LG 22 Lv2500 - Televison & Video
My usb is not working for video only in lg led 22le5300 what happned what to do
According to the spec sheet for your TV (see attached link), the only video files it recognizes and plays are MPEG-4 (files with extension .mp4) or DivxHD (files with extension .divx). If your video files are not of these types, you can download a free video converter PC application to convert your files to the two types that your TV can play from the flash drive. LG 22LE5300 22 inch HD LED TV 21 6
Dec 18, 2014 | LG 22LE5300 22" 720p LED-LCD TV - 16:9 -...
22" Logic tv does not get a signal from arial
is it the is it the Logik L22FED12 22" LED TV with dvd Combo that is having the problem or the LG 32LD550 32 in. ??
Jun 01, 2014 | LG 32LD550 32 in. LCD HDTV
Hey ya all, merry xmas!! I'm looking for drivers for LG L222WS-BN monitor!
Merry Xmas. Monitor should not need seperate drivers as generic ones will enable it. What exactly is the problem?
Screen resolution can be changed in the control panel of your OS.
Dec 25, 2010 | LG L222WS-BN Wide-format 22 22 inch LCD...
Open lg 22' wide screen
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
Apr 13, 2010 | LG 22" FLATRON LCD Monitor
I have a LG Flatron 22", LCD monitor, model is W22345. dilemma: after sleeping the computer for the night, as I have been doing for the past 8 months that the computer and monitor has been in my owne
Check the video cable,replace them, and if didnt work, try to reset the config stored on the settings of the monitor (usually by menu).
Some electronic problems could do the same simptom. check the manual for hints.
Good luck
May 23, 2009 | LG 22" FLATRON LCD Monitor
22" FLAT LCD FROM LG
make sure the lcd monitor is connected to a voltage regulator because if your electricity is fluctuating then that might be a cause of the flickering of the monitor. make sure also that the video card of your operating system is configured properly and the drivers are working fine.
Aug 24, 2008 | LG 22" Widescreen Flat Panel LCD Monitor
Monitor configuration
Did you also install the LG software and LG Drivers correctly?
With my LG flatron i received a piece of software to optimize my settings and even calibrate the monitor. I run win XP ME.
Jul 04, 2008 | LG 22" Widescreen Flat Panel LCD Monitor
LG 22" Flat Screen TV
Miniboy,
Don't relied on the mini-speakers, of course sound awful! It's has only 2 watts built in speakers. Try not to set at a full volume. Have fun!
Mar 01, 2008 | LG Flatron 295LM 22" LCD Monitor
Televison & Video Logo
10 people viewed this question
Top Televison & Video Experts
