Question about Amsco Steris Digital Blanket Warmer Qdj04
My qdj04 blanket warmer doesnt heat up - Amsco Steris Digital Blanket Warmer Qdj04
Bloomfield pour over Model 8543...Taking very longto brew....How long should it take?
Call for service! Repairs should be performed by a qualified Bloomfield tech.
*** the following is for information only ***
* Your brewer has a tank that should have 1-1/2 pots of pre-heated ready to brew water. Pouring in a cold pot of water will push out the heated water into the funnel and over the coffee grounds then into the decanter. This should all start within 15 seconds of pouring water in machine (the top opening) and continue to brew for about 2 mins with a drip out for another minute. If your getting cold or luke warm water out of the brewer then you didn't give it enough time to pre-heat (about 20 mins.) Still not hot? Then call your vendor for service.
* If brewer was not pre-filled prior to powering up then the Thermal fuse may have blown due to no water in tank and/or over heating.
* Depending if the tank was empty and how hot the element got will determine what blows.
* If it was completely dry when plugged in then the element got cherry red hot and may have melted gaskets as well as all the fuses.
* Depending on the model, there may be 2 thermal fuses or even a 3d on the thermal blanket.
* If the brewer was filled but left on for a long period (weeks?) then the tank just boiled off till the fuse blew. Good chance the element is ok. But have to check to be sure.
* Pre-Heated tanks like this unit.usually have a normal load on from the warmer blanket. The load (amps) will kick up on the initial heating of the tank (filled with water) then drop down after reaching temperature.
* There is an additional load if any warmers are turned on.
* Some brewers have a separate heater switch (some call it a 'Vacation') on/off switch on a brewer will activate the main heater element. Some have a separate switch for the brew warming plate (Blanket stays on all the time)
* Easiest way to check is amperage loads on each section. Continuity is a bit harder as it does not tell you if it's shorted (unless you know the resistance loads to begin with)
* Final: Get a qualified service tech to check just to be safe.
Aloha, ukeboy57
Feb 03, 2018 | Bloomfield Coffee Makers & Espresso...
Turns on but turns off shortly afterward
it probably is-- because of the comforter as it acts as insulation and that will affect the thermostat controls for the blanket
Feb 26, 2016 | Heating & Cooling
I've bypassed the blown thermal fuse, but still cannot get anything to come on.
Call for service! Repairs should be performed by a qualified Bunn tech.
* Thermal fuse blows due to no water in tank and/or over heating.
* No model given so I'm guessing a VPR or similar pour over (BXB series) These blow out when not properly filled before powering up.
* VPR's .usually have a normal load on from the warmer blanket. The load (amps) will kick up on the initial heating of the tank (filled with water) then drop down after reaching temperature.
* The on/off switch on a VPR will activate the main heater element AND the brew warming plate (Blanket stays on all the time)
Aloha, ukeboy57
Feb 04, 2016 | Bunn GRX-B
Boils the coffee
There is usually a warmer blanket or heat control that will keep the brewer at a ready temperature.
* If your noticing a lot of boiling that continuously runs for more than 30 mins then the brewer needs to be serviced. The thermostat is probably shorted.
* Reheating is normal for table units, especially in a cold office. If it comes on more than normal (say within 5 mins) then have the brewer checked. The thermal blanket is bad and or the thermostat is set too high. (or out of calibration) Needs to be replaced.
* Call vendor for service to be safe
Aloha, ukboy57
Mar 31, 2014 | Bunn VPR Coffee Maker
Thermostat adjustment
Aloha, ukboy57
Mar 20, 2014 | Bunn VPR Coffee Maker
My sunbeam queen size heated blanket is stuck on HI
ask for another or your money back, heated blankets with electrical problems are a no no.
Jan 26, 2014 | Holmes Cozy Fleece Queen Heated Blanket
Electric Blanket Control Blinks
mydual control sunbeam electric blanket blinks on one control
Dec 23, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
Amsco Steris Digital Blanket Warmer Qdj04 Logo
56 people viewed this question
Top Amsco Science & Laboratory Experts
ray gallant
Andrew Taylor
Andrew Taylor
S J Parkin
S J Parkin
Are you an Amsco Science and Laboratory Expert? Answer questions, earn points and help others
