Question about VIA P4MA Motherboard
My Motherboard can not boot or enter bios setup
My mother board can not enter bios setup or showing the manufacturer signs, It always restart and shows the spec of my graphic card then it restart again, over and over again, anyone ..........please help....... i got a lot of work to do and i need my computer :(
    Scholar:
  • 66 Answers
Long shot but if you are familiar with computers try replacing the battery on the motherboard and also make sure EVERYTHING is securely in place where it should be. if that does not help i hope someone with more knowledge can. i had the same problem a few times and once was from the battery on the motherboard and the second was caused by the memory stick not being secured.
Posted on May 22, 2009
Why does my computer on bootup ask for system password then locks up too many attempts?
If you mean Bios password try this:
Resetting the BIOS PSSWRD, Open the computer case and look inside on the motherboard. Dell has diagrams of this. Locate the Little Jumper. It should have small print if you can read on the mother board indicating PSSWRD CLR. Boot the computer to Setup. Carefully remove jumper, becareful of static, and then once removed hit enter. Shutdown the computer, and restart and enter Setup again F2. The password should be CLR. Turn OFF and PUT Jumper back into place and Turn Back ON. You should be able to access Setup.
If you then boot to setup-check your hard drives and floppy that are seen. You may solve those issues in setup.
If you mean the windows password: boot to F8 safe mode and log
on to the ADMINISTRATOR not your log in that has admin rights.
Disable all passwords and restart.
Aug 16, 2014 | Dell Dimension 4600 PC Desktop
My Gigabyte Mother Board shows some time Load Optimized Defaults then boot / Load Optimized Defaults then reboot / enter BIOS. How to fix it?
Two things come to mind first. Number one would be making sure you have the most up to date bios. Number two would be that maybe the motherboard battery is dying/dead and isn't holding enough charge to after being shut down to save the option you selected.
Apr 11, 2014 | Gigabyte Technology Gigabyte GA-H61M-S1...
Power failed during MSI P67A-C43 B3 bios update
Download the latest BIOS update from your computer manufacturer's website onto a USB flash drive. Refer to your user manual to obtain the manufacturer's website address. If the downloaded BIOS file is a zip archive, unzip the contents onto your USB flash drive. Jumper settings may need to be reconfigured on some motherboards to enter BIOS recovery mode. Most Intel-based motherboards have a jumper setting or switch near the on-board CMOS battery. The procedure for setting the jumpers will vary depending on your motherboard make and model, so refer to the motherboard documentation for specific instructions. Power on the computer and press "F2" to access the Setup Mode menu. If you are unable to access the setup menu, you will not be able to proceed with this repair. Take your computer to a repair shop, as the motherboard may need to be replaced. Use the arrow key to select "Boot Priority" or a similarly named field. Press the "Enter" key. Scroll down until "First boot priority" or "First boot drive" is selected and press "Enter." Select the USB flash drive as the first boot priority device. Press the "F10" key to save this setting and exit from the setup menu. Connect the USB flash drive to an open USB port on your computer. Then let your computer fully reboot. The USB flash drive should be detected and the BIOS should update automatically. When the update is complete, you may be prompted to restart your computer, or it may reboot automatically. If you are able to use your computer without any further problems of overheating or failure to recognize drives, your failed BIOS update has been resolved.
Apr 05, 2013 | MSI P67A-C43 B3 Desktop Motherboard -...
Failed BIOS update
CMOS battery.
hope this helps
Sep 11, 2012 | ASUS (P5RC-LA) Motherboard
I have a Dell mother board model 0WF887. It has the usb boot option on the boot selection menu. There is no option for this in the BIOS setup. Does this mean I'm SOL for booting from a flash drive? It...
Some BIOS will only give you the option for USB if there is a USB detected upon boot. List all your boot options it could also be listed as something like Legacy USB, USB FDD, USB HDD
Aug 31, 2011 | Dell (0141E) Motherboard
I am attemping to load linux, ubuntu, on to a dell with an intel board, it is not accepting the hard drive during install of the os, i was wondering if there was was mother board reason, a jumper fix?
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
if its not accepting your hard drive test the leads that attach from motherboard to hard drive make sure they are securely seated with no dust built up or replace them they could be faulty
hope this helps
Aug 07, 2011 | Intel D865GBF Motherboard
How to install windows xp to psrd1-vm mother board
if you want to install xp to your computer
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Jul 03, 2011 | ASUS P5RD1-VM Motherboard
I have a message manufacturing mode:level (67)
Do the following with nothing attached other then the AC Power. After trying these fixes and neither works, it is a mother board issue. Replace the mother board.
1. Enter System Setup (aka BIOS) reset it to its default settings. By doing the following:
Sep 11, 2010 | Dell Latitude D610 Notebook
How to enetr bios set up of a com with mother
if you want to enter the bios set up of a mercury motherboard what you have to do is that from the begining of the system booting, system will give you the key to hit or press like some system may tell you to press Del key, some may resquest for F1 but you can try any one of this keys Del, F1, F2, F10, Ctrl+Alt+enter try any none of them. then go to booting sequence. to set the setup.
Jun 12, 2010 | Mercury P4VM800M7 Motherboard
VIA P4MA Motherboard Logo
267 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
