Question about Vizio 39" E390VL 1080p LCD HDTV
Can't set up close captioning. Icon doesn't work.
Cannot highlight cc button to set up cc. Button not lighted.
SOURCE: closed caption
i turned off "mute cc"
thanks
Posted on Dec 27, 2008
SOURCE: Closed captioning for hearing impaired
Looked up vizio web page, found the manual.
Posted on Jan 27, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: HAVE CC ON HDMI CAN NOT REMOVE IT
Go into the setup for the source (cable box, DVD player, etc.) feeding the HDMI input and make sure captioning is turned off there.
Posted on Apr 22, 2009
  • 176 Answers
SOURCE: cannot turn CC ON/OFF via remotes
Try this combination.
1) Start with the cable box turned on and TV on tuned to the cable box.
2) Press the POWER button for the cable box and then quickly press the MENU button.
3) This should bring up the user setting menu. Use the arrow keys on remote to go to Closed Caption and press right arrow button this should bring up the closed caption menu.
4) Press the OK button and this should either turn CC on or off.
5) Once Closed Caption is turned off press LEFT ARROW button to return to User Settings Menu.
6) Press the POWER button to turn the Cable box back on and the Closed Caption should be gone....
Good Luck.....
Posted on Jan 19, 2010
SOURCE: vizio l37 closed captions are garbled.
we have the same problem and we have direct TV
Posted on Mar 15, 2010
Turn off close caption for netflix with harmony 900
Close Caption CC is a Netflix setting not a harmony 900 setting.
When Netflix is running on the lower right select the highlighted icon and select English CC
Hope This Helps?
Nov 27, 2016 | Televison & Video
How do you shut off the closed caption n
It might be the Subtitle feature not CC(close caption) that you are viewing. The following is the procedure for a Samsung player. Other players would follow a similar procedure.
1. Press the MENU button on your remote control.
2. Use the navigation buttons to highlight System.
3. Highlight Accessibility.
4. Press the right navigation button again to access the Accessibility options, highlight Subtitle and then press the ENTER button.
5. Press the ENTER button again, highlight Off and then press the ENTER button once again.
Hope this helps.
Mar 23, 2016 | Televison & Video
How to turn off closed caption
For over the air usually on the lower section of the remote look for CC or subt.
If on cable the Close Caption is controlled by the cable box not the TV. Usually there is a CC near the cable select button on the cable box remote. If not found then go into the cable box settings and look for
  1. Press the SETTINGS button
  2. Use the arrow buttons to scroll to the LANGUAGE section.
  3. Scroll to Closed Captioning and press the right arrow.
  4. Press the right arrow again and highlight the Off option
For some setups it is more complex. This link may help you with.
My Closed Captioning Won Turn Off
Jan 05, 2016 | Samsung Televison & Video
Can't get closed captioning to work on westinghouse 46" 4680 led tv
What is the video source? Some set-top boxes send a closed caption signal that doesn't match the TV's CC interpreter. For those devices, you need to enable the captions on the set-top box.
I know how to enable captions on one particular Dish satellite box. The steps will depend on if your TV is TV1 or TV2 connected to the box. If the TV is TV2, you need to set the box in Single mode (so both TVs are set to the same channel). This is done with the Mode button on the box itself (highlight Yes and click Select using the Dish remote when prompted to go to Single Mode). If the box is in Single Mode, you won't get a prompt but the unit will go to Dual mode. There is a small LED on the box to indicate Single or Dual mode.
Next press Menu on the remote and go to Properties (9). Click Select and then navigate to Closed Captions (6). Click Select. Go to the Closed Caption On/Off line (1) and press the left arrow and then the up/down arrow to set to the captions to On. Press the right arrow and then Select with Done highlighted. Exit the Menu by hitting Cancel repeatedly.
I hope this helps.
Jul 24, 2012 | Westinghouse Televison & Video
How do I shut off the captioned dialogue on the screen for my magnavox smart series tv. there seems to be no such choice on the menu
hi,
For closing the Closed Caption option do the following.
