up the error code in your owner's manual to find out what the problem is.
Posted on Jan 01, 2006
BIKER T
  • 909 Answers
SOURCE: Bosch SHE44C02UC digital display shows longer time for regular wash than power wash
sadly enough, same problem. looks as though micro processor is defective.
Posted on Oct 08, 2007
ginko
  • 19396 Answers
SOURCE: my bosch exxcel dishwasher will not drain after wash cycle
That is because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Posted on Feb 07, 2009
SOURCE: my bosch dishwasher whistles when on washing cycle
it is your wash pump
Posted on Apr 16, 2009
lou5577
  • 21 Answers
SOURCE: Bosch Dishwasher SHU3302UC manual
I have one it seems forever ,about 45 mins
Posted on Apr 22, 2009
My dishwasher suddenly won't wash hot on either the normal auto setting nor the eco one.
Do you find water left in the dishwasher bottom at cycle end???? It sound like your drain line is partially or completely blocked or possibly a bad drain pump depending on model. If it can't drain completely it can't refill with hot water. That will also explain an increase in the cycle time. Some dishwasher add time because it is trying to heat the water up. Its a loosing battle if the water isn't partially hot to begin with.
Apr 03, 2015 | Dishwashers
Bosch dishwasher cycle running too long?
Please supply model number and define what is "too long". Long cycle times are usually caused by a water heating issue. Some (heavy wash w/high temp heating) cycles may take 90+ minutes for a complete cycle, this is normal. Does the unit circulate (pump) water or is just the drain pump running?
Aug 28, 2014 | Dishwashers
Bosch dishwasher actual runtime versus indicated runtime.
The usual discrepancies with run times is due to water heating time.
For example, your dishwasher may be estimating run time + time to heat the water from cold.
If your dishwasher is connected to hot water instead of cold, it will skip the majority of the heat cycle and adjust the time accordingly.
On the other hand for other people, their dishwasher brands may say "50 minute wash" but this does not take into account heating time, so wash can be anything up to around 70-80 minutes.
Jun 01, 2013 | Dishwashers
Bosch dishwasher error code c1
Hi
Pump-out not accomplished in normal time.
Check the drainage and replace or reposition the drain hose,Clean it out by running the disposer.
Feb 27, 2012 | Bosch Dishwashers
Dishwasher instructions
Hello, welcome to Fixya.
Typically the "normal" wash cycle should be sufficient and take anywhere from 60min to 120min. under normal conditions. ( Though 120 mins is quite long and should only occur if you had a low hot water supply, i.e. many people showering at the same time ).
The one variable in this is "normal". These machines when connected normal or proper should have a hot water supply and a heating capacity of 2 degrees per minute until reaching 150 degrees.
The other "tip" to consider is the numbers in the display ( depending on the model...not all have led displays ) is not actual time, just estimated time based on the previous cycle.
If you select a normal wash and run the hot water tap at your sink before starting the machine and it still takes in excess of 2.5 - 3hrs. to complete, there's likely a heating problem.
Let me know and we can go from there. The B/S/H/ ( Bosch, Thermador, Gaggenau & Siemens ) dishwasher's have had some issue with the heater relay on the control boards dating back to the early to mid 90's. Just browse through the bosch dishwasher problems and solutions under my profile... http://www.fixya.com/myprofile/solutionsfiltered.aspx?ctgid=131&usrid=3604823
and you'll see what I mean.
Thank you for visiting "fixya", please take a moment and rate the info I provided for you here and also let me know if you require any further assistance.
Good luck.
macmarkus :)
Jul 05, 2010 | Bosch Dishwashers
My SHE4402UC/36 dishwasher malfunctioned all the lights were flashing and the machine was trying to drain. The guy came out and replace the control board. The dishwasher now read 199 on all cycles except...
well its not baloney but it is cheesey. normally changing the module is the cure but it has to be programmed correctly. bosch has a recall so check it out and see because the recall is free and the tech is suppose to know how to program it. go to thermedor .com and get the #. i am a old bosch tech.
Mar 11, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Washing cycle wont complete
I had the same problem. Called the repair man, who said it was a defective control board. He ordered a new one, replaced it and now the problem is fixed.
Dec 28, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Cycle time
yes its normal.bosch dishwashers use very little water and energy but,the cycles need to be longer to get the dishes clean. its perfectly OK.(ps use cascade powder if you can)
Jul 24, 2009 | Bosch 24 in. SHU6802UC / SHU6806UC...
Bosch dishwasher she44c02uc runtimes are getting longer
hi there this is a software problem on the pcb and the only way to fix it is to replace the pcb. cost about £80
Dec 13, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
206 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
