Clutch pawl not disengaging correctly when machine starts to agitate
  • Washing Mach... Master
  • 19,396 Answers
The washing machine clutch spins or oscillates , applying force from the agitator or propeller to selectively rotate the basket.
Your washing machine clutch system consists of a support member that includes a housing and a cover. An actuator comprising a piston.A bracket comprising a lever coupled to at least one arm including at least one terminal and at least one protuberance.A spring connected from the support member to the bracke, a hollow shaft and a shaft. A second spring , couples the clutch to the shaft.
Often there is an internal secondary mobile clutch that couples to the shaft.
All this parts are internal components of the clutch assembly and cannot be replaced separately.
If the clutch does not disengage at all, or does not disengage completely you need to replace the whole clutch assembly.
Clutch replacement is not an easy repair .
If instead the problem is that machine is not agitating check also Agitator, drive motor, transmission , and motor coupler if present.
Enter the model number below to get parts and diagrams for your appliance:
Appliance Parts Pros
Posted on May 22, 2009
Agitator only going in one direction
either clutch pawl tip broken or fallen off or capacitor fault
Nov 14, 2015 | Samsung SW62ASP Top Load Washer
My kenmore 600 washer will agitate when emmpty but not when loaded... The clutch was spinning when in the spin cycle and was told that shoud not happen.. With new clutch in it still does..
Check the agitator PAWLS. These are the small arms that make the agitator do what it does. They are located in side the agitator. You will see them when you remove the agitator.GOOD LUCK FRIEND.
Nov 27, 2014 | Kenmore Washing Machines
700LC will not spin
The older Hoover had a problem with the clutch drive seizing. Sometimes it was caused by the aluminium housing on the gearbox breaking or cracking. When this happens, the clutch pawl doesn't release the clutch gear properly. The clutch stays in the locked position and then it wont allow the tub to spin. Its not often the top bearing fails. A common sign of gearbox / clutch failure is a brown oily stain spread all over the inside of the cabinet in line with the bottom of the gearbox. This means that the gearbox has slowly filled with water through a failed gearbox seal and when it gets to this stage, its not an economical repair. Time for a new washer unfortunately.
Feb 22, 2014 | Hoover Washing Machines
The agitator was not working correctly. I did the work myself but im stuck trying to put the clutch/brake assembly together & on. The unit is Whirlpool Ultimate care 2. Mod# LSQ9544KTO SER#...
Hi and welcome to FixYa, I am Kelly
Here is a video that should solve the mystery:
This does a much better job than any text that I could post here but just in case take a look at this Whirlpool Job Aid L-55 for Direct Drive Washers. Page 17 shows how to set the Neutral Drain on the Brake Pawl. Also see pdf page 20.
Between the video and the Manual this should help you.
Thanks for choosing FixYa,
Kelly
Aug 09, 2011 | Washing Machines
My Whirlpool Fully Automatic Washing machine has some problem with WASH process, the agitator is not all working but the SPIN process, SOAK process are going on fine. Some scratching sound was heard from...
Most Whirlpool washers have ratchet type pawls in the agitator. If it is like mine, the top of the agitator pops off where you would ad softener detergent (in the center top of the agitator) and you will see the ratchet pawls inside the agitator. Mine we worn out and doing the same thing. I replaced mine and the unit is working fine now.
Dec 01, 2010 | Washing Machines
1997 sportster 883....intermittent gears not engaging
There could be several problems here. One problem could be the way you're shifting the gears. I've been riding for over 40 years and I still miss a gear every now and then due to sloppy shifiting.
If you don't think this might be the problem, you may want to check your clutch adjustment to make sure the clutch is disengaging. The easy way to tell this is to put the transmission in low gear, the start the bike with the lever held in. Does the bike lurch forward or have a strong tendency to "pull" the bike with the clutch completely pulled? If so, adjust the clutch mechanism.
Next, your shifter pawl may be getting ready to give up the ghost. These year model Sporty's are notorious for shifter pawl carrier failure. They are not difficult to replace for someone with a good basic mechanical ability.
Mar 25, 2010 | 2004 Harley Davidson XL 883 Sportster
Agitator top to bottom rotation seperation
387091 is the part called agitator clutch or dogs,they are little yellow pieces of plastic with teeth on the ends to grip the agitator and turn in it the teeth are worn off of yours..
Sep 02, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Trans will not disengage
either you have something stuck betwwen the two tubs(ie. a sock. ) preventing the tub from free spinning.or there is a clutch mounted on top of the transmission not engaging, as far the agitator not spinning correctly sounds liek the agitaor dawgs are stripped preventing proper agitaing(bottom of agitator works fine but upper portion free spins both ways without resistance?? correct??
Mar 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator problems
sounds as if the transmission agitator pawl is slipping. inside the transmission is a gear connected to the agitator. there is a spring loaded pawl that rotates around the center and engages its pawl or hook into the agitator gear for each rotation. either the pawl hook is worn or the agitator gear is rounded off. the transmission must be opened up to see what is a miss
Aug 22, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
