Question about Baumatic 23 in. BDW13 Built-in Dishwasher
The bottom arm of my baumatic dishwasher is not turning
It is a bdw13 or bdw14. the arm spins freely when you hit it.
SOURCE: i need to reset my dishwasher but don't know how!!
bdw13 showing e4 & trying to empty when no water in it
Posted on Apr 16, 2007
SOURCE: I have a Frigidaire Ultra
I may have the answer. I had what sounded to be the same problem. I found the dishes were dirty after they were cleaned, but I found there may have been a big pot lid blocking the upper arm. I decided to run the machine again, and after a bit opened the dishwasher after to make sure it was not a problem with the arm. Sure enough, the arm wasn't moving. However, I found out on the Frigidaire webpage that some models have an alternating spray cycle, where only one arm spins at any given time. After reading this I checked again, and it had moved by that time. I checked a few times more to confirm this. So it ended up it was an arm blockage after all. Hope this helped...good luck.
www.frigidaire.com/support/FAQ-Dishwasher.asp#6
Posted on Dec 14, 2008
SOURCE: Baumatic BDW13 14 dishwasher SHowing E3 Fault
word_answers.gif I had the same problem and changed the two thermostats on the base and got it working. You can get them from partmasters.co.uk (thermostat protector) cost 17.99. They just screw in and are dead easy to fit
Posted on Jan 23, 2009
Kgt1962
  • 59 Answers
SOURCE: Viking dishwasher not cleaning bottom rack of dishes
Yes there is the Water Div valve, it diverts the water between the wash arms.
Posted on Mar 11, 2009
  • 81 Answers
SOURCE: removed lower spray arm:ge gld5500 dishwasher. Can reinstall.
Yes!
Posted on Apr 24, 2009
There are no error codes showing, water is definately getting hot but dishes on bottom tray not cleaning, i have used few products specially designed to clean the dishwasher itself without any dishes in,...
Check that the arms spin freely when spun by hand, then check the outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. .
Jun 18, 2011 | Baumatic 23 in. BDW13 Built-in Dishwasher
Baumatic BDW13
I think that you may be on the half wash setting, check to see if the light labeled as number 4 is on while washing, if it is, then you need to simple turn off this option. Let me know if it isn't.
I will provide further assistance if needed, just let me know
otherwise Thank you for using Fixya, good luck and please don't forget to rate my solution when you solve the problem
Apr 24, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
I have a baumatic bdw13 dishwashers that is not washing correctly it is reachong correct temperature but not cleaning dishes correctly i have checked filters & put finish rinse aids through & still...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 25, 2011 | Baumatic 23 in. BDW13 Built-in Dishwasher
Error code E2
Error Code E2 means the pump is blocked. The remedy is to take the filter out which is underneath the bottom dish basket and ensure its is clean and free from debris. Then use a small container to empty the water sitting in the bottom of the machine/filter housing and ensure that no waste is stuck in the bottom. That should clear it
May 24, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Error code on my bdw13 dishwasher
Turn off the water and electric!
Its really easy to change the heater element, once you have taken out the dishwasher!, remove the bottom panel and remove the wiring to the element, slacken off the nut under the electrical contacts voila!, also it may be a faulty thermostat that you cannot reset and has to be replaced, I would do this at the same time, as again its easy with the bottom off.
May 03, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Baumatic bdw13
the top tray has a nozzle on rear,which pushes into a screw on rubber seal on inside rear of appliance.this splits and stops water being fed to sprayer on top tray.phone baumatic parts dept,only a few pence,but sent mine free!
Jan 09, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Beumatic
OK - sorted it finally!
If you, like me, had actually added water thinking that this would rinse the machine through... doh! you had inadvertantly made water fill the cavity at the bottom of the maching. This is situated behind the kick-board. There are 2 black plastic panels - if you remove these, (they just pop out) and sponge out the water that is activating the dip switch (there is a polystirene float) that activates the pump - this resolves the E4 error code.
Make sure you do it while the machine is off! The reason the base of the machine has filled with water may need further investigation, but mine was most definitely user error. Who'd of thought adding water to a dishwasher could have been so fatal! It nearly cost me £88 call out charge too after the helpline weren't able to help me.
Jun 25, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
Mar 08, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
I need to reset my dishwasher but don't know how!!
If it's any help then here is the link to the user manual (when you download it it applies to bdw13 as well even though it is labelled for the bdw14) http://www.baumatic.co.uk/products/discontinued-models/dishwashers/integrateddishwashers/BDW14 Best I could come up with is to try page 19 at the bottom of the "dishwasher doesn't run" section - there are two different types of reset which may do the job. Hope this helps :)
Mar 13, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
Baumatic 23 in. BDW13 Built-in Dishwasher Logo
77 people viewed this question
Top Baumatic Dishwashers Experts
Oloyede Monsuru
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
