Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
WHEN I TURN ON UNIT IT SMELLS LIKE WHEN THE RUBBER BELT STOPS TURNING ON A SWEEPER. HOW DO GET TO THE MOTOR AREA?
Smells like rubber belt burning when I turn on the power. How do I get to motor area?
    Problem Solver:
  • 15 Answers
Mosture has gotten into the motor. Take the bottom tank off and let the unit run for 30 seconds. It will dry out the compartment
Posted on May 25, 2009
  • Iced-T-tx Sep 09, 2011
    Had the same problem. Did as you say. made it about 20 seconds before the smoke started pouring out. Naturally, turned it off. What is it that is burning? How is it not doing damage? When I laid it on its back after doing this water did leak out that hadn't before, so that looks like progress.
Why does my vax power 2 cylinder hoover make a noise and smell of burning rubber when I turn it on we have cleaned inside and out and all filters
That is the smell of perhaps burning insulation when there is excessive current going into motor. If something in unit is binding the motor will not spin fast enough, generate less back emf, use more current, overheat and burn out!!!!!!!!!!!
If it has a drive belt and that is rubbing up against something and not turning properly that will also cause the smell.
Do not use unit in this condition -you risk permanent damage.
Aug 31, 2015 | Hoover Vacuums
Why are the belts burning and the brush not turning?
Check the ends of your brush roll. Most have bearings on the end and if one of those is locked up and will not turn it will burn the belt. Sometimes hair will get in the bearing area and will contribute to the bearing locking up.
May 14, 2014 | Hoover U5780-900 Windtunnel Cyclonic...
Bristles quit rotating and smelled like something was burning. It isn't the belt that turns the bristles. Can't afford a repairman, can you help me fix it?
Belt can reamin intact but still jam and burn. It won't necessarily break. I suggest you remove the bottom of the vacuum where the bristles spins and where the belt is located. You may have something jammed in there. You may need to remove the bristle to get the belt out. Inspect the belt and replace after clearing the obstruiction.
Sep 21, 2012 | Bissell 6594 PowerForce Bagless Upright...
MOTOR RUNS WITH NO VACUUM PRESSURE
Sounds like the belt should be replaced. It maybe turning the brush, but if you smell burning rubber, its slipping and not turning the brush with as much force as it should. Changed the belt. Check the air suction path. If the suction is reduced, something is blocking it. Check the bag (if it has one) and all filters. If the machine picks up any liquid, it will reduce the air flow through the filters and bag. Change the bag and filters. If this is an upright, you may find caked on dirt under or in the area of the brush.
Nov 28, 2011 | Hoover Vacuums
Smells like burning rubber when running
Vacuum belts lose elasticity and will slip. It may spin the brush roll ok when you look at it but be so loose that when. Vacuuming carpets the belt will stop turning. The motor shaft is still spinning and will melt the rubber belt causing a burned rubber smell. Belts on almost All vacuums need. To be changed at least twice per year.
Nov 13, 2011 | Riccar 8955 Upright Vacuum
Motor runs, brush won't turn, burning rubber smell
Easy to fix. The burning rubber smell is hair in the roller against the belt! Congrats, you have a healthy vacuum, you are lucky! Unplug the vacuum, remove the screws that cover the belt and roller brush. If you are nervous, take pictures with a cell phone or digital camera as you go for re-assembly. ok, pull the long roller out of it's slot and out of the vacuum. cut all hair off the roller and carefully move the belt from side to side to do the same. If the belt slips off, it slips back on easily. If the area is too tight for fingers guide it back on with any long thin wooden object. You can squeeze the belt to narrow it and slide it back over the thin metal rod that spins it from the motor. Slide the roller through the belt and back into it's slots. If it won't slide back on, turn it a quarter turn. Repeat till it does slide back into place. Put the face plate back on-tighten screws, flip it over, plug itr in and it should work!
Sep 05, 2011 | Bissell Vacuums
Vacuim sweeper motor has a high pitch squeal otherwise runs fine
If you can notice a smell of burned rubber near the sweeper, then you most likely have a slightly stretched belt. The belt would be spinning against the beater brush, causing the squeaking noise -- as it heats up, the belt will begin to smoke, or at least give off the smell of burned rubber. This will be the most noticeable if you use the vacuum for a few minutes and then turn it off -- most times the suction from the vacuum will pull the smell into the vacuum and keep you from noticing it until it has been going on for quite some time. Replacing the belt should fix the problem.
Before going out and buying the belt, you might want to check between the belt and the beater brush -- if there is a lot of debris between the belt and the beater brush, it will cause the same type of slipping as a stretched belt, and could also be the cause of your problem. Either way, to fix the issue, you have to open the bottom of the vacuum and take a look at the belt -- if it looks to be in good shape, move it around a little. If it has a lot of room to move, it's probably stretched. If you notice a big hair clog under the belt, this is most likely to be your problem -- clean that out and you should be good to go.
May 26, 2011 | Vacuums
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
Belt is burning?
is the brush turning?  remove any debris that is keeping it from rotating.  It does sound like the belt is burning because the motor is trying to turn it and the brush/sweeper is jammed.
Oct 16, 2007 | Eureka 2996AVZ Bagless Upright Vacuum
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
197 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
