How to change text COLOR - Computers & Internet
Where in the settings is text and subtitle font/color options?
I believe you are talking about imessage, no you can't change the color or font, you can change the text size though which is under settings, generals and text size. The color blue means it's a imessage sent using your mobile data/wifi, a green message means a traditional text message sent using your non-data mobile network
Sep 14, 2014 | Apple iPhone 4S
Corel Draw 8 - Can the color of the underline below the text be changed, a different color than the text?
yes right click any color u r chose any color right click for underline and left click for text color
Jan 28, 2013 | Corel Draw 8
Corel Draw 8 - Can you the color of the underline below the text be changed, a different color than the text?
right click for the any color u need change the underline color and F12 for line thickness (punch F12 and open new dialog box select 1, 2 what ever u want give thickness value then click ok or enter )
Hi When I write text in messenger, I press enter but my text does not appear in the chat box Any clues? Thanks Michael
This is all I can think of. Is there any chance that your text color is set to white?
The way to check the text color setting is to click on the text icon (a capital T with a box around it). And then click on the little color palette icon and check to see what color is selected.
Also changes in settings some times require you to close and open a window to take effect.
Restart the program to see if that helps.
HTH
Jun 16, 2011 | Yahoo Messenger
I need to change fonts & text colors. I can't see
If you are using Windows 7 then goto Control Panel , in that you can see "fonts" double click on it , then it shows font style etc , by this u can change fonts and text colors etc.
May 27, 2011 | Toshiba Computers & Internet
How to change the color of the background?
This is pulled from the tutorial PDF:
================================ DESIGNING YOUR MENU Now that your content is added, you can customize the look and feel of your menu. You can change the background, title, and chapter button layout and text. Before changing your text, it's recommended that you set your background first. Often, the color of your text will be dependent on the background color. A good amount of contrast between the colors is necessary to ensure that the text stands out clearly ================================
The option to change the background is in the Themes tab.
Mar 02, 2011 | Arcsoft ShowBiz DVD 2 (3265)
Misfiring escape 2003
Check timing/ timing belt. May have jumped one cog.Remove and replace.
Jun 07, 2009 | 2003 Ford Escape
I want to change the color of the text on the start screen. The text is white and I am using a light colored background picture. Does anyone know how to change the text color?
I finally found "tdyscheme changer"
http://mobisapienz.com/index.php?option=com_jdownloads&Itemid=82&task=view.download&cid=74
The name of this is UI Tweaker and it contains the TdyScheme Changer. Works like a charm! Thank you for your response!
Feb 18, 2009 | AT&T 8925 Tilt Smartphone
Vb6
You can bold a selected text by pressing Ctrl+B.
I dont think you can color a highlighted text at runtime because colors have to be selected from the toolbar.
If this has helped you please press solved.
Nov 17, 2007 | Computers & Internet
Computers & Internet Logo
335 people viewed this question
David Payne
David Payne
