Question about Sewing Machines
Brother VX 1120 bobbin won't movepromising brother VX 1120 the bobbin won't move
2 Suggested Answers
SOURCE: Brother VX-1120- The needle is not picking up bobbin thread.
I had the same problem with my brother vx-1120 sewing machine. I set the needle to lowest position by using the hand crank. Then I loosened the knerled set screw that holds needle in place. Then I moved needle shaft till the eye of needle is just lower than the hook on the shuttle loop maker. It made my mechine work. There are instuctions for ajusting timing on machine but I think these mechines are built to not fix and throw out. Just because there where no ajustment marks at all on machine, any machanical machine will needed to be ajusted sometime.
Posted on Oct 30, 2010
How do I reset the timing on my brother vx 1120 model?
Be sure to install a brand new needle.
If it still doesn't work, then search for "sewing machine timing."
Jul 28, 2017 | Brother Sewing Machines
I have a brother vx1100 sewing machine and I forgot how to combine the bobin thread with the upper thread to start sewing please help
ono secret
just pull the bobbin thread down the slot in the bobbin holder and under the spring plate
leave about 6 " thread loose and put the bobbin and holder back in the machine
use you hand and turn the machine over a few times and the needle thread will pull the bobbin thread up
or use a bit of scrap material and start a short sew
Jan 15, 2017 | Brother Sewing Machines
My brother vx-1120 needle wont pick up bobbin thread to make a continuous stitch
Install a brand new needle. Make sure it is installed correctly.
Remove the bobbin/bobbin case from the machine. Check that the bobbin is turning the correct direction and the bobbin tension is threaded correctly. Reinstall the bobbin case and confirm that it is latched into place.
Retest your machine. Slowly turn the handwheel and watch the needle descend and see if it picks up the bobbin thread. If not, then there is probably a sewing machine timing issue. Take it for service.
Nov 01, 2016 | Brother Sewing Machines
Manual brother vx-1130
Sue, I will post links below for your manual.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Brother VX 1120 User Manual
Brother VX 1120 Sewing Machine Threading Diagram
Manual BROTHER VX1130 Operating Instructions Service
Brother VX 1120 Sewing Machine Troubleshooting eHow
Mar 03, 2016 | Brother Sewing Machines
Shuttle on a Brother VX-1120 sewing machine will not pick up the bobbin thread
Bobbin in backwards, needle in backwards, needle damaged, needle too small for the thickness of fabric or needle not the correct needle system for the machine are my first guesses. Try a new size 12/80 needle, flat of the needle to the back of the machine, completely up in the needle clamp as a first pass at the problem.
Feb 18, 2014 | Brother Sewing Machines
Brother VX 1120 sewing machine bobbin holder missing
you can buy one from this website.
http://www.sewingpartsonline.com/bobbin-case-class-15-japan-made-jo1313z-j.aspx
Jan 27, 2010 | Sewing Machines
Jul 08, 2008 | Brother CS-8150 Computerized Sewing...
Bobbin thread will not pick up nor will dog feed rise
my Brother sewing machine model VX 1120 will not pick up the Bobbin Thread. Machine is fairly new with only several hours use. I have changed needles , tried different bobbins, cleaned the machine. Any suggestions?
Jul 06, 2008 | Sewing Machines
Sewing Machines Logo
15 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
