Question about Nautilus T914 Commercial Series Treadmill
Sys overload system overload
Mid 90,s custom harley build w. 32 amp sys new everything stator puts out 48 v. 2 new regs both ck ok. only bat v. at bat. simple 1 wire to bat. puts out 12.3 at 3000 rpm. sugestions?? anybody???
check for a missing wire to the battery as the voltage regulators are not controlling anything
if you have a 32 amp alternator and it is producing 48 amps , the voltage regulator is not controlling the out put of the stator so it will burn out from overload
voltage from the stator has to be 13.2 volts DC minimum and no more than 14.5 v DC at 2,000rpms
suggest that you get an accredited bike electrician to check out the circuits and system
Jun 28, 2017 | Harley Davidson Motorcycles
Missing Usbccgp.sys
What is usbccgp.sys?
Microsoft USB generic printer driver system driver file. This usbccgp.sys file is safe and should not be considered threat to your computer.
Download this update from this link and install:
http://support.microsoft.com/kb/814560
Otherwise uninstall and reinstall the printer driver (if you have any) on your PC.
Sep 23, 2012 | Computers & Internet
I need a diagram for the fuse box in my 1995 ford explorer
See Below.
Hope this helps.
Zeppelinx12
Fuse Panel, Explorer
EXPLORER FUSE PANEL Fuse Position Rating Circuit Protected 1 10 Amp Power Mirrors/Antenna 2 10 Amp Air Bag/Blower Relay 3 15 Amp Parking Lamps 4 15 Amp Left Headlamp 5 10 Amp On Board Diagnostic II System 6 15 Amp HO2S Sensors 7 10 Amp Illumination Switches 8 15 Amp Right Headlamp/Fog Lamp System 9 10 Amp EATC Mem./Seat Mem./Mess. Ctr./Cell. Phone 10 10 Amp EATC Sys./Rear Blower/Spd. Control/GEM Sys./Brake Interlock/OH Console Adapt. Susp. 11 10 Amp Warning Lamps 12 10 Amp Front and Rear Washers 13 15 Amp PCM Sys./Stoplamps/4WD/
ABS/Spd. Control/Trailer Tow 14 10 Amp Anti-Lock System 15 15 Amp Air Bag System/Alternator 16 30 Amp Front Wiper 17 30 Amp Cigar Lighter 18 15 Amp A/C System 19 25 Amp Ignition Coil/PCM System 20 10 Amp Radio/Power Ant./GEM Sys./Anti-Theft/Cell. Phone 21 15 Amp Hazard Lamps 22 15 Amp Turn Signals 23 15 Amp Rear Wiper System 24 15 Amp Starter Relay/Anti-Theft 25 10 Amp Speedometer/GEM System 26 15 Amp A4LDE Trans/DRL Sys./Backup Lamps/4WD/Rear Defroster 27 15 Amp Under Hood LP/Map Lights/Glove Box Lamp/Dome Lamp/Visor Lamps/Accessory Delay/DR Switch Illum./4x4 System 28 10 Amp Memory Seat/GEM System 29 15 Amp Audio System 30 - Not Used 31 10 Amp Aux. Blower System 32 10 Amp Heated Mirrors/Heated Backlite 33 20 Amp High Beam Lamps 34 10 Amp Audio System/Power Antenna 35 - Not Used 36 - Not Used
Feb 24, 2011 | Ford Explorer Cars & Trucks
Spcmd.sys
The file "spcmd.sys" is known to be created under the following filenames: %System%\cc.sys %System%\dboy1.sys %System%\g3i2ll.sys %System%\setuplk.exe %System%\setuplk.sys %System%\spcmd.sys %System%\tencent.sys %System%\zzjkxs.sys %Temp%\xpanxionvirus\a1.exe %Temp%\xpanxionvirus\a2.exe %Temp%\xpanxionvirus\tmd.exe %Temp%\xpanxionvirus\tmd1.exe %Temp%\xpanxionvirus\tmd2.exe %Temp%\xpanxionvirus3\boot.exe %Temp%\xpanxionvirus3\cc.exe %Temp%\xpanxionvirus3\s.exe %Temp%\xpanxionvirus3\sc.exe %Temp%\xpanxionvirus3\se.exe %Windir%\a1.exe %Windir%\a2.exe %Windir%\s.exe %Windir%\se.exe %Windir%\tmd.exe %Windir%\tmd1.exe %Windir%\tmd2.exe c:\boot.exe c:\cc.exe c:\sc.exe Go to this link for more info http://www.threatexpert.com/files/spcmd.sys.html it is said to be of no threat.
