Question about Friedrich Heating & Cooling
Mini split error codes
How to find error code for friedrich split system
5 Suggested Answers
SOURCE: Friedrich Mini-Split blowing fuse
Low voltage shorts can be a real pain to find!!! i would try a process of ellimination: first i would try to elliminate the thermostat. then id look for a wire that is vibrating on something in the cabinet.
Posted on Oct 16, 2007
  • 400 Answers
SOURCE: GE mini-Split Error code
Replace the indoor pc board and thermistor.
Posted on Mar 20, 2009
SOURCE: LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
CA: Compressor Discharge Sensor Fault
Contact a qualified service technician and have them replace this sensor.
Posted on May 04, 2010
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
New LG mini split installation getting error CH05
I believe the wiring may be incorrect. Here arethe fault codes.
05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
5
Hope this helps
Bob
Aug 08, 2014 | LG LA120HYV Art Cool Premier 120HYV Ultra...
Friedrich cp24g30a code of ch 34
Friedrich Room Air Conditioner Service & Parts Manual 2014-2015
CP15 & CP18 & CP24
ERROR CODE
CH34 High Pressure Error Fault Codes -- As high pressure,comp off over 10 times in 1 hour
UPDATE: 9/24/17 -- So, after multiple plot twists with the particular AC that kept giving us this error message and shutting off, we finally got to the bottom of the situation. This model is supposed to be a WINDOW sleeve and WALL sleeve installed capable AC. When it failed, we had it installed in a wall sleeve (proper size), but apparrently it was not vented properly. (Of course, we did not know that for nearly 4 years.) To keep this story clear, I am going to refer to two ACs: "Bob AC" the unit with heat that gave us these error messages and "Stanley AC" the unit without heat that was essentially the same unit that did not give these messages.
When we first bought and installed "BOB AC", it failed within 1 month --and out of desperation, we pulled it from its wall sleeve and put it in a different location in our office but this time it went into in a window sleeve. We put "Stanley AC" which was in another location in our office in a window sleeve into "Bob AC's" wall sleeve.
Also for clarity, we have 4 of these ACs in our offices, but this "BOB AC" when it failed was brand new and als was the only one that also has HEAT. That said, with respect to BTU and dimensions, all our ACs are the same.
So when we moved "Stanley AC" into "Bob's" wall sleeve, it fit and worked and did not give us that same error message and "worked", but it also did not really cool our showroom. Also, what would happen is that the Stanley ACs would just up and die one day. (Yes that means there was more than 1 Stanley that we killed.) So during the hottest week in the summer of 2017, our latest "Stanley AC", the CP24g30 that we put 2 years ago in that same wall sleeve where "BOB AC" used to be - suddenly up and died. Because "BOB AC" had been working for the past two years amazingly well in the window sleeve we moved it to after it failed in the original wall sleeve, I decided to moved "BOB AC" back into the wall sleeve where it originally failed. And, as you might expect -- "BOB AC" failed within 2 hours of installation.
Now, we had all sorts of theories as to why the Bob and Stanley ACs failed. One of my team was certain the failure was caused from the AC being in direct sunlight. I didn't agree, but when "BOB AC" was in the window sleeve and working perfectly -- it was even a bit too cold in the zone he was working, the unit was out of direct sunlight. (FYI - I did find info on direct sunlight -- it will impair an AC's efficiency, but it should not cause this failure.)
A friend who is an engineer came to examine the situation and he believed that the problem was based on our neighbor building having a large HVAC pointing its exhaust directly at our AC's vent. His theory was that the hot exhaust was overpowering our AC's ability to vent, and he told us to install a sheetmetal barrier over the back of our AC's sleeve to block the other buildings exhaust from going into our AC. Ironically this sheetmetal solution may have been the reason that "Stanley AC" died.
Anyhow since Stanley AC never really cooled our showroom even after we installed the barrier my friend recommended, I kept researching what might be the problem. Finally after having a strange conversation with an AC specialist who insisted that I was using a window AC in a wall which is a "no-no", I went back to research the install instructions to verify that I was not crazy. And, there in the install instructions I found the answers.
