Question about Hoover H130E Front Load Washer
HOOVER h130e START AND SUPER WASH LIGHT KEEPS FLASHING
My Hoover H130E has come to the end of the wash cycle but now the start light and the super wash light keep flashing and the door lock light is still on.
4 Suggested Answers
  • 101 Answers
SOURCE: Door on the Hoover washing machine, model H130E
make sure the tap is not broken off ,if the tap is good that means you switch is bad, replace it. hope this information could help you.
Posted on Apr 23, 2008
  • 101 Answers
SOURCE: How can I fix my Hoover Washing Machine, model H130E?
which light?
rylee_smith
  • 8619 Answers
SOURCE: Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 18, 2010
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
After a power cut my washer wont work the door security light just keeps flashing! Model Hoover Vision HD
Ihave a Hoover Vision HD washing machine and the "Door Security" light keeps flashing. I have looked in the manual and it says the door is not properly shut. However the door is correctly shut and as a result the machine will not operate . The door will open or close but will not start a cycle to wash. Any suggestions please????
Apr 24, 2011 | Hoover Washing Machines
Hoover H130E 'Superwash' and start light flashing after cycle....
You might try unplugging the power cord for 5 minutes, then restore power again. Try the machine again--if still has problems (beat son severely), you may have to replace the control unit.
Aug 11, 2009 | Washing Machines
Washer wont start or reset
All I did was clean the filter behind the kick plate. Works fine now.
Sep 13, 2008 | Hoover H130E Front Load Washer
My hoover washing machine 1400 spin 8kg hd vision hd
Hi On my washer when I press the start button when allready in opperation all the lkights flash and it stops as this second press of the button pauses the machine and need the start button to be pressed again to restart the machine
Hope that is cleas and helps
Angela
Jun 22, 2008 | Hoover H130E Front Load Washer
Apr 23, 2008 | Hoover H130E Front Load Washer
Hoover 1300 washing machine
hi there this is a common fault you will need to replace the control module and selector switch/timer
Dec 01, 2007 | Hoover H130E Front Load Washer
Washer not spinning right and not completing a cycle
Sounds like you need to replace the carbon brushes on your washing machine motor
Sep 26, 2006 | Hoover H130E Front Load Washer
Hoover H130E Front Load Washer Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
