Question about Marantz CC-4000 5-Disc CD Changer
Philips as655 no display of graphics on tuner etc
Philips as6554/30 no display system works just no lights and tuner display etc ie lights out but they are at home
    Master:
  • 501 Answers
Ive found with the AS655 Ive been working on,the lights will come on after about2-5 mins of use.this isnt a fix,just a comment.
Posted on Jul 21, 2010
I am using FRONTECH LCD TV tuner MODEL NO:-JIL-0622.Recently connected to my new DELL LED then i was just changing the configuration of screen resolution but somewhere in middle it got stuck later on the...
update your driver of tv tuner for os of your computer.like win7 or win8.
second do windows update for your computer and do update for your graphic card--and do update bios of your computer.
thanks
Jul 14, 2014 | Philips SAA7130 TV Tuner/FM Radio/Video...
Delll optiplex 755 desktop - motherboard is dr845 13740. Problem with display. When boot up, no graphics on monitor - same as if monitor not connected. monitor checked ok but pc shows no visuals?
I don't know if you have done anything lately,ie; updates to board, cahnge of cables, etc. but first, try shutting down system, unplug your cable for video, unplug tour tower, plug tower back in and restart. If this doesn't work. You may want to try a system restore back to when you had a picture. Try this and let me know if this worked by adding comment or reply at the end of solution.
Dave
Mar 13, 2011 | Dell OptiPlex 755 Motherboard System Board...
Model AS655,cd midi system. records are playing ok then go into slow mode then good then slow again. i think i need new belt. do i just go with model no. to replace and i need description on how to access...
Hi Sue
This will almost certainly be a drive belt problem - they get worn and stretched over time- and will best be fixed by replacing the belt. You should be able to find one by searching on-line for Philips AS655 drive belt and including your country in the search criteria.
A temporary fix might be possible by using some 'belt dressing spray' - available from good tool shops. Squirt a little on the inner surface of the belt but take care not to get it on other components as it is rather sticky and messy. This will help the belt to grip the drive pulleys but you will need to keep repeating the treatment from time to time.
I don't know this particular model but with quite a lot of turntables you can get access to the drive belts by taking off the rubber mat on the platter - you may find some little windows you can get at it through with a pair of tweezers.
Otherwise you are going to have to get inside the case somehow. Some turntables have screws around the sides of their base-plate that allow you to separate them from the rest of the unit but be careful the wires are often short and it is easy to break them.
You can purchase a full service manual from here to download in pdf format, which should explain how to do it.
http://www.manuals-in-pdf.com/index.php?main_page=product_info&products_id=127430
Jan 29, 2011 | Philips Audio Players & Recorders
Hello I have a Dell optiplex GX270, with the mobo it comes with. It will boot, has sound coming from the HD, CD drive, cpu cooling fan, etc, but will not show anything on the monitor and the keyboard...
Hi,try swapping the Memory chip ie putting it on the other slot,also test with another processor if after all these system does display,i'll suggest you go get a new board.
Jan 04, 2011 | Dell OptiPlex GX270 Small Mini-Tower...
Problem with philips 713x tv tuner
This is a hardware driver problem.
The final version of Windows 7 has not been released yet, you most likely have the RC copy of Windows 7 (ie Release Candidate - final beta version just before official release) the RC is available to anyone to download and test.
The problem is that not all device drivers are avaiable and if you cannot get a Windows 7 version audio driver from the manufacturer's WEB site at this stage, you have to wait until it is available.
Sep 07, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Graphic card stopped working normally
Uninstall the current display drivers from the Control Panel > Remove Programs.
Then, go to Windows Update to download their version of the driver. It will work.
Aug 06, 2009 | Pine Technology XFX GeForce 9400 GT, PCI...
Hissing sound
Do you mean audio hissing sound or is there smoke coming out the back?
Audio hiss with the FM tuner selected would mean it's between stations or you don't have an antenna. Try tuning around the band with an antenna.
Close what?
Connect what to what tuner? It has an internal tuner.
Apr 04, 2009 | Audio Players & Recorders
Tune 14 inch TV on remote ie BBC1 on No 1 thro to No5.
here is a link to thhttp://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG&cat=TV_CONVENTIONAL_CA&sct=COMBI_TV_SU&session=20090102155334_65.38.34.98&grp=TV_GR&ctn=14PV182/05&mid=Link_UserManuals&hlt=Link_UserManualse manual
Dec 29, 2008 | Philips TV Tuner Video Capture PCI Card -...
Marantz CC-4000 5-Disc CD Changer Logo
204 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
