Question about Craftsman Crafts & Hobbies
Lubricate staple gun - Craftsman Crafts & Hobbies
  • 2712 Answers
SOURCE: staple gun support
Know the types of staple guns available. They can be manual, electric, battery operated or run by compressed air with an air compressor. Some staple guns have guide wires because they’re used by electricians that can’t pierce wires. Others have long noses to work well in corners and tight spaces. There’s also a reverse built ergonomic staple gun called a "forward action" because the handle and the staple’s exit point are on the same end of the staple gun. Some staple guns can shoot brads instead of staples. Know how each type of staple gun works. This one is so simple because it works just like a stapler. You press and hold the silver latch on the back of the stapler to open the body. Take the tray out and fill it with staples. Then it’s ready to use. Just put the staple ejecting end on your piece to be stapled and squeeze it. There is also the forward action manual gun which is used by pushing the handle down, too. The handle is just located near the staple ejection site. Use an electric staple gun for effortless stapling. There’s no need to squeeze or apply any pressure on these guns. They come with a very short cord so you will always need to have an extension cord with your staple gun. You can also go with a rechargeable battery operated cordless staple gun. They are great but they do run out of steam so for long use one with a cord is better. They’re also pretty easy on the wallet these days, so there’s no reason to go without this in your home tool kit as it’s something that does a lot of jobs. Know the versatility of the staple gun. Whether you have a manual or an electric model, these are some of the most versatile tools out there. You can use them to recover furniture, to build a birdhouse, to staple lattice to a patio, to build lightweight projects like a small knick knack shelf and to do wiring work.
Posted on Aug 27, 2008
SOURCE: staple gun
Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
Posted on Nov 25, 2008
danny_murray
  • 55 Answers
SOURCE: Need help on how to put staples in Ace staple gun 22084
At the very botton of the stapeler in the back there should be a square mechanism press in and down then just slide the staples in and eplace the mechanism the way you took it out
Posted on Dec 05, 2008
joboo1
  • 257 Answers
SOURCE: Haubold 1400 series Staple Gun has blown an ''o'' ring.
Hi, I repair lots of tools and ended up buying a complete like 2000 part o ring kit I keep in my shop, it has proven invaluable, If you can't find the o ring at a hardware store, give ample supply a call and see if they can help you, their number is 1-800-339-5667.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Mar 27, 2009
  • 3 Answers
SOURCE: I have a PowerFast staple gun #31600. Can not
I got some staples stuck in my Powerfast 31600 too. I THOUGHT they were the right staples, I was wrong. You have to bend a little tab on the bottom of the stapler to let the slide come out of the back. Then you can remove the staples. Replace the slide and tap the tab back into place with a punch.
Posted on Aug 11, 2010
Why is my Stanley TRE 500 locking up after stapling a short time. What is the + and - on top for? I have lost my manual.
Make sure you are using the right staples for it. This will prevent lockups. You can also try spraying the staple track with a dry silicone lubricant.
The Plus and Minus is to set the strike pressure. Low for cork board, high for oak paneling.
Here is the manual, the TRE550 is close enough.
Stanley TRE550 Electric Staple Brad Nail Gun
Sep 21, 2014 | Electric Stanley Tre500 Staple Gun /...
Been using stapler for past hour suddenley trigger
Could be a bad power cord: broken wire at the switch; a bad switch; the stapler needs lubrication; or the stapler is shot.
Jun 19, 2014 | Stanley Tools TRE550 Electric Staple/Brad...
Bostitch nail gun number SB-21n1 is jammed and need manual to know how to unjam it or a solution online. Was using it in the staple mode and it jammed after about 5 staples. Was using bostitch staples.
Hello. Begin by disconnecting the air hose. That way you can not get hurt while removing the jam. Get a pair of needle nosed pliers and remove each of the jammed staples. They will pull out I assure you. Then Use a little WD-40 or compressor oil to lubricate the working mechanism at the firing head. IF you must loosen up the mechanism to remove all of the staple parts be sure to use the correct size allen wrench. I am providing link to a free manual for your gun in case you don't have one: http://bostitch.com/catalog_images/web_pdf/107674.pdf
Jan 12, 2010 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
How do you adjust the staple size to load 1/2" or 1/4" staples?
Staple guns can use a variety of staples; the width of the staple is fixed, the lengths vary from 1/4" up (usually in 1/8" increments). You don't need to adjust the staple gun for the different lengths, just be sure the width fits your gun since some manufacturers have used brand-specific staples.
There are also a variety of staple types; there are staples for ceiling tile, electric wire, window screening, etc. My favorite staples for wood have the tips cut on a sharp angle, they penetrate wood well. Some staple types require a particular gun, I have a gun that shoots only round-top staples for small cables like phone & thermostat wire.
Dec 05, 2009 | Stanley CT10C Heavy Duty Staple Gun/Cable...
Will not staple - sounds like a blender.
Usually, disassembling the stapler and clenaing/lubricating it will solve this problem. Sounds like the solenoid is chattering because it's not operating freely. Use something akin to 3-IN-1 machine oil to lubricate all moving parts.
Charlie
Aug 20, 2009 | Staples Tools & Hardware - Others
How to repair jammed arrow electo matic staple gun
You'll have to disassemble it. There is probably a staple lodged in the "hammer" mechanism on the business end of the stapler.
Often, these staple are very difficult to remove -- a very small flat-tip screwdriver and needle-nose pliers usually work best.
After you get all the jammed staples out, lubricate all moving parts with something akin to 3-IN-1 machine oil. This should prevent future jams.
Charlie
Aug 20, 2009 | Heavy Duty 648967 Arrow Electric Staple...
My electric staple gun won't work.
Plug and do you feel humming if so lubricate with wd 40 if no hum it is burnt up and throw away.
Mar 16, 2009 | Arrow 8000 Power Shot Pro Staple & Nail...
Dec 03, 2008 | Ace Hardware Ace Staple Gun
Staple Gun Troubleshooting
Most of the staple gun models lack an "anvil" — the metal plate with curved slots that office staplers use to bend the legs of the staple inwards and flattens them against the paper. Staples set with a staple gun retain their straight legs, and are held in place only by static friction of the legs against the compressed surrounding material, much like common nails. Indeed, some staple gun models can handle brads and nails as well as staples. Some staple guns also use divergent point staples where the legs twist as the staple drives into the surface providing superior holding power.
Aug 27, 2008 | Arrow T59 Wire & cable staple gun
Crafts & Hobbies Logo
44 people viewed this question
Top Craftsman Crafts & Hobbies Experts
Kazim ERGUNEY
Kazim ERGUNEY
Raymond Ramirez
Raymond Ramirez
Are you a Craftsman Craft and Hobby Expert? Answer questions, earn points and help others