First off, the unit IS both a window and wall AC -- so I was not just forcing a square peg into a round hole. But, for any unit of large capacity that is going to be put through a wall, the key issue for the unit is going to be about ventilation. Why does the capacity matter? It matters because some lower capacity models have been designed to vent ONLy thru the rear of the AC. (BTW those models are very low BTU like 14k and are very expensive like $1000. Our unit is 24k and cost roughly $800.)
Anyhow in re-reading the installation instructions (which I never bothered to read because I had the unit installed by "experts") it talked about wall thickness and how much of the AC needed to be exposed for proper venting. The answer BTW is that at least 14" should be venting outside of the wall.
As a point of reference, when "BOB AC" was installed in the window sleeve were it worked PERFECTLY -- only 3" of the face of the AC was inside the room and the remaining 23" of sleeve and AC were outside the window...but when both "Bob and Stanley AC" were installed in the Wall sleeve where Bob almost immediately failed and Stanley worked (poorly) until he died, it was very different -- probably 9" inside the showroom, then about 9" of wall, and then about 6" of the back-end of the AC extending out of the wall sleeve outside the building.
Essentially and bottom line, we had installed the sleeve incorrectly and the ACs were baking themselves and then dying. In other words, they were NOT venting properly at all.
So, after a lot of debate with my trusted handyman, we pulled the AC out and he wrestled with the sleeve and pulled it out of the wall and additional 9 inches. Now 14" of the wall sleeve are exposed to air out of the back of the building. We reinserted the AC -- and now: 1) NO MORE ERROR MESSAGES; 2) NO MORE INSTANT SHUTOFF and even more amazingly - -3) "Bob AC" is working PERFECTLY and the room is now actually COOLED by Bob. (Remember, when we had "Stanley AC" in the same spot, while it did not fail the same way or as quickly -- it also did not cool the room. Had we known we were not venting it correctly, poor Stanley might have lived a long, happy life and kept us cool. )
Hope this long story helps others. Good luck.
Jul 11, 2014 | Friedrich Chill CP24G30A 23500 BTU Window...
My mini split system had an E2 code...replaced indoor pipe sensor...indoor unit works but outside unit does not...no other error codes, just motor not working outside
Check the outdoor unit to ensure power is available to it, and the contactor is closing on a call for cool 24-28 volt is present at the contactor coil to activate it.
Aug 24, 2013 | Continental Electric CE-AC7581 Ductless...
Friedrich ductless heat pump will not start up.
Did you check to see if the compressor is running? Check out start relay/capacitor.
Sep 21, 2017 | Heating & Cooling
After lightning MW12C1E replaced burned fuse on power circuit unit satrt then flashing green LED then stop how to read error code ?
If you had a major surge then chances are the entire outdoor PCB and possibly the inverter transformer need to be replaced. I'm not as familiar with the Friedrichs but most mini-splits use flash code errors on both the outdoor and indoor units, occasionally with the common codes printed on one of the outdoor service panels, usually only in the service manual (supplied to authorized dealers and sometimes available from manufacturers websites).
Sep 22, 2011 | Friedrich Heating & Cooling
I have a friedrich ductless split m# mw24cy3f .. call for cool only fan runs inside, call for heat nothing runs, outdoor temp at the moment is 38 degrees, error code light blinks on indoor unit......
not able to find the error codes for the unit number you gave but, here is a number you can call to get them. sorry not more help.
1-866-793-0323 spacer.gif Mon - Fri 9:00am to 6:00pm EST
Dec 20, 2010 | Friedrich Heating & Cooling
I have a Friedrich Split system model MW18Y3Y w heat. When I put on the heat, I am getting a trouble code of 5 flashing operation/timer and than a single timer flash. What could be the problem?
I'm having the exact same problem, same model. My guess at this point is that the outdoor unit fan has been iced up due to recent heavy snows. I have a shop light hooked up to thaw things out and will re-check in the AM
Dec 27, 2009 | Friedrich MW18Y3FM Split System Air...
Oct 11, 2007 | Friedrich M18CE Air Conditioner
Heating & Cooling Logo
161 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
