Nortron electric heat will not turn off when set temperature is reached
It seems like heat gets stuck on and temp just keeps climbing no mater what i do. I tried turning heat selection off on thermostat and running just the fan heat still on. This has only happen about 3 or 4 times but it worries me that it may not shutoff when I'm away.
    Master:
  • 571 Answers
Replace sequencer
Posted on Jan 06, 2014
  • 24 Answers
SOURCE: RUUD (Protech Model 500) Thermostat Single Stage Not Programable
problem is not the thermostat, thermostat is an on-off switch that happens to work on temperature. Your furnace is locking out. cycling the heat off switch resets the micro-processor in the furnace. You need to diagnose the problem in the furnace, to go further we will need the model and approximate age of the unit
Posted on Dec 18, 2008
tborn6
  • 700 Answers
SOURCE: Furnace doesn't reach desired temperature
On the thermostat if its a manual on then pop the cover off and look for a small dial with numbers on it. Take and move it tpoi a higher number than whats it is set at. Its called a heat anticipater and is supppose to make it so that the unit does not oveshoot or under shoot like what your experiencing. If its a digital oine then you are going to have to configure the setting in the insdtallers menu.
Posted on Dec 21, 2008
pierre1811
  • 144 Answers
SOURCE: Electric furnace runs but won't shut off on heat setting
I would insist that Sears either have a Senior tech come out and fix it or return it to the state it was prior to them touching. Then call some one else. Have them involve the Goodman rep in your area.
Posted on Jan 20, 2009
  • 3 Answers
SOURCE: Ruud Electric Furnace Cannot Reach Setpoint - "Watt Restrictor"?
unfamiliar with watt restrictors.
heat strips have 2 safety devices, a thermal overload, they get to hot they shut off, cause not enough air flow increase fan speed this device is auto reset. a fusible link a fail safe to thermal over load, no reset and sometimes replaceable. if this does not help would like to ask you a few questions. one of the buildings i take care of has 200 + reem/ ruuds all electric heat. if a part is defective replace, please do not by pass. safety frist.
Posted on Mar 07, 2009
co7196
  • 3433 Answers
SOURCE: Dometic AC that the fan shuts off but the compressor keeps running
call dometic dealer. I hear they have a bad circuit board that is replaced.
Posted on Jun 02, 2009
I have a rlv4300 wired to a fan forced wall mounted heater when desired temperature is reaches heater shuts off for 3 or 4 seconds then comes on again over and over is this normal
The temperature delay has a setting (on some) that needs a differential between the on and the off temps, if this is too close the residual heat extracts when it climbs to the on temp then cols to the off and then climbs to the on again, its not normal but is efficient and is not allowing the unit to overheat but if the differential can be set wider it is the answer.
Mar 30, 2015 | Heating & Cooling
How do I keep the burners on at medium heat when I am making carmels so they get to the stage where they become caramels. My burners kept shutting off, so I had to turn them higher and when I got don
Is it the electric glasstop stove with the smooth top? If so, the burners aren't actually turning off. They're red until they reach the right temp and then they go dark to maintain the temp. If they stayed red the temp would keep climbing. I used one a while back and I remember it doing that. You didn't give much info, so that's my guess. I think most electric stoves do that to some extent, though. If it's gas, however, I'd call a repair guy.
Oct 01, 2017 | Kitchen Ranges
Nortron electric furnace series
Sounds like a stuck sequencer. Verify there is not 24 Volt control voltage to sequencer coil, then replace sequencer.
Jan 04, 2014 | Heating & Cooling
Electric furnace won't shut off
It sounds like a bad or badly miswired T-stat
Jan 20, 2009 | Goodman CLQ36AR49 Air Conditioner
Appliaance shuts off at low temperatures
Most refrigerators cycle on and off based on the fresh foods temp. If the ambient temp is 10C and you have it set for 4C, the unit does not have to run much to satisfy the temperature control, and the temp in the freezer section will warm to + C range. (likewise, if the ambient drops to -C range, it won't mater if you set the fresh food section to +4C, it won't heat the air, and the fresh food section will eventually reach the -C ambient temp.) The only solution is to move the appliance to a warmer location or heat the room it is in. This is the only Fix-Ya for your refrigerator.
Jan 03, 2009 | Refrigerators
Too hot
more than likely if it isnt shutting off when it reaches temp. then it probably needs a temp sensor or a EOC (electronic oven control). I have replaced many of these boards in the past , usually there is a relay on the board that is stuck. The relay really isn't replaceable and the whole board needs to be replaced. Does the dispay show the temp that the oven acually is or the temp it is set for?
Nov 05, 2008 | Maytag MER5775Q Electric Kitchen Range
Temperature control
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
Sep 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Electric hydronic liquid-filled baseboard heaters
The same comparisons with other forms of electric heat (i.e., radiant, electric strip baseboard, etc.) are the same. The difference is cycle time - the liquid-filled electric heaters turn on and off less frequently than strip-type to maintain thermostat temperatures. This also means that the unit's temperature will swing more widely than the desired average thermostat setting (the liquid's temperature will signal the thermostat to turn off power, but the temperature will continue to climb; similarly the liquid will signal the thermostat that it is cool enough to engage power but the liquid will continue to cool after power is engaged - similar temp swings with hygronic heating systems). Some say that the liquid-filled units are safer, but the manufacturer's installation guidance is usually the same between strip and liquid-filled so both pose an equal safety hazard.
Sep 21, 2008 | Fahrenheat PLF1504 Baseboard Heater
Won't shut off when reaching preset temp
Sounds like a thermostat problem or a short in the wire. Can you give us more info like is it gas or electric and model numbers will help.
Thanks.
Oct 11, 2007 | Heating & Cooling
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
