Question about Frigidaire Dryers
Dryer wont start after spark of door switch.
Fridgidaire dryer model FLGB8200DS1: The door switch was stuck so I pried it out and replaced the spring. When I put it back and tested, it sparked (I think the wire was touching the frame). Now dryer won't work at all. (Washer still operates). What part was damaged and needs replacement or repair?
  • 1073 Answers
SOURCE: kitchen aid dryer
the diagram that you are looking for is in the console as for the two blue wires they go to the blower fuse that is white and about the size of a small paper clip
Posted on May 02, 2008
TheMobilian
  • 8220 Answers
SOURCE: Wire Scraping sound and sparks inside rear dryer drum area.
Probably the rear bearing has failed and caused the drum to rub against the heating element. Hey, is this the guy that said he heard a noise last month? LOL
Posted on Feb 04, 2009
aasc
  • 1606 Answers
SOURCE: trying to replace timer 8299771. Can't find my
On the new timer , you have 2 wires comming of the timer motor . The blue wire should go to one of these terminals on the timer itself . The place where there is ONLY a timer motor wire going to , is where it should go .
Posted on Sep 04, 2009
Testimonial: "Okay that worked perfectly. Timer works. Unfortunately, so does the old one."
dmftrucker
  • 1922 Answers
SOURCE: sparks from starter switch wires
you may have lost one leg of power at the panel if fused or on 2 single pole breakers,or you could have burnt the neutral connection somewhere inside the unit
Posted on Sep 26, 2009
TheMobilian
  • 8220 Answers
SOURCE: dryer won't start
On the bottom left is the heating element. On that element is a limit. If open the dryer will not run.ba9d1b0.jpgHere is an amana late model service MANUAL:
Posted on Apr 07, 2010
Dryer door switch sparked and now wont start.
A fuse on the board may have blown....
Jan 04, 2014 | Frigidaire Dryers
Fridgidaire dryer aeq6000es. won't start, beeps 3 times with error message dr
Hello
This code means the dryer door is not closed or the door safety switch is not making a good connection at times. The dryer door safety switch is in the opening of the door and when the door is closed the switch button is depressed. If the control circuit board doesn't get a signal that the dryer door switch is closed it will not allow the dryer to start.. Try firmly closing the dryer door a 2nd time when this happens, if that cures the problem you are good to go, if that doesn't cure the issue you must remove the front panel of the dryer and replace the switch. If you need a switch they are available from Sears Direct for about $15.00 Below is a picture of the switch that most likely used in your model and make, the button on top is what the dryer door depresses when closed..
Jul 12, 2011 | Dryers
Dryer was running. I opened the door to check the load and the dryer would not restart. I buzzed, but did not turn. Some smell of over heating. next day before I started to trouble shoot, I attemped...
Usually a dryer that will not start is the door switch. The switch is simple to change and comes in different styles. Some have a screw or two to remove and some without screws you just pry out to replace. To replace open the door and you will se a button that closes the switch when the door is closed. Depending on the type remove screws or pry the switch out. Your local appliance dealer has these switches cheap. Take your with you as well as the make and model number to buy a new switch. Reinstall and all is well. Hope that helps and thanks for asking Fixya.com, Rich
Nov 21, 2010 | Whirlpool LER4634J Electric Dryer
How do i access the back of a Model #MDE8600AYW - MAYTAG Dryer. i think i need to replace the drum rollers but dont think i can from the front panel.
yes it can be accessed from the front panel as it is located on the back right inside of the dryer.
1) unplug dryer
2) open door remove screws
3) with a flat tip screw driver pry gently up on the top corners it will pop
4) move front panel forward and disconnect door switch
5) sit panel aside
6) lift top lid of dryer 90 degrees it has clip/hinged on back
7) look to the right back of dryer, it looks like a spring in a metal box disconnect and replace.
Hope this helps Tim
Sep 25, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Problems with GE DWXR483EBWW Electric Dryer. Dryer will not start (no spin,no heat, no attempt to start). Has Power because interior light works. About 6 mo ago start switch was replaced...does not appear...
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Nov 11, 2009 | GE DWXR483EBCC Electric Dryer
Dryer just stopped
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
I would also, check the Thermal Fuse as well.
Jun 25, 2009 | Kenmore 62602 Electric Dryer
Dryer wont start
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
Jun 03, 2009 | Kenmore Dryers
Estate dryer wont engage
Check the following--
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
Jun 01, 2009 | Whirlpool LER5636P Electric Dryer
Ge dryer wont stay running
start switch is bad,it is stuck inside,get the model number inside dryer door or on top panel,call local appliance parts store to get new part,only a few bucs,replace and you should be allright,let me know-mike
Jun 15, 2008 | GE DBSR453EBWW Electric Dryer
Need help with OLD dryer
IF YOU MEAN THAT THE DRYER STARTS BACK UP WHEN YOU CLOSE THE DOOR, THE PUSH TO START SWITCH IS SHORTED. CHECK TO SEE IF THE PUSH TO START BUTTON IS STUCK PRESSED IN AND NOT SPRINGING BACK OUT.
IF IT IS STUCK, TRY WD-40 TO LOOSTEN IT. OTHERWISE, REPLACE THE SWITCH.
IF THE DRYER KEEPS RUNNING WHEN YOU "OPEN" THE DOOR, THE DOOR SWITCH IS SHORTED. REPLACE THE DOOR SWITCH.
Mar 31, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
11 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