Your timely rating of this soloution is much appreciated.
Thanks
Nov 01, 2010 | Computers & Internet
Acer recovery disk download
i keep getting this on my lap top and cant get ride of it can you help me??
Multi (0)disk(0) rdisk (0) partition (2)\Windows\AppPatch\drvmain.sdb
TRAP 00000006================EXCETION================
multi(0)disk(0)rdisk (0) partition (2) \WINDOWS \system32\DRIVERS\WMILIB.SYS
multi(0)disk(0)rdisk (0) partition (2) \WINDOWS \system32\DRIVERS\pci.sys
tr=0028 cr0=80000013 cr2=00000000 cr3=00039000em32\DRIVERS\isapnp.sys
gdt limit=03FF base=0003F000 idt limit=07FF base=0003F400compbatt.sys
multi(0) disk(0) rdisk(0) partition(2) WINDOWS\system32\DRIVERS\BATTC.SYS
cs:eip=0008:0009F737 ss:esp=0010:000600EC errcode=0000IVERS\pciide.sys
flags=00010012 NoCy NoZr IntDis Down TrapDis ystem32\DRIVERS\PCIIDEX.SYS
eax=00000000 ebx=00000100 ecx=0000BB40 edx=00030715 ds=0010 es=0010sys
edi=00060D4C esi=00000000 ebp=00060E34 cr0=80000013 fs=0030 gs=0000s
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\ACPIEC.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\OPRGHDLR.SYS
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\PartMgr.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\VolSnap.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\atapi.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\disk.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\CLASSPNP.SYS
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\drivers\fltmgr.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\sr.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\KSecDD.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\Ntfs.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\DNIS.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\Mup.sys
Feb 06, 2010 | Acer Aspire 5315 Notebook
All my usb ports are not working when i connect any pen drives or external hard disk or bluetooth deice my computer doesn't read them what should i do?
Plese make sure that your USB port is enabled in BIOS Mode,
if it is enabled make this steps....
Download USB Driver files....
usbehci.sys
usbport.sys
usbhub.sys
usbui.dll
usbccgp.sys
usbohci.sys
Feb 20, 2009 | Microsoft Windows XP Professional With...
Kstvtune.ax
ALCXWDM.SYS
portcls.sys
ksxbar.ax
kswdmcap.ax
vidcap.ax
vfwwdm32.dll
CCDECODE.sys
NABTSFEC.sys
WSTCODEC.SYS
ipsink.ax
MSTEE.sys
isapnp.sys
usbuhci.sys
usbuhci.sys
stream.sys
wdmaud.drv
ks.sys
ksproxy.ax
drmk.sys
ksuser.dll
I can't install my multimedia as these files are missing. I tried reinstalling the drivers but it needed these files which I can't download even after I have inserted the Windows XP Cd. Can you please help me with this also let me know how I can download these files from the net.
Jun 02, 2008 | Microsoft Windows XP Professional With...
USB
checked my XP via control panel: usbhub.sys usbohci.sys usbport.sys usbui.sys good luck...may be difficult to force drivers...when system asks to install software, insert the original XP cd. The driver did not change with SP2, as far as I know.
Aug 18, 2007 | Microsoft Windows XP Professional With...
Armada E500
using edlin you can enter for config sys device=c:\dos\himem.sys device=c:\dos\emm386.exe noems device=c:\dos\cdrom.sys /d:mscd001 /l:e for autoexec bat @c:\dos\mscdex.exe /d:mscd001 ----------------------------------- config sys himem.sys is the upper memory manager emm386.exe is the 'gate' to allow access or combine all of it noems turns off expanded memory cdrom.sys is the CD Driver - yours may have a different name /d:mscd001 refers to the name of the CD Rom Drive (generic) /l:e refers to the drive letter (e:) to designate for the CD Hope that helps If used, rate me
Nov 11, 2006 | Compaq Armada E500 Notebook
Nautilus T914 Commercial Series Treadmill Logo
52 people viewed this question
Top Nautilus Exercise & Fitness Experts
David Payne
David Payne
Electro Med Services...
Techmotionusa.com
Techmotionusa.com
Are you a Nautilus Exercise and Fitnes Expert? Answer questions, earn points and help others
