Question about Kitchen Ranges
RCCB tripping problems
Random tripping of the RCCB even when we are away and no ancillary equipment is on. MCBs never trip
  • 55 Answers
SOURCE: UPS does not supply power to equipment after power trip
Some of the less expensive UPS devices have two sets of plugs.  One set provides backup power and the other set only provides surge protection.  You need to ensure that the devices for which you want backup power are plugged into the correct outlets on the UPS.
Posted on Apr 26, 2009
canbruce75
  • 1776 Answers
SOURCE: Trips breaker and get "PF" on display even when not tripped
This error code indicates "power failure" was detected. This could be caused by a bad/loose connection at either the logic board, the relay board, or at one of the three main power connection terminals on the back of the dryer. The logic board is located inside the control panel. The relay board is located in the base of the dryer. You can unplug and reseat electrical connections at these locations and check the main power cord hook-up at the terminal block. Hope this helped and best wishes.
Posted on Sep 02, 2009
dmftrucker
  • 1922 Answers
SOURCE: Random RCB trip on main split load circuit
re-check the neutral connection at the house power panel,sounds like a poor neutral connection.
Posted on Sep 13, 2009
  • 417 Answers
SOURCE: My Belling E641 keeps tripping out. Now the trip
You evidently have an earth fault on the cooker i.e one of the heating elements has failed and the trip switch is operating to prevent you getting a shock.
Most likely it is one of the radiant rings that is at fault but it could also be an oven element.
There is no easy way to tell without checking with a multi-meter for earth continuity between each element and the cooker frame, you can do this with the power off and the meter set to resistance or continuity test.
There should be no reading between healthy elements and earth but a faulty element will normally show a reading when the probe touches the cooker frame.
Posted on Dec 30, 2009
SD Tech
  • 14553 Answers
SOURCE: mw865bisb microwave has tripped the meter and now when you plug it in, it keeps tripping the meter
If it trips the breaker you have a rather hard short in the unit---take for repair shop to examine or if old consider a new unit.
Posted on Aug 30, 2012
During self-cleaning cycle we heard a loud pop and it tripped the breaker. Oven and stovetop (ceremic) still work but we smell the same smell from that cleaning cycle like electrical burning? Is there any...
If any appliance trippes the breaker there is a problem that has to be looked into, no appliance should trip MCBs or RCBs (trips), ISOLATE THE MAINS POWER BEFORE REMOVING ANY PANELS
A visual inspection of the rear is required, also the electrical mains connections. Look into this do not use the appliance until you have resolved the problem, it may turn out an amount of food had been stuck beside one of the heating elements, and causing a smell, better to be safe.
Let me know if you require any further assistance.
John
May 20, 2011 | Frigidaire Ovens
As load is apply inverter trip
Tripping Of Your Inverter / Circuit breaker when you use Kitchen range Can be because of Overloading or because of Short circuit . If There is an Earth Leakage Problem , Your RCCB may trip if you installed one .
Get Checked by an Electrician . you may need to use a higher rated MCB and Wires .
Please Rate my answer and Support me
Nov 21, 2010 | Kitchen Ranges
AV stereo rec SA-GX550 GX350 Shuts down while operating. Resumes playing after random interval. Does not pass 110VAC to ancillary equipment through AC plug in back of console. Please advise.
Technics? check for bad solder connections on the voltage regulators attached to the heatsink. some models have an acess panel you can cut out on the bottom of the receiver. you will have to find a screw or two to re-attach the panel. it could also be a problem with the cooling fan.
Good Luck
Oct 21, 2009 | Audio Players & Recorders
TV cuts on and off by itself
how often does this happen ? is it tripping random
look at the power supply panel for dry joints especially around the transformers etc
Sep 03, 2009 | Sony KP-65WV600 65" Rear Projection...
Burnt out
internal failure possibly on power side, lower than 300A fault current so unit could not trip i/p protection and as fault was post ac section, continued to burn internally.
it just broke
no breakers tripped out so it kept drawing current until the fault burnt away.
maybe this is what happened, need to know a lot more info to change hypothisis
Jun 01, 2009 | Vector VEC056D 2500 Watt Power Inverter...
Tripping BreakerS
Same problem as both above. Humidifier trips after maybe 5 minutes. Top of machine is very warm; there's no on/off switch, so plugging in does nothing until the heat dissapates. What's the solution, to just buy a new piece of equipment?
Sep 13, 2008 | Dehumidifiers
I have an Amana SRDE528TB W side by side fridge freezer made in 1999. When the compressor kicks in it trips out the house RCD circuit All the other electrical bits appear to function OK and the...
Sorry to say that the most likely cause of this problem is a bad compressor. Many Amana's have the same problem. In dealing with these units I find that will run for a while then have trouble starting up. In your case you are using a ground fault circuit and the extra current draw is causing the house breaker to trip, although most manufactures suggest that you don't use that type of circuit. The only real way to correct the problem is to replace the compressor, or get another refrigerator. The compressor replacement should be done by a qualified technician.
Aug 28, 2008 | Amana Refrigerators
Hot point washing machine WMA 32
It's unusual for a household RCD to go out on excess current from an appliance - the fuse in the plug top and circuit fuse/MCB in the consumer unit should provide closer protection. This leaves you with an earth fault. Earth faults aren't usually related to motor load. Watch carefully what phase of the cycle the trip happens. Does it correlate with the start of water heating? A very frequent cause of low current earth faults is water ingress into the heating element. If you can trip the RCD reliably on every cycle, running the same cycle with the element disconnected would confirm whether or not this is the cause. A.
Feb 28, 2007 | Hotpoint WMA32 Front Load Washer
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
