Washer will not agitate
It fills up an just humms, adjitater will not move
5 Suggested Answers
SearsTechToo
  • 261 Answers
SOURCE: Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Posted on Oct 08, 2008
mgprice
  • 744 Answers
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Posted on Jul 19, 2009
  • 84 Answers
SOURCE: Amana washer won't agitate when full with laundry
The belt is probably worn down. Replace it.
Posted on Jan 17, 2010
TheMobilian
  • 8220 Answers
SOURCE: The washer filled with water but the agitater isn't moving making
That must be the drive coupling has gone bad.
Posted on Jun 18, 2010
Whirlpool ultimate care heavy duty leaks underneath, not agitate or spin. only humms and fills up
Again!! Any washer that does not drain has a bad Drain Pump. Very Common. I see this in 40-50% of the problems. Replace the drain pump and your washer will be very happy
Jan 19, 2014 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator humms and won't move
It hums since the motor is still working. However the mechanism for the agitation is not working due to the helix part worn out. Need to replace it. If the service man is coming, have him to check the spinning mechanism also, since the same labor for the 2 mechanism. if the agitation mechanism worn out then the spinning mechanism is going to wear out soon. Now keep in mind that the clutch and the brake for the spinning mechanism are hardly worn out, only the part pushing up to release the brake is worn out. Keep this in mind to prevent overcharged.
Jan 09, 2010 | Dryers
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
WASHER HUMMS BUT DOESN'T AGITATE
this sound i think come from motor so since there is no rotation the belt need to fit again or replaced by agood one,
g b y
Jul 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag A9400 washer won't agitate
the motor, sorry! if left on wash cycle it humms for a bit quits and trys again? or not? the motor is about $130.00 part# 201805
Jun 30, 2009 | Maytag Washing Machines
Washing machine will not fill with water. only agitates. will drain and will not spin only humms
unit should not agitate with no water. pressure switch has to be satisfied to begin wash cycle. what kind of washer?
Jun 21, 2009 | Washing Machines
Basket won't move-noise
do you notice if it agitates?
if it doesnt agitate it is just a simple coupling
if it is making a humm noise its the motor
if a LOUD rumble ONLY on spin cycle, its the basket drive assembly and the clutch.
May 29, 2009 | Whirlpool LSQ9610L Top Load Washer
Washer does not agitate
hi thanks for the question it looks like a problem with the transmission but only if afer the water fills the tub the motor starts running if te motor docent start after its full look for a timer problem . so if motor runs on wash cycle and no spin transmission problem thanks the appliance doc please rate me.
Feb 23, 2008 | Frigidaire FEX831CS Top Load Stacked...
Will agitate, but will not spin
hover gemini. mod.A6516-010 will agitate but will not spin.thanks .henry
Jan 01, 2008 | GE WDSR2080D Top Load Washer
Washing Machines Logo
106 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
