Question about Bosch 24 in. SHU6802UC / SHU6806UC Built-in Dishwasher
Bosch running 199 minutes
Sometimes doesn't finish cycle. keeps running at 1 minute
3 Suggested Answers
SOURCE: Bosch she44c wash cycle time keeps extending.
We have had the same problem, except the water was not getting hot either. After a ton of research there was an issue that kept popping up. There was a massive recall on many of the model and serial #s. According to the recall there was a fire risk from the control board, the brains for the machine, that sits behind the digital display. For those not "at risk" but with the water not heating and the run time increasing, the problem can still be with the control board. I removed the control board and found a burned out connection with one of the controls. I soldered it and put the machine back together. The run time has returned to much closer (down to 128 from 184) than before the fix, but still is not back down to the original 108 minutes. I've priced a new control board--about $120.
This happened right after the warranty ran out. Imagine that.
Posted on Oct 10, 2009
  • 1575 Answers
SOURCE: bosch dishwasher error code c1
Hi
Pump-out not accomplished in normal time.
Check the drainage and replace or reposition the drain hose,Clean it out by running the disposer.
Posted on Feb 27, 2012
How to reset bosch diswasher sgs4332 au
hold the start pause button for 5 seconds, the display should then show 1 minute, when its finished its 1 minute drain cycle turn it off then on again
Feb 07, 2017 | Bosch Dishwashers
My dishwasher suddenly won't wash hot on either the normal auto setting nor the eco one.
Do you find water left in the dishwasher bottom at cycle end???? It sound like your drain line is partially or completely blocked or possibly a bad drain pump depending on model. If it can't drain completely it can't refill with hot water. That will also explain an increase in the cycle time. Some dishwasher add time because it is trying to heat the water up. Its a loosing battle if the water isn't partially hot to begin with.
Apr 03, 2015 | Dishwashers
My bosch dishwasher is stuck on a cycle, it keeps on flashing and won't start
try shutting off the power at the breaker panel and wait a minute sometimes rebooting will clear up a problem
Oct 27, 2014 | Bosch SHE6AP15UC Ascenta Evolution Series...
Bosch dishwasher gets stuck at 1 minute
New and highly targeted viral marketing campaigns can instantly place your product, service or brand in front of potential customers. See the best examples of viral marketing videos and social media strategies. Viral Marketing Company Plan Strategies and Resources Viral Shot
Mar 11, 2014 | Bosch 24 in. SGS43C12 Classixx...
Sgv5613gb
Bosch sgv5613gb will not finish cycle stopping on 1 minute and the dishers are not dry. Is it just a case of resetting the machine and if so how?
Jan 05, 2014 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch washing machine - electronic timer goes down to 1 minute remaining and stays there. Washing liquid has been drained from drawer, however, fabric softener is still there. We have resorted to stopping...
Check if drain filter is clear and drain pump is working properly. Also remove soap conditioner tray and check if you have black residue inside the soap/conditioner dispenser. Sometimes this can prevent water from entering the conditioner tray.
Oct 24, 2013 | Bosch Washing Machines
Bosch dishwasher error code c1
Hi
Feb 27, 2012 | Bosch Dishwashers
Bosch dishwasher SHU5315uc control board issue
Check the main smoothing capacitor on the control board. Could be low value.
Jul 24, 2017 | Bosch SHU5315UC Dishwasher
Keep running at one minute?
well lots of times there is a mylar ribbion on the control panel that you can un hook and gently clean it with a pencial eraser as they are sensitive to resistance and lots of times this will fix it try it before the control panel im in the usa and havnt had a lot of hands on with bosch
Mar 24, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 24 in. SHU6802UC / SHU6806UC Built-in Dishwasher Logo
21 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
