Toshiba ta8210aho ic - Televison & Video
How do i fix my toshiba flat screen 57" tv when it looks like it is 3d
Howdy;
It sounds like the convergence IC's have failed.
Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is detected, it’s recommended that both IC’s be changed to the “T” type IC version. Inspect the Convergence Output IC’s for the “T” type version.
1420-B Toshiba Dr.
Lebanon, TN 37087
Fax: 615-444-7520
www.tacpservice.toshiba.com/tacp
Good Luck, Big Irish.
Nov 22, 2009 | Toshiba 61HX70 61" Rear Projection...
Convvergence problem w/ Toshiba 50H82
You need to replace following ICs, may be 2 pieces in your tv for convergence problem.
IC, STK392-110T
Toshiba Part Number: 23135090X
Please search on net for availability in part stores
Sep 27, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba 40who8b convergeance problem
Good Day, harri1234;
Sounds like a convergence problem.
Convergence Output IC Failure
Corrective Action: Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is
version.
Jun 23, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba 50h72
STK392-110 Convergence ICs you will need two of them. You can get replacement ICs with free instalation instrcutions at the following link.
http://servicemanuals.vstore.ca/
Jun 22, 2008 | Toshiba 50H72 50" Rear Projection...
Convergence ICs - Toshiba 57h81
they send the instalation instructions with the ICs , which tells you what tools you would need and exactly how to replace them. yes both Ics should be repalced together as they work together to control the 3rd color. yes STK392-110 are the correct ICs for your model.
Jun 20, 2008 | Toshiba 57H81 57" Rear Projection...
Blue convergence
They should be STK392-110 ICs you can get replacement ICs at the following link with free instalation instructions
Jun 04, 2008 | Toshiba TN55X81 55" Rear Projection...
Double imaging
The Toshiba 55H70 is a standard rear projection set. It does not have a "lamp", it has 3 picture tubes. When the colors suddenly do not line up on the screen, it means that one of your convergence output IC's has burned out and needs to be replaced. This is very common on those sets. If your set is using the STK392-110 IC's, it is probably a good idea to go ahead and replace both IC's with the newer upgraded STK392-150 IC's. The IC's should be replaced and the convergence circuits realigned by a qualified tech familiar with Toshiba projection sets.
Sep 11, 2007 | Toshiba 55H70 55" Rear Projection...
Need IC - THOSIBA - 20N1TIV
Try this www.toshiba-india.com
Jul 18, 2007 | Toshiba MD24F12 TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
