Printers
Problem for Printers
Generic problem for all Printers
Won't print - lound noise
By bzelkauf on May 22, 2009
when I try to print it makes the loudest most awful sound. I shut it down and then when it comes back up and tried to print it says carriage jam. it is new
Comments:
May 22, 2009
- officejet 6480 all in one. This is a replacement under my warranty, remanufactured. I have a feeling this one has to go back too, but I am so frustrated. when we set it up and tried to print it makes this horrible loud noise. only way to stop it is to shut down and/or pull plug. then when it goes back on it reports a carriage jam. there is no jam, I have checked. then when that is cleared it ofen goes to paper jam. was hoping for quick fix as I HATE dealing with HP
May 22, 2009
- thanks. I did just make sure there wasn't even the tiniest bit of anything in it. argg, this is the 2nd replacement. Any recommendations for a good all in one home office printer?
Clarification Request
Posted by El Geek on May 22, 2009
What is new? The printer? The cartridges inside? A carriage jam is when the rail where the print mechanism rides along has some kind of obstruction. If the printer is new (depending on how new) can you take it back?
Posted by efs_perpends on May 22, 2009
make and model #?
Best Solution
posted on May 22, 2009
Helpful)
El Geek
Rank: Guru
Rating: 85%, 49 votes
Allow me to be the bearer of bad news. From what you describe, it sure sounds like you will have to talk to HP again and get another replacement. The only things that normally jam a carriage (that I have seen in my twenty some-odd years of doing this) is the shipping foam that holds the cartridge together, but that is as visible as a brick inside an egg, you can't miss it. Or a paper jam. However, if you have already checked it out and nothing seems out of place, then I would call HP before they tell you "oh... your warranty expired yesterday..." or something like that.
I do have to say one thing though. I had a client with a printer that kept complaining about a paper jam and nothing was visible; however, when I took it apart I found that several (and I'm only talking about three or four) paper shreddings were inside the printing area. Turns out that the paper shredder that was right next to the printer, when she emptied it out from time to time, a paper shedding or two would fly about and some landed inside the printer causing the paper jam. The term JAM in this case was over stated really because it was only two pieces of paper that happened to land on the sensor that indicates a paper jam.
Sorry, I am digressing. I would seriously consider going back to HP, especially since it looks like you might be able to get another one.
Comments:
May 22, 2009
- Hard to say not knowing your situation. When recommending a printer I always like to ask if color is a factor or will b/w suffice? Advantages of b/w printing is that laser toner means less cost per printed page, the toner doesn't dry up when not in use as in the case with some ink cartridges, prints faster and the ink doesn't smudge. With that said, in the case of laser printers, you must look at the consumables required to keep your printer working. Meaning that there are some printers that not only require a toner cartridge now and again, but also require a "Drum Kit". Sometimes, as in the case with my last printer, the cost of the drum kit is almost as expensive as my printer altogether. I currently use a Canon ImageClass 4150. It isn't the latest model, but I can say that it has been working without any problems for about two years now. When I replace the toner, the drum is replaced as well because it is part of the toner cartridge. The toner runs about $60-$80 depending on where I buy it. It usually renders about 2000 normal pages.
Color Laser Printers are also another way to go, I was looking at the HP (no offense) line of color lasers and for about $400-$600 a color laser would be just fine.
Options like Duplex, and networking capabilites need to be considered. Any printer can do manual duplexing, but when you have to print out a 500 page duplex document it is easier to have the printer duplex and not you. Having the network capabilities on the printer itself means that it won't rely on a PC to be on for the printer to be available. Personally, if I can run a wire to the printer, as opposed to have it connect wirelessly, it seems better and faster.
For the inkjets, I would look for one that has a separate cartridge for all colors. This way, when you run out of blue, you replace the blue ink and not the magenta and yellow that are not low on a tri-ink cartridge. This will save you money in the long run when you stop and figure out your per page costs.
Scanning capabilites now-a-days are pretty much the same, I have not seen any low resolution scanners anymore. Faxing is also the same thing. So look for copying speed as well as how many pages can fit in the hopper.
Speaking of pages, also check out how many pages you can load on your paper tray. I installed a very nice little AIO printer for a client; however, the paper tray only held about 150 pages. My Canon can hold about a **** of paper which is about 500 sheets. My HP OfficeJet 7410 AIO has dual trays and they hold almost a full **** each tray. Having the dual trays is also a great thing because at the end of the month I put envelopes in the top tray and regular paper in the lower tray and never have to switch back and forth when sending out invoices.
I guess what you need to write down are your "needs" and your "wants" for your next printer. Then put them in a priority order and then try and match up something that will fill all of your needs and most of your wants.
Good luck, keep us informed.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Printers
Questions and Unsolved Problems for Printers
Answer
Is c4200 stil availabl eto buy?
Answer
MP 620 printer is it a good buy
Answer
Describe your Canon LASER SHOT LBP-2900 Printer all type of Problems
Answer
I don't have a user manual CITIZEN GSX-230.can you send it to me.Plz
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