1. Press the MENU button on the remote to see the menu.
2.Press the up arrow or down arrow until the CC (Close Caption) is highlighted.
3. Press the right arrow repeatedly until CC OFF appears.
4 .Press the menu button to exit.
Or, you also can set Closed Captions by pressing the CC button on the remote. Press CC repeatedly to select: CC-OFF,
ok
Feb 07, 2011 | Philips Magnavox 20MS233S 20" TV
My closed caption on my new dynex 26L 150A11 will not turn on. I have followed all instructions in the book. I need the cc. any one have an answer? thanks cosycat
There are several possibilities here so you will need to work with me to resolve this problem. In order for Closed Captioning (CC) to work, you need to make sure the CC settings are correct on the TV, and then make sure they CC is switched on. In addition, if you are using a cable or satellite receiver box, CC also needs to be switched on for these "boxes".
It's easiest to start with the TV. Please make sure you have done the following:
1. Check the Closed Caption settings are as follows from the TV on-screen menu as follows:
a) Press the "MENU" button on the DYNEX remote
b) Press the RIGHT arrow twice to highlight the "SETUP" menu
c) Press the DOWN arrow once to open the "SETUP" menu
d) Press the DOWN arrow twice to highlight "CLOSED CAPTION"
e) Press the RIGHT arrow or the "ENTER" button once to open the CLOSED CAPTION MENU
f) Make sure the Closed Caption option "CC MODE" is set to "ON". This can be changed using the UP/DOWN arrow keys to highlight "CC MODE" and using the LEFT/RIGHT arrows to switch between off and on.
The "Basic Selection" and "Advanced Selection" settings are for analogue and digital closed-captions respectively. In addition, the "Options" sub-menu can be used to change the size and style of the digital closed captions (Advanced Selection). All three of these options should eventually be set according to your personal preferences, but for the purposes of making sure it is working, I suggest you set them as follows:
Basic Selection = CC1
Advanced Selection = Service 1
These options are the basic settings which will display only the spoken dialogue of the TV program.
g) Press "EXIT" on the remote to close the menu and return to viewing mode.
2. Press the "CCD" button on your Dynex remote control. This can be found in the bottom right-hand corner of the remote. Each press of the "CCD" button will cycle the closed captions between ON and OFF. (CCD means Closed Caption Display)
3. Check the Closed Captions are displayed and then adjust the Basic and Advanced Selection options until the type and appearance of the closed captions are how you like them.
If you have done the above and still cannot get it to work, please let me know whether you are using a cable or satellite receiver and the brand/model number. I will then be able to assist you further.
Regards,
BElectric
Dec 30, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Closed caption
CC (Closed Caption)
Press the down button to highlight the CC (Closed Caption) selection.
Press the > button. A separate menu will appear with the following CC
settings
CC
When watching regular analog (NTSC) TV, the CC feature is available in the
Setup menu.
Press the down button to highlight the CC selection.
Press the > button to select CC1, CC2, CC3 or CC4.
Once the adjustments are completed press the LAST button repeatedly to exit
the OSD completely.
Closed Caption for regular TV is usually CC1 or CC2.
Mar 02, 2010 | Vizio VO42L 42 in. LCD TV
Cannot turn CC ON/OFF via remotes
Good Luck.....
Jan 17, 2010 | Vizio VW32L 32 in. LCD HDTV
Closed Captioning: How do I turn it off?
Press the Orange V Button
Scroll over to the Wrench Icon
Scroll down to CC
Press left or right arrow until OFF is highlighted
Press Orange V button
Nov 29, 2009 | Televison & Video
I do not know how to turn off the closed captioning on my son's orion tv set. I do not know the model type. I do know that closed captioning options are not on the menu.
If you have the original remote look for a button labeled "CC" or "Caption/Text" press this button till the screen says caption off.
Jul 06, 2009 | Televison & Video
Vizio 39" E390VL 1080p LCD HDTV Logo
51 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
