Question about Michley Lil Sew Mechanical Sewing Machine
Take up lever gets stuck on lil sew and sew 505
Where can i buy bobbin case/hook race for LSS 505 mode michley lil sew& sew
Any local sewing machine sales and service business can get this fro you.
Apr 14, 2017 | Michley Sewing Machines
How do I thread bobbin?
Here is a good amount of help on the Lil Sew:
https://video.search.yahoo.com/yhs/search;_ylt=A86.J796POdVyGEAKrknnIlQ?p=Lil+Sew+%26+Sew+Michley+Mini+Sewing+Machine&fr=yhs-mozilla-002&fr2=piv-web&hspart=mozilla&hsimp=yhs-002
Sep 02, 2015 | Lil Sew & Sew Michley Mini Sewing Machine
I have just purchased an LSS-505 machine and I have not been able to get sewing yet. The bobbin thread tangles after about 3 stitches. I have done all the troubleshooting that I know to do, changed n
YOUR BOBBIN IS TOO BIG, when the upper thread passes over
to create the stitch it catches on the rim of the bobbin. Make sure there is no lint caught under it or in it's cradle.
Oct 14, 2014 | Michley Electronics, Inc Lil Sew & Sew...
My brand new lil sew and sew lss 505 will not turn on
When you say it will not turn is it the hand wheel stuck or the motor will not run it. If it is the motor check the position of the bobbin winder. It may be jammed with thread. Remove the bobbin case/basket and look try to turn it by hand.
Apr 29, 2014 | Sewing Machines
The lever on my machine for dwing backwards seems to be stuck or broken
then it would be a good idea to have the machine serviced
to find out if the lever is broken or stuck.
Feb 22, 2013 | Janome 1600P-DB Mechanical Sewing Machine
Lever is stuck in reverse
If the stitch length bar, which is located on the right side of the machine, is in the up position move it down to where the numbers are. Those numbers are referring to how many stitches the machine will sew in an inch. Therefore, if you put it on 10, your machine will sew 10 stitches per inch. It being up will cause your machine to go in reverse.
Jul 26, 2009 | Brother LS-1217 Mechanical Sewing Machine
Bobbin problem
Remove the race cover and jiggle it out. It is only stuck in there with thread.
O
oil the machine first. Then, determine whether or not you need any parts at all.
Jun 25, 2009 | Sew D'Lite SM-888 Mechanical Sewing...
Stuck in reverse
The reverse button is attached to link that moves a lever to make the machine sew in reverse. The lever is spring loaded so it returns to forward sewing when the button is released. Either the spring has come off or there is a bind in the lever(oil it). In order to solve the problem, the covers must be removed.
Oct 26, 2007 | Kenmore 15208 Mechanical Sewing Machine
Michley Lil Sew Mechanical Sewing Machine Logo
62 people viewed this question
Top Michley Sewing Machines Experts
erebooni
Level 1 Expert
Robin Hill
Robin Hill
Are you a Michley Sewing Machine Expert? Answer questions, earn points and help others
