Question about Pioneer VSX-823-K
Wont stay on
Shuts down after 2-3 seconds unplugged everything same result
Pioneer PDP - RO6U Plasma: Says starting up, please wait when turning on. Can't get past this screen. I have tried unplugging and plugging everything back in and am still getting the same error. Are...
unplug it from the power for one hour. Than Press and hold the power button on the on the TV for 20 seconds(It wont show anything. Than Release the power button....
After that plug the power and check the same...
Sep 14, 2008 | Pioneer Televison & Video
Wii power problem!
You are not getting the correct voltage into the Wii, this can happen one of three ways. (1) The power converter you have is not converting the power correctly, (2) running on converters are not exactly matching the correct voltage and wattage has strained your power supply and damaged the Wii, or (3) the power supply itself just failed as a result of any number of normal electrical conditions.
Jun 09, 2010 | Nintendo Wii Console
Lightning Last Night Nocked The Receiver Out.
leave unpluged overnight. usually capacitors hold charge and will release slowly. try that if doesnt work powersupply is bad.
Jun 03, 2009 | Yamaha RX-V861 Receiver
Kenmore Elite QuietPak 2 powers up and shuts off within seconds
I need the serial #, to better assist you
Thank you
May 12, 2009 | Kenmore Dryers
Laptop shuts down in 6 seconds.
Most proably it is a main board problem. Contact authorized service center.
Jan 27, 2009 | Gateway MX6448 Notebook
TV won't stay on for more than 2 seconds
TV turns on for 2 seconds then shuts off. Sleep/timer blinks. Won't go back on unless unplugged and plugged back in
Nov 16, 2008 | Televison & Video
Cant shut down
keep start button pressed 30 seconds, the pc should turn off. If not brutally unplug the power cable. Do a scan disk on restart.
Feb 16, 2008 | Acer Aspireā„¢ T180 PC Desktop
Television Shuts Off
TRY REPLACING THE REGULATOR OR CHECK DIODES IN SAID CIRCUIT ,ALSO CHECK FOR BAD CONNECTIONS.
Jan 26, 2008 | Toshiba MD14FN1 14 in. TV/DVD Combo
Dell inspirion 1150 won't boot up
I had this exact same thing happen. I tried everything I could think of and find out to try. For me it was a motherboard failure and installing a new one worked. .
Jan 19, 2008 | Dell Inspiron 2200 Notebook
Pioneer VSX-823-K Logo
43 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
