Question about Frigidaire Dryers
Dryer door switch sparked and now wont start.
Fridgidaire dryer model FLGB8200DS1: The door switch was stuck so I pried it out and replaced the spring. When I put it back and tested, it sparked (I think the wire was touching the frame). Now dryer won't work at all. (Washer still operates). What part was damaged and needs replacement or repair?
  • 1 more comment
  • Victoria
    Victoria Jan 06, 2014
    Thank you, how do I access the fuses/board? How do I test and replace a fuse? Thanks for any guidance.
  • Anton
    Anton Jan 06, 2014
    Get it checked out by a professional, it sparked for a reason and any unprofessional repair could result in electrocution !!!
  • Victoria
    Oh brother!!! Rewired my whole house...I know how to turn off the main.
    Problem Solver:
  • 8 Answers
A fuse on the board may have blown....
Posted on Jan 04, 2014
  • 172 Answers
SOURCE: whirlpood dryer Model LER8620pwo Above
Pull the dryer out and unplug. At the bottom left of the back you will see your blower housing. on it you will see a 1 inch by 1/2 inch white thermal cut out. This is the part you are looking for. it is part number 3392519
This part is available and cost$18.00 to ship it to your door.
Mike Anderson
Anderson Appliance Repair
(865)945-3808
Posted on Dec 02, 2008
  • 16 Answers
SOURCE: Hotpoint NVL333EYOWW electric dryer
If it doesnt run at all its nothing to do w the thermal aspects at all. The motor would run regardless just no heat. Check all paths electrically to the motor and be sure to check the motor itself.
Posted on Jan 17, 2009
TheMobilian
  • 8220 Answers
SOURCE: Wire Scraping sound and sparks inside rear dryer drum area.
Probably the rear bearing has failed and caused the drum to rub against the heating element. Hey, is this the guy that said he heard a noise last month? LOL
Posted on Feb 04, 2009
john631068
  • 172 Answers
SOURCE: How to replace door switch on old kenmore stac.dryer 110.88752792
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.Check online for the part repairclinic.com has it for $14.00 not bad
Posted on Nov 17, 2009
TheMobilian
  • 8220 Answers
SOURCE: dryer won't start
On the bottom left is the heating element. On that element is a limit. If open the dryer will not run.ba9d1b0.jpgHere is an amana late model service MANUAL:
Posted on Apr 07, 2010
Fridgidaire dryer aeq6000es. won't start, beeps 3 times with error message dr
Hello
This code means the dryer door is not closed or the door safety switch is not making a good connection at times. The dryer door safety switch is in the opening of the door and when the door is closed the switch button is depressed. If the control circuit board doesn't get a signal that the dryer door switch is closed it will not allow the dryer to start.. Try firmly closing the dryer door a 2nd time when this happens, if that cures the problem you are good to go, if that doesn't cure the issue you must remove the front panel of the dryer and replace the switch. If you need a switch they are available from Sears Direct for about $15.00 Below is a picture of the switch that most likely used in your model and make, the button on top is what the dryer door depresses when closed..
Jul 12, 2011 | Dryers
Dryer was running. I opened the door to check the load and the dryer would not restart. I buzzed, but did not turn. Some smell of over heating. next day before I started to trouble shoot, I attemped...
Usually a dryer that will not start is the door switch. The switch is simple to change and comes in different styles. Some have a screw or two to remove and some without screws you just pry out to replace. To replace open the door and you will se a button that closes the switch when the door is closed. Depending on the type remove screws or pry the switch out. Your local appliance dealer has these switches cheap. Take your with you as well as the make and model number to buy a new switch. Reinstall and all is well. Hope that helps and thanks for asking Fixya.com, Rich
Nov 21, 2010 | Whirlpool LER4634J Electric Dryer
Push start button wont start dryer
This could be the non resettable thermal fuse has popped, or the door switch is not working. Open the door and press on the door switch until it clicks and push start to see if it works. If it clicks and still no start, then the thermal fuse needs replaced. UNPLUG the dryer, remove the back and you will see the white thermal that looks like a regular thermostat with 2 wires on it. It is located on the air plenum. There could be 2 depending on the exact model, but normally only one white one. These thermals usually pop when the temperature gets too hot as a warning something needs checked. Check your vent and be sure it is absolutely clear, and the flapper on the outside is not stuck with lint buildup.
Nov 27, 2009 | Kenmore 62602 Electric Dryer
Dryer just stopped
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
I would also, check the Thermal Fuse as well.
Jun 25, 2009 | Kenmore 62602 Electric Dryer
Dryer wont start
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
Jun 03, 2009 | Kenmore Dryers
Estate dryer wont engage
Check the following--
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
Jun 01, 2009 | Whirlpool LER5636P Electric Dryer
Ge dryer wont stay running
start switch is bad,it is stuck inside,get the model number inside dryer door or on top panel,call local appliance parts store to get new part,only a few bucs,replace and you should be allright,let me know-mike
Jun 15, 2008 | GE DBSR453EBWW Electric Dryer
Need help with OLD dryer
IF YOU MEAN THAT THE DRYER STARTS BACK UP WHEN YOU CLOSE THE DOOR, THE PUSH TO START SWITCH IS SHORTED. CHECK TO SEE IF THE PUSH TO START BUTTON IS STUCK PRESSED IN AND NOT SPRINGING BACK OUT.
IF IT IS STUCK, TRY WD-40 TO LOOSTEN IT. OTHERWISE, REPLACE THE SWITCH.
IF THE DRYER KEEPS RUNNING WHEN YOU "OPEN" THE DOOR, THE DOOR SWITCH IS SHORTED. REPLACE THE DOOR SWITCH.
Mar 31, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
